Cheap shelves in bed mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FirstTracks, Sep 13, 2013.
  1. Sep 13, 2013 at 5:32 PM
    FirstTracks
    FirstTracks [OP] Well-Known Member
    Marc
    Salt Lake City, Utah
    07 Tacoma Access Cab 4.0L V6 SRS 6sp manual
    Leer cap, BedRug
    I spend a lot of time camping in the bed of my Tacoma and a wanted simple shelves back there to put stuff.
    I took a 2'x4' piece of MDF project board, cut it with a jigsaw to fit next to the Leer cap clamps and end caps of the track, painted it and simply slipped it into the bed track. Total cost: approx. $14.
  2. Sep 13, 2013 at 6:18 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
  3. Sep 13, 2013 at 6:19 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Hey that's pretty smart!
  4. Sep 13, 2013 at 7:33 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    Nice! I need a topper!
  5. Sep 13, 2013 at 8:00 PM
    jw1983
    jw1983 Well-Known Member
    Jason
    Alberta
    13' Tacoma Access 4x4 OR
    Looks great!
  6. Sep 13, 2013 at 8:51 PM
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    Dam that's a great idea you had there. And it looks nicely flush. Nice work buddy
  7. Sep 13, 2013 at 9:01 PM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    Nice!!
  8. Sep 14, 2013 at 8:07 AM
    FirstTracks
    Marc
    Leer cap, BedRug
    Thanks folks. It'll just be nice to get some things up off the floor while sleeping or while hanging out on a rainy evening. I've also got a trip permitted in early November for the White Rim in Canyonlands NP near Moab and I needed some place to put a small catalytic heater in case it gets particularly cold.
    I'm also not much of a fabricator, so I was pretty damned pleased that it turned out just like I envisioned it.
  9. Sep 14, 2013 at 8:25 AM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I am not much of a fabricator if any at all and I applaude your work. Did you think about maybe putting a lip around the edge of it to keep things from sliding off? I know you won't be moving the truck when you use them but we all know how things tend to slide around.
  10. Sep 14, 2013 at 8:26 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    Also, care to share your measurements for the rest of us to copy, lol????
  11. Sep 14, 2013 at 9:09 AM
    FirstTracks
    Marc
    Leer cap, BedRug
    The lip is a good idea, I hadn't thought of that. I suppose if I wanted to glue a furring strip for a lip edge I should have done that before painting. Small screws or finish nails could be an option now that they're already painted.
    I wanted the shelves to occupy 20" of track on each side so they're 28.3" on the long side to preserve a right triangle. I therefore took the 24" by 48" MDF panel and cut it to 28.3" long. I thereafter split it right up the middle to create two pieces 12" x 28.3" each. I then measured 12" from each end to draw and then cut each 45 degree angle. I then put it in place to mark, measure and thereafter cut each cutout, first for the bolts and blocks that attach the shell to the truck, and then for the ends of the side tracks. Finally I used a palm sander to smooth the edges and make up for my lousy saw cuts before spray painting them with Rustoleum's combo primer/enamel, 3 coats.
    It took about an hour total, not including paint dry time.
  12. Sep 14, 2013 at 9:14 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    That's a great mod,
    Good job man,
