Help Installing Famous Fab Sliders - Not Lining Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Jan 7, 2014.
  1. Jan 7, 2014 at 3:44 AM
    iJDub
    iJDub [OP] Well-Known Member
    So, I'm trying to install the sliders but I can't get the holes to line up perfect where the rivets on the frame are. It's just off by a tad, but enough to keep the sliders from sitting flush.
    Anyone else have this issue? Will post pix below:
  2. Jan 7, 2014 at 3:48 AM
    iJDub
  3. Jan 7, 2014 at 4:00 AM
    udy2554
    udy2554 NORTHERN RED-NECK
    John
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Try using a uni-bit (step-drill) to enlarge the holes, or a dremel tool to adjust them!
  4. Jan 7, 2014 at 9:40 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
  5. Jan 7, 2014 at 12:15 PM
    iJDub
    Haven't read of anyone else having to. Kinda weird wondering if I'm doing something wrong.
  6. Jan 7, 2014 at 12:24 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    This
  7. Jan 7, 2014 at 4:24 PM
    tundrataco
    tundrataco Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    pics after install!!
  8. Jan 14, 2014 at 4:59 PM
    iJDub
    Can those of you guys with these sliders post a pix of the same area? I want to compare, thanks.
  9. Jan 14, 2014 at 5:07 PM
    udy2554
    John
    Naples, NY
    Mine were kinda tight! I bought them from a member. He started clearancing them, I finished with a uni-bit! Worked like a charm!
  10. Jan 14, 2014 at 5:22 PM
    udy2554
    John
    Naples, NY
    Kinda tough to take pics at night in a wet, muddy driveway, but you can see how some weren't exact. Just enlarging the holes a bit made the difference! Aside from that, the fit was impeccable! I haven't lifted the truck by them yet, but I stand on them all the time and I've slid past trees in my woods many times with no issues! Excellent product!:D
    Just to show off the old emblem!:cool:
    Get a Uni-Bit man, it takes just a few minutes per side to get the fit just right!:D
  11. Jan 14, 2014 at 5:23 PM
    iJDub
    OK, getting a unitbit. If I only have a cordless power drill will that work or should I look into a more powerful one?
  12. Jan 14, 2014 at 5:30 PM
    mach1man001
    Rob
    Blackstone, MA
    That should be fine. These bits work pretty quickly.
  13. Jan 14, 2014 at 5:34 PM
    udy2554
    John
    Naples, NY
    I used a 20volt DeWalt! A brand new Uni-bit will cut like butter! Use a lubricant and a lower speed so you don't heat the bit up! WD-40 will work in a pinch! Bar and chain lube, 5w-30, whatever you got! It's easier than you may think!:)
  14. Jan 18, 2014 at 4:14 AM
    iJDub
    Holy shit these things are hard to drill
  15. Jan 23, 2014 at 6:17 PM
    iJDub
    Do I need a special bit? Is this hardened steel? Lol
  16. Jan 23, 2014 at 7:17 PM
    udy2554
    John
    Naples, NY
    Man, I don't know what to tell you, mine drilled easy!:notsure:
  17. Jan 23, 2014 at 7:31 PM
    Black Pipe
    Black Pipe Well-Known Member
    just weld em on
  18. Jan 23, 2014 at 7:35 PM
    iJDub
    LOL I feel like I spent forever drilling em and only scratched the surface.
  19. Jan 23, 2014 at 7:40 PM
    Black Pipe
    The best way to enlarge a hole is to use a die grinder and a carbide bur bit. Works wonders. I had to enlarge the mounting holes on my bumper when I installed and it only took like 5 mins to do
  20. Feb 1, 2014 at 4:06 PM
    iJDub
    Ok carbide cutter on a dremel or die grinder is the way to go. That unibit would take forever. Finally got the holes enlarged enough. Kinda disappointed that these required modification to get fitted. Should be bolt on with no mods.
