Totally Confused about Wheel Choices HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bodacious, Jan 6, 2014.
  1. Jan 6, 2014 at 7:47 PM
    Bodacious
    Bodacious [OP] Well-Known Member
    Dave
    Northern Michigan
    TRD Sport 4x4
    Ok so I read a gazillion posts about wheels, tires, offset, and back spacing and still don't have a frick'in clue as to what might fit or not. Stupid Old' Guy doesn't get it.
    Here is where I'm at:
    I will be using my OEM Bridgestone 265/ 65R 17" tires
    2014 TRD Sport AC 4x4
    Non-Lifted stock suspension.
    OEM wheels are:I Believe.... 17"x 7.5" +32mm offset 5.25" Backspacing
    6x5.5" bolt pattern.
    I'm an on-road driver, not looking to go Wheeling.
    1- Most wheels I looked at are 8" to 9" wide. First of all what is the maximun wheel width I should consider, and what width would be best for my tire size?
    2-What back spacing do I need?
    3- What offset is suitable?
    I would like to have wheels with more of a dished look (wider stance) but not so pushed out that I have clearance problems.
    I guess I'm looking for the spectrum that I can use as a guideline.
    I looked at TireRack but really don't understand what will fit the Tacoma.
    I realize that this may seem elementary .......thanks for your help.
  2. Jan 6, 2014 at 7:59 PM
    dxpsman
    dxpsman Well-Known Member
    Brandon
    Oceanside, CA
    14 TRD Sport PreRunner
    AFE MACH Force-Xp 3" Cat-Back Stainless Steel Exhaust System w/Black Tips, Complete OME 3" lift, debadged, Body Armor 4x4 side steps.
    Anything beyond a 17X8.5 will be a stretch fitment for your stock tires, and therefore be unsafe.
    Backspacing/Offset is two different ways to measure the same thing. If you're looking to keep close to the stock stance, a 17x8.5 with a +6 or +12 offset is going to be your cup of tea. If you'd like to have the wheels protrude slightly (more common for aftermarket rims), go with the -6.
  3. Jan 6, 2014 at 8:16 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    Thanks, so try to stay with 17x7.5 or 17 x 8 would be a good choice for width?
  4. Jan 6, 2014 at 9:50 PM
    dxpsman
    Brandon
    Oceanside, CA
    Anything up to and including 17x8.5 is fine. Most aftermarket rims are designed to fit a larger tire since that's what most folks are doing, so finding anything less than a 17x8 might prove a bit tough.
    I'm in "the business" of wheels and tires. What exactly are you looking for when it comes to a rim?
  5. Jan 7, 2014 at 4:00 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Most aftermarket wheels you will find are 8" wide with a backspacing of 4.5". That would give you a wider stance and I doubt you will have any rubbing issues with a 30.5"x10.5" tire size(265/65/17). Avoid going with a 9" rim for your tire size.
  6. Jan 7, 2014 at 8:34 AM
    evan
    evan Well-Known Member
    SK, Canada
  7. Jan 7, 2014 at 5:49 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    dxpsman:
    The wheels I kind of like are the DC-2's
    they are 12mm offset, 4.53" backspacing (these both mean the same thing?)
    17" x 8.5"
  8. Jan 8, 2014 at 9:52 PM
    dxpsman
    Brandon
    Oceanside, CA
    Clean wheel. Those will play. These are designed to be an "ideal" offset, meaning they're going to fit relatively close to stock. The face of the wheel will sit relatively close to where your stock rims sit now. If you're not planning on upping the tire size, be prepared for a slightly "stretched" look in the tires as well as a slightly rougher ride, although you'll probably only notice this if you're really ride-quality conscious.
    And yes, the backspacing/offset is a different way of saying the same thing. Think standard versus metric.
    If there's a Discount Tire in your area, I'd highly recommend looking them up to get those rims. They get great prices on Mickey Thompson's rims (DC's manufacturer).
  9. Jan 9, 2014 at 9:31 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I think the OP's concern is that online stores like Tire Rack have a fitment warning on this rim that either trimming or a lift will be required. I like these wheels as well (but in 16") and haven't found many guys running them in any size to see if there were fit issues.
    Tire Rack has the following warning for 17" DC-2 4.53" backspace -12mm: Aggressive fitment. May require suspension lift for proper fitment
    Their warning for 16" DC-2 4.06" backspace -12mm is: Aggressive fitment. This will require modifications to prevent rubbing wheel wells
    So the concern is: with the specs noted, will they fit without rubbing because Tire Rack is being conservative or is there a real issue.
  10. Jan 9, 2014 at 4:28 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    Thanks for the info....vssman has read my mind and must have found they same fitment verbiage as I read from the Tire-Rack website.
    Thanks again for your help. (I'll try and reach Discount Tire and see if they can shed and light on this question).
  11. Jan 10, 2014 at 6:38 AM
    dxpsman
    Brandon
    Oceanside, CA
    -12mm is very aggressive. Stock tires will almost definitely rub the flaps with a -12mm 17x8.5 and a stock tire. I misread the OP's post as a +12mm offset, which would be fairly close to ideal, maybe slightly inset.
    I would suggest sticking with a wheel that's -6/+6 to avoid rubbing issues.
  12. Jan 12, 2014 at 3:36 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    Thanks!
  13. Jan 16, 2014 at 7:06 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    Ok getting closer, I'm trying to stay with an 17 x 8 wheel with -6 to +6 offset.
    Most wheels I'm looking at have a 108 bore, I read here that the Tacoma 4x4 only has a 106 bore. If this info is correct will a 108 work or not?
  14. Jan 16, 2014 at 7:09 PM
    dr dave
    dr dave Active Member
    david
    virginia beach
    tacoma, sport, 4X4, white
    I have different concerns. Got a 4X4, quad cab, LB, new 3 inch lift, looking at wheels, going for 285/70/17. Wheel weights that I have access to at my friend's tire shop are in the 29lb range. Should I be concerned these wheels are heavy, and try to go lighter or is this expected? Seems heavy
  15. Jan 16, 2014 at 7:11 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    just get Hub Centric Rings and you're golden
  16. Jan 16, 2014 at 7:27 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    This is how much a -12 mm offset sticks out, just for reference.
    Front view on my new truck:
  17. Jan 16, 2014 at 7:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Stock TRD Sport wheels are 26 lb for comparison. The lightest 17" wheels I've seen that are still affordable are about 21 lb: http://www.tacomaworld.com/forum/wh...74-17-konig-six-shooter-wheels-brand-new.html
    Pay more attention to tire weight gain. Stock P-metric tires are less than 40 lb. Most tires in 285/70/17 are LT, so you are looking at 55-60 lb.
  18. Jan 17, 2014 at 6:47 PM
    Bodacious
    Dave
    Northern Michigan
    TRD Sport 4x4
    If I'm under standing this offset concept, then: Stock wheels are +32mm which equals about (1.26") outward from center of the OEM wheel. Add another -12mm for example an aftermarket wheel (.47") This would put the new -12mm offset wheel about 1 7/8" wider or set out than the OEM wheel position.
  19. Jan 17, 2014 at 7:18 PM
    KenLyns
    Belly of the Beast
    Yep. And when you steer, the wheel swings over a 1-7/8" wider scrub radius. If you go with a larger-than-stock 32" tire, you would likely rub on mudflap at full lock.
