Engine Shut Down/Lost Electrical
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CIAGDDS, Sep 22, 2013.
  1. Sep 22, 2013 at 3:50 PM
    CIAGDDS
    CIAGDDS [OP] Well-Known Member
    Corona, Ca.
    05 4x4 TRD OR
    Driving home this morning the engine died out and all my electrical shut off. This lasted about two seconds, then everything powered back up and the engine came back on and I was able to finish my half hour commute. The key never left the ON position. Any ideas on what happened?
  2. Sep 22, 2013 at 3:58 PM
    DavisBladeWorks
    DavisBladeWorks Well-Known Member
    John
    North ATL
    2013 DSCB TRD Sport 4x4
    EMP gun.
    Kidding.. I have no clue.
  3. Sep 22, 2013 at 3:58 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    wizards
  4. Sep 22, 2013 at 4:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Now we have an "Unintended Deceleration" problem.
  5. Sep 22, 2013 at 4:10 PM
    CIAGDDS
    Corona, Ca.
    05 4x4 TRD OR
    I didn't know what to do, so I throttled up.
  6. Sep 22, 2013 at 7:08 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) If you can answer some questions about your problem, the additional information may help find a solution.
    How old is your battery ? Did you hit a bump in the road or do anything unusual while driving ? Was it a sudden power loss, and a sudden return to power ? Has anything else happened since you made your post, has it happened again ?
    With a few answers from you and some deducing from the fellow members, a solution will be found. Good Luck.
  7. Sep 22, 2013 at 7:27 PM
    CIAGDDS
    Corona, Ca.
    05 4x4 TRD OR
    No bumps, just all of a sudden lost all power (engine and electrical) as if I turned the key off. Lasted about two seconds and everything came back on. I don't know how old the battery is, but it is not stock.
  8. Sep 22, 2013 at 7:28 PM
    jaeforceone
    jaeforceone Member
    Jae
    Gainesville, FL
    2013 DCLB 4X4 TRD Sport
    is your car a manual?
  9. Sep 22, 2013 at 7:31 PM
    CIAGDDS
    Corona, Ca.
    05 4x4 TRD OR
    Automatic
  10. Sep 22, 2013 at 7:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    A few ideas:
    - Bad battery - go to a shop and ask them to do a load test on the battery
    - Bad ignition switch - with the engine running, wiggle the key while it's in the "on" position. If the engine shuts off, you have a bad ignition switch.
    - Bad ground somewhere in the electrical system.
    - Loose connection on the battery.
  11. Sep 22, 2013 at 7:40 PM
    CIAGDDS
    Corona, Ca.
    05 4x4 TRD OR
    I'll check the connections and clean them. I thought a car would run with a dead battery as long as its started. It ran without any problems the rest of the trip and I just started it a hour ago with no problems. Weird. Hopefully it doesn't happen out 4x4ing.
  12. Sep 22, 2013 at 8:39 PM
    Hank4444
    Hank4444 Member...?
    Brian
    Daphne
    09 Sport DCSB
    Dog-Proofed Rear seat, 5100's, Rear TSB, Tranny TSB, Fog light mod, map light mod, DTRL mod, Volant CAI with ram air, UltraGauge, Blacked out emblems, extra D-rings, Bedlined front valance, Satoshi, Hella 500ff 55w HID, Dynomax Super Turbo Muffler, Leather arm rests, Weathertechs, Hankook Dynapro ATM, Oil catch can, URD MAF Calibrator, Wheelers HD AAL, Thule Roof Rack, OME 885x with Lean Spacer, RedLine Hood struts, Access LE Tonneau, LED Bedrail lights,
    I don't know if you have the factory alarm with the little red button next to the fog lights, but I had a similar problem. The alarm thought I was stealing my own truck I guess. Disabled everything. Turns out it was a bad battery, even though my battery held a 13+volt and 14 v when running (tested bad at the local auto parts dealer). Probably a bad cell in the battery. Changed it out and worked fine ever since.
    Anyway, really don't know if this helps your situation, but if it does I can find the reset alarm sequence in the morning. And to clarify, the sequence wasn't correct in the manual. A 2005 or 2006 model sequence worked for my 2009 truck.
    Go figure...
  13. Sep 22, 2013 at 9:30 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    This.
    Plus check anything at all that has been added aftermarket. Aftermarket stuff causes a lot of weird stuff sometimes. Trailer harness, alarms, stereo systems, dealer added alarm (most don't even realize it's there).
  14. Oct 4, 2013 at 4:56 PM
    CIAGDDS
    Corona, Ca.
    05 4x4 TRD OR
    So I never figured out why my truck shut down all of a sudden and came back to life and it hasn't happened since. But while driving to work yesterday the airbag light came on and the display for my mileage was flickering from high to low brightness. Once I got to work I shut it down and restarted my truck and all was normal again. WTF. I need to get a smog test done too. So should I wait for a hundred miles or so in case there was a code that needs to clear out of the system?
  15. Oct 4, 2013 at 10:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I see you have a 2005. Just to throw this out there> I had a high mileage truck that started showing strange signs ( flickering dash lights, Dropping power etc ). After going through all the wiring on the truck and not finding the problem in any wires I found that the Alternator Slip Rings were worn causing a very intermittent ground. I replaced the Alternator and was good as new again.
  16. Oct 5, 2013 at 5:52 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Just curious, how did you narrow it down to the slip rings in the alternator? That's some impressive troubleshooting, they're hard to get to unless you crack open the alternator.
  17. Oct 5, 2013 at 7:12 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Did you experience a time lapse?
  18. Oct 5, 2013 at 10:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well I tore it part and found where they were visibly worn through causing a Very Intermittent ground.
    I then just bought a new one.
  19. Oct 6, 2013 at 12:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not that this has anything to do with your situation, but.........
    My truck left me sit one night cuz it wouldn't start. I heard this cracking noise in the dash. I found out later, I had a short/burnt connections at my climate control plug in my dash.
    Cleaned things up, added di-electric grease and its been fine since. ????
    I did buy a used climate control pod, which I'm using now...
    Weirdest thing....to have a short in the dash and the entire truck just fell on its face and wouldn't start. Had my battery & everything tested good the next day at the dealer. That's when I found the burnt connections.
