3" lift- 285/75/16 or 255/85/16??
Old 10-10-2013, 09:23 PM   #1
TXTaco13 [OP] TXTaco13 is offline
TXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shedTXTaco13 is one of the sharper tools in the shed
TXTaco13's Avatar
TXTaco13's Tacoma Gallery
Planning on getting Icon Stage 2 3" suspension setup, but I am torn between the 285/75/16 and the 255/85/16 . I'd prefer to not have to trim, but if need be I will do it as long as it is minimal. If you have a 3" lift and either of the tires sizes please chime in a let me know the advantages and disadvantages! Thanks!
Old 10-11-2013, 10:29 AM   #2
vssman will become famous soon enoughvssman will become famous soon enough
vssman's Tacoma Gallery
There's some guys reported that they are running 255/85 on stock wheels with stock suspension and no trimming. No off roading either. See the 255/85 thread in the wheels & tires section.
Old 10-11-2013, 11:56 PM   #3
easystickerco is on a distinguished road
easystickerco's Tacoma Gallery
id go 285/75/16
Old 10-12-2013, 12:16 AM   #4
cheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shedcheeseit is one of the sharper tools in the shed
cheeseit's Avatar
cheeseit's Tacoma Gallery
Originally Posted by easystickerco View Post
id go 285/75/16
x2. I run this size and I had to get new rims with more backspacing because the tires rubbed on the UCA's. I also had to do pretty minor trimming.
Old 10-12-2013, 02:24 AM   #5
ACKtrd30 is on a distinguished road
ACKtrd30's Tacoma Gallery
3", 285/75/16 here. No rubbing in any situation. My 2008 had the same setup, just different wheels. Rubbed at full lock. Ymmv. I'd go with 285's
Old 10-12-2013, 02:33 AM   #6
The Past Through Tomorrow
JohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shedJohnnyWayne is one of the sharper tools in the shed
JohnnyWayne's Avatar
JohnnyWayne's Tacoma Gallery
Putting lift and 285's on today, will let you know how it turns out op.
Old 10-13-2013, 01:05 AM   #7
TXTaco13's Avatar
Originally Posted by Beavis0076 View Post
285/75/16 took mudflaps off... no trimming..
Untitled by beavis0076, on Flickr
Thanks for the reply. I do like the stance of yours. I'm really wanting the BFG All Terrains, Ive always ran them and get really good mileage out of them since 80% is on pavement. Do you have spacers? How much trimming if any? Do they rub on your UCA's?
Old 10-13-2013, 01:09 AM   #8
TXTaco13's Avatar
Thanks for the input! Aftermarket UCA's?
Old 10-13-2013, 01:10 AM   #9
TXTaco13's Avatar
Thanks! Which lift are you going with?
Old 10-13-2013, 01:12 AM   #10
TXTaco13's Avatar
Thanks for the heads up! Aftermarket UCA's?
Old 10-13-2013, 01:28 AM   #11
TXTaco13's Avatar
Thanks! You would think though that with stock suspension there would be rubbing like crazy... That 255 is big compared to the stock size!
Old 10-13-2013, 01:32 AM   #12
BulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shedBulletToothTony is one of the sharper tools in the shed
Name: You can call me Susan if it makes you happy.
Gender: Trans
BulletToothTony's Tacoma Gallery
Uca's are upper control arms. They are need to maintain proper alignment and are normally needed at lifts greater then 2.5 inches. They are also stronger then factory ucas and allow more travel. What part of Texas are you in OP?
Old 10-13-2013, 02:12 AM   #13
TXTaco13's Avatar
I was asking if his UCA's were stock or not. I decided on uniball vs. heim joint. They are cheaper and don't squeak as much.
Old 10-13-2013, 02:17 AM   #15
Gender: Trans
Ah ok then disregard my post
Originally Posted by OZ-T View Post
I would go 255/85/16
X2 after this set of 285's goes I think I'll try 255's next...
Old 11-27-2013, 03:20 PM   #16
tacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shedtacoflaco is one of the sharper tools in the shed
tacoflaco's Tacoma Gallery
How did it turn out? Any rubbing. I'm doing the ToyTec ULK and UCAs. Would like to mount up 285/75/16 to my OEM TRD wheels but would prefer not to have to do any trimming or the cmc. I have 265/75/16 right now and have no rubbing in any situation so far on or off road.
Old 11-27-2013, 06:40 PM   #17
Vantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shedVantage is one of the sharper tools in the shed
Vantage's Avatar
Vantage's Tacoma Gallery
I would go 255/85's on a 2" lift.
or
285/75/16 on a 3" lift.
285's look so damn good, but 255's are taller and usually do just as well if not better offroad and onroad.
Old 11-27-2013, 07:08 PM   #18
justchil is on a distinguished road
justchil's Tacoma Gallery
Woah so 285's do fit fine on stock wheels. I'm in the same boat as you OP. Decisions decisions lol.
How much of a spacer are you running Beavis? I'm guessing 1/2" to get 5 BS?
255/85/16s or 285/75/16? YellowDog01 Wheels & Tires 117 11-09-2013 07:08 PM
Last Question About Tires 255/85-16 Toyo MT or 265/75-16 Duratrac Magnetic Wheels & Tires 1 08-15-2011 08:14 AM
Using a 255/85/16 as a spare for 285/75/16? Tacoma831 Wheels & Tires 11 04-05-2011 04:37 PM
255/85/16 or 285/75/16 MadeInMaine Wheels & Tires 33 09-25-2010 10:46 PM
