20" Enkei deep 6 on a 6" lift.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NEFLmudder, Jan 12, 2014.
  1. Jan 12, 2014 at 11:28 AM
    NEFLmudder
    NEFLmudder [OP] Well-Known Member
    Jacksonville
    2013 DCSB TRD
    6" Zone lift kit, 20" Tracker Level 8 (20x9 0 offset) with Firestone Destination AT 275/65/20, Debadged, double din touchscreen pioneer dvd, 10" kicker cxr in a taco tunes box and a 600.1 kicker amp. Custom made surf racks utilizing the track system.
    I recently traded my 05 tacoma in and got a 2013. I have came across some good deals and picked up a brand new Zone lift. Everybody days they are no good but no one ever says why. Either way brand new for $600 I could not pass it up. I have not seen anyone run these rims on a 6" lift. If you could show some pics that would be nice. Will they fit with the lift? I plan on running cooper discovery stt mud tires 35x12.50x20.
  2. Jan 12, 2014 at 11:46 AM
    Evenflow
    Evenflow Well-Known Member
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    The only thing you have to worry about with the wheels is that the backspacing is 4.5 or the back of your tires will rub on the spindles. If they come too close when the suspension articualtes and flexes they will rub the spindles bad. The next thing is that with a basic 6" DB spacer lift like that and 35's be prepared to do a ton of trimming, you will need to chop and cap your cab mounts, remove your mud flaps, remove the inner fender covers, trim the fender flares and even trim your fender back behind the flare. A 6" kit does not clear 35's unless you only drive in a straight line. If you don't want to do all of cutting just stick with 33's and your truck will be wayyyy more functional. Last but not least I would highly suggest getting a 4 or 5" leaf pack you will honestly hate the way the rear end feels with that 4" block, the axle wrap will be horrible. Not trying to be a downer, I have a DB kit and am speaking from experience.
  3. Jan 12, 2014 at 11:51 AM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    Here are just the rims.
  4. Jan 12, 2014 at 11:55 AM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    I have 5.5" backspace and thanks for the advice. I may just go with 33's and a 1.25 inch wheel spacer.
  5. Jan 12, 2014 at 11:58 AM
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    db lift + low pro tires does not make for a good off road truck. show truck yes
  6. Jan 12, 2014 at 12:13 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    I hate to admit it but more of a mall crawler except I go surfing a lot and drive on the beach and occasional mudding. Don't do much trail riding or rock crawling.
  7. Jan 12, 2014 at 12:23 PM
    Evenflow
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    I hate to say it buddy but the spacer plan is a bad with 35's and by the time you buy 4 good spacers + what you spent on the rims already your way over the cost of a proper sized set of wheels too. I would seriously suggest that you sell the wheels and look at buying something that is the correct spec without having to use a spacer. The other thing is that if you are going to run 33's you should really step down to 18" rims too, you have to run a 18" or larger with a BD kit to clear the spindle and new tie rod location but 20's will end up with very little sidewall. A 20" with a 33" will feel super rough like a low pro on a sports car... that + stiff truck suspension is a really bad combo... again just speaking from experience. I love the way 6" lifts look but you really have to do it the right way the first time or you will end up spending so much more time and $ in the long run and not be happy along the way.
    Ultimately the best thing to do if you want a drop bracket kit is to just buy the drop brackets and spindles only, then buy good CO's and a leaf pack.
  8. Jan 12, 2014 at 12:44 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    I appreciate the advice and have already started looking at 18's with 33's
  9. Jan 12, 2014 at 1:09 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Nice wheels man. Finally, some sporty looking wheels instead of the rig pig ones. :)
  10. Jan 12, 2014 at 1:41 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    They just might be up for sale now. Make an offer lol
  11. Jan 12, 2014 at 1:45 PM
    Silence9
    Alberta, Canada
    Much too large for me as I won't be lifting my truck, as far as I know. :)
  12. Jan 12, 2014 at 2:46 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, PDL, Tilt, Cruise, AM/FM CD
    Don't let them discourage you man,just do some research before you commit.
  13. Jan 12, 2014 at 2:49 PM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    Perhaps the best first post ever. Inspiring... :cool:
  14. Jan 12, 2014 at 3:20 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I was trying to post a picture for inspiration..
  15. Jan 12, 2014 at 4:13 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    Nice and is that your truck? If so what lift spacers and size tire?
  16. Jan 12, 2014 at 4:46 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Yeah it's mine. 295/55-20 toyo's,toytec ultimate lift w/Dakar leafs.
  17. Jan 12, 2014 at 4:55 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    is this the look you want?
  18. Jan 12, 2014 at 5:13 PM
    NEFLmudder
    Jacksonville
    2013 DCSB TRD
    A bit brutal with that one lol. No I just love these wheels and spend plenty of time on the highways.
  19. Jan 12, 2014 at 7:45 PM
    Darthyota
    Alberta
    Blown BSP X-Runner
    so just run the 20's with a performance touring tire with out the lift. i think that would be the cleanest look
  20. Jan 12, 2014 at 8:58 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    may i ask where you got the brand new lift for $600? i also have the deep sixes, love the wheels
