Rear Alignment at 41 Degrees Toe?
Old 08-25-2013, 11:28 AM   #1
Tacoma SD [OP] Tacoma SD is offline
Tacoma SD is on a distinguished road
Tacoma SD's Avatar
Tacoma SD's Tacoma Gallery
I did some searching on the forums, but no luck with rear alignment issues. I believe its because no one usually has rear alignment problems.
My question - What are the traditional alignment specs for the rear tires? Because it is an axle Im wondering if it is only adjustable by re-adjusting the leaf springs and blocks?
My theory for my truck having 41 degrees of toe on the right rear is that the previous owner may have ran over something on the right side.
There is a door ding on the front passenger door and the alignment on the front right is a little off, but within the range. The rear must have hit or ran over something to throw the alignment and toe off?
Overall I dont believe it is a huge problem, but 41 seems like a high number to have for toe on any tire.
Any suggestions for re-aligning the rear to have better toe settings?
Old 08-25-2013, 11:40 AM   #2
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
I think you mean 0.41 deg, i.e. less than half a degree. Could be a slightly bent wheel, bent bearing flange on the axle housing, or bent driveshaft. Could also be a misdrilled hole in one of the leaf packs. No practical adjustment method. There's a reason solid axle + leaf springs setup has been shunned in passenger cars - it leads to imprecise wheel control.
The front toe can be adjusted to match the rear net "thrust angle". That's about it.
Old 08-25-2013, 11:48 AM   #3
85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future85GT 79FJ40 has a brilliant future
85GT 79FJ40's Tacoma Gallery
Nothing to worry about. If it was 41 degrees you wouldn't be driving it!
Old 08-25-2013, 02:36 PM   #4
aficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shedaficianado is one of the sharper tools in the shed
aficianado's Tacoma Gallery
amazing.
Old 08-25-2013, 02:48 PM   #5
Total Automotive Performance
TacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shedTacoDeLaPlaya is one of the sharper tools in the shed
TacoDeLaPlaya's Tacoma Gallery
Yeah i was like... Who would even put it on the machine with the axle twisted halfway off.
Don't worry and you cant do anything anyway. You could rotate the wheel and retest a few times to see if its the wheel or the drivetrain if you want to diagnose
EDIT
I would assume there machine has .1-.2° of error. I dont think they adjusted an extra tenth of a degree onto the left side of your solid rear axle.
However i think this readout leads to a lot more questions than answers if you compare all the numbers i would have them recheck
left rear camber, right rear toe, front right caster, and camber should be close to - as possible i dont think positive camber is good on our tucks since the camber already gets more positive when the wheel is turned.
Old 08-26-2013, 09:57 AM   #6
Tacoma SD's Avatar
Wow I am sorry for the lack of knowledge on my part. haha I didnt even think about the .41 vs 41 for some reason. Makes sense now that it isn't a huge offset. I cancelled out the wheel and tire because they have been rotated after the first alignment and the one I posted was the second one.
Thanks for not blowin me out of the water! I appreciate the feedback and info.
I'm guessing my misalignment is from something from the previous owner running into or over something. Ill check underneath to if there is anything obvious and get back to this post to update.
Old 08-26-2013, 10:24 AM   #7
10splaya22 is on a distinguished road
10splaya22's Avatar
10splaya22's Tacoma Gallery
The difference will be so small you won't even notice it.
Here is 1 degree. 0.41 is less than half this angle.
Old 08-26-2013, 05:09 PM   #9
We set our race cars slightly towed in at the rear.
Old 08-26-2013, 08:09 PM   #10
Dirty Trucker
TacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shedTacoSupreem is one of the sharper tools in the shed
TacoSupreem's Avatar
TacoSupreem's Tacoma Gallery
.41 degree’s doesn’t necessarily mean .41 degree’s because i’ll be willing to bet the alignment machine wasn’t 100% accurate. They never are. If your truck is driving ok and the tires are wearing ok then your probably ok.
Old 08-26-2013, 08:15 PM   #11
I think your tires will tell you if theres a real issue you cant feel while driving it. Just check them for uneven wear periodically. look around the tread. especially toward the inside of the tire. bend down if you have too.
Im from sd too glad to help you out
Old 08-27-2013, 09:44 AM   #12
Tacoma SD's Avatar
That makes sense that the alignment is fairly off. I guess I glanced at the numbers and assumed they shouldn't be that high.
Ill keep an eye out for wear and rotate them. Thanks again for all the help guys!
Alignment degrees TAC1 2nd Gen. Tacomas 0 08-09-2013 02:06 PM
Wtb rear axle leaf shims 2.5 and 3 degrees BaconTaco 2nd Gen Tacoma Marketplace 1 11-10-2012 10:17 AM
Please advise: uneven "bad toe" tire wear even with "good" alignment. MGRS 2nd Gen. Tacomas 13 02-24-2012 05:05 AM
Alignment "toe" problem Gunfan 2nd Gen. Tacomas 5 01-14-2012 11:14 AM
Rear Left Toe Allignment Issue - 2007 Oscar Wheels & Tires 2 07-27-2009 09:18 PM
