Knock sensor issues. What a dealer ripp off.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burnt C6, Jan 13, 2014.
  1. Jan 13, 2014 at 1:22 PM
    Burnt C6
    Burnt C6 [OP] Well-Known Member
    David
    Houston Texas
    Silver & Black 06 PreRunner
    Bilstein 5100 up front new Powder coated Coil Springs and Calipers, With 5160 in back, New 3” Dakar Rear Spring pack, Slotted and Cross Drilled Rotors, SS brake lines,Icon UCA’S . PIAA Driving Lights, Wheels Pro Comp 7031 17”x9 with 295/70 R70 XTreme tires. Katzkin Premium Leather Seats, Doug Thorley long tube headers and Y pipe, Under hood LED light kit,
    My buddy has a 2012 Tacoma with 30K on it. Last week theCheck engine light came on and he took it to the dealer. They are telling himthat a rodent got into the manifold area and chewed the harness. They want$2200 to fix the problem. They also told him that part of the cost was becausethey needed to replace the knock sensors as they could not check to see if theywere bad or not due to the wire being chewed up, each sensor was $265. I told him to tell them to hell with the sensors. They need to replace the wireharness then see is they are bad.
  2. Jan 13, 2014 at 2:57 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Did your buddy actually see the chewed harness?
  3. Jan 13, 2014 at 3:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Your insurance will pay for the fixing of the wire harness.
  4. Jan 13, 2014 at 3:37 PM
    Burnt C6
    David
    Houston Texas
    No I told him not to let them do anything till he saw it.
  5. Jan 13, 2014 at 3:39 PM
    Burnt C6
    David
    Houston Texas
    I did not know that. I will let him know that
  6. Jan 13, 2014 at 4:11 PM
    BamaToy1997
    Bill
    Navarre, FL
    I have seen this kind of thing DOZENS of times when I worked at the dealerships. Mice can do a number on wiring harnesses. That being said, saying the knock sensors need to be replaced is stupid. You can connect up the new harness to the knock sensors and test them right then.
  7. Jan 13, 2014 at 4:20 PM
    Burnt C6
    David
    Houston Texas
    That's what I told him. It's not so much fixing the harness as selling him unneeded sensors
  8. Jan 13, 2014 at 4:22 PM
    Manwithoutaplan
    ID
    I had this happened to me and I had insurance cover everything except the deductible.
  9. Jan 13, 2014 at 5:56 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Deaver 1.5" AAL Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on, Carrier Bearing flip
    My quote was $1800 to fix. My insurance covered the extra over the deductible.
    Do a search here about what is involved to replace the harness, the top parts of the motor all have to come off. The part is a little over a hundred, it's the labor that is the killer.
