Vibrating noise idling and initial acceleration during cold weather
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forealz, Jan 7, 2014.
  1. Jan 7, 2014 at 2:23 PM
    forealz
    forealz [OP] Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Hey guys,
    I'm hoping some of you can give me an idea of what is making this noise on my truck. I don't think this is the infamous Toyota tick. Other than that, the truck and everything seems to be running just fine.
    I noticed this as it has gotten colder. This usually starts from 30 degrees and below.
    Here is an audio clip of the noise. Use headphones/earbuds if possible.
    https://www.dropbox.com/s/m1mbw8bq8wm5f73/Truck Vibration.mov
    You can hear it slightly in the background within the first 20 seconds.
    1:06 - 1:09 you can hear the vibration noise right before you hear the brakes solenoid sound
    1:22 - 1:23 it's pretty loud
    You can hear background taps from from 2:05 to 2:20
    Briefly at 2:28 while accelerating.
    I usually only hear it at idle or initially stepping on the gas, but I have heard it while accelerating normally.
  2. Jan 23, 2014 at 11:21 AM
    forealz
    Los Angeles
    Anybody?
  3. Jan 23, 2014 at 12:32 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    You did not say which engine you have; I am guessing you have the 4.0L. They are notoriously noisy. The cams on these engines are not a hydraulic roller like most vehicles now days. Some of them have piston slap too when cold.
  4. Jan 24, 2014 at 9:09 AM
    forealz
    Los Angeles
    Yes it's the V6 4.0 Sorry.
    It sounds like it comes from the drivers side. It can make the noise at idle as well as when accelerating.
    I'll see if I can get another recording of the sound. It's never been super consistent.
  5. Jan 24, 2014 at 1:43 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I can't hear the noise well enough to know. But my exhaust makes a noise in similar situations - engine cold, just after starting, either just beginning to accelerate or stopped with my foot on the brake and the truck in drive. It goes away as soon as the engine warms up. (My exhaust is flattened, so I think the shop that did the work didn't hang it very well.) One thing to look at is all the rubber exhaust hangers. They should be centered on the metal hook that they hang on. If they are pushed one way or the other, the exhaust pipe can't vibrate as freely as it should, and that can push some noise into the truck.
    Also check the catalytic converter heat shields. They can come loose and rattle. They make a medium pitched tinny sound. Fairly easy to tighten them up.
  6. Jan 24, 2014 at 1:52 PM
    Slvr2ndGen
    Slvr2ndGen Well-Known Member
    05 PreRunner DCSB, 2010 PreRunner DCSB
    Check the intake where it goes through the fender. Mine vibrates when it's really cold just like the conditions you specified.
  7. Jan 24, 2014 at 2:02 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    My truck makes (sometimes, needs to be freezing cold and not driven for a few hours) funny noises when it's really cold until warmed up. I understand, I hate the cold as well.
  8. Jan 24, 2014 at 4:18 PM
    Breadman603
    Breadman603 Member
    Pittsburgh PA
    06 Tacoma SR5 4.0
    bed mat leer cap
    i have the same thing happening to me also....it only makes the noise when its running cold in drive but once it warms up I can faintly hear it when I accelerate from a stop....I thought it sounded like some kind of bearing going bad.....and its really starting to piss me off!!!!
  9. Jan 30, 2014 at 11:21 AM
    forealz
    Los Angeles
    Thanks everyone. Once it's warm enough I'll climb under and take a look. Really appreciate the input.
  10. May 25, 2015 at 7:08 AM
    tasnowma
    tasnowma Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    BUMP. You ever find out what the issue was? My truck (06 4.0) has a very similar sound when it's idling or slow acceleration. It started slightly yesterday but was much more apparent this morning. Although it was about 72 degrees when I started it today. Hmmmmm
