Lucky 07 PreRunner to 4x4 Conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lucky, Jan 16, 2014.
  1. Jan 18, 2015 at 5:29 PM
    #141
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    cAble ADD almost done. The axle side of the cable is done. A few touch ups yet to do in the cab.
    Its pretty well protected.
    Inside shot.
    ADD off.
    ADD engaged.
    not_nick likes this.
  2. Jan 18, 2015 at 5:32 PM
    #142
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    This is pretty neat...does the stock 4x4 shifter still work?
  3. Jan 18, 2015 at 5:50 PM
    #143
    lucky
    NB, TX
    07 PreRunnerX4
    Yes. Its going in the classifieds....
  4. Jan 18, 2015 at 6:44 PM
    #144
    jimmybee1108
    jimmybee1108 Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    So that's the electronic actuator.
    I like what you've done with it.
  5. Jan 19, 2015 at 2:25 PM
    #145
    lucky
    NB, TX
    07 PreRunnerX4
    Cable operated ADD Inside done. I plan on running my elocker by cable also. ANother twist-lock t-handle will be in here before too long.
    Off
    Engaged
    not_nick and Crom like this.
  6. Jan 24, 2015 at 8:17 PM
    #146
    lucky
    NB, TX
    07 PreRunnerX4
    NO turning back now.
    a750e is OUT.
    a750f going in tomorrow.
  7. Jan 24, 2015 at 8:20 PM
    #147
    jimmybee1108
    JM
    San Antono
    Aaaaaahhhhhhh so exciting
  8. Jan 24, 2015 at 8:25 PM
    #148
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Sub'd. I'm on the fence about what direction I want my build to go but this is one of the options
  9. Jan 25, 2015 at 11:14 AM
    #149
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Looking good Lucky, that manual ADD actuator you made is pretty impressive. Honestly, I was having a few doubts about your project until I saw that, now I'm confident you'll have no trouble completing the job. Keep up the good work!
  10. Jan 25, 2015 at 2:47 PM
    #150
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    looks like you are doing a great job. Just seems like a lot of work. I'm a Pre Runner owner and at times wish I had a 4x4. But that's a lot, id just suck it up and trade it in on a used 4x4.
    best of luck
  11. Jan 25, 2015 at 3:01 PM
    #151
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I bought all the parts for the conversion, dropped it off at a shop and picked up my new 4x4 7 days later all for $4500
    frejil likes this.
  12. Jan 25, 2015 at 4:00 PM
    #152
    lucky
    NB, TX
    07 PreRunnerX4
    I got everything bolted up. Did some test fitting to make sure my cable-shifted FJ case was going to clear - it does - and proceeded to stab this sombich. I didnt get it and ran out of time for the day. I'll give it another go tomorrow. The tranny jack I rented has decent control for tilt and twist, but its worn out and doesnt roll very smoothly.
    All together
    Waiting for tomorrow
  13. Jan 25, 2015 at 4:10 PM
    #153
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    now that's what im talking about. that's the way I want to go, buy everything and have someone do it. Im really thinking of doing it, just finished paying my truck off.
  14. Jan 25, 2015 at 4:18 PM
    #154
    lucky
    NB, TX
    07 PreRunnerX4
    I've enjoyed doing it myself. Its taking longer, yes, but I'm doing it on my terms, timeline, etc...
  15. Jan 26, 2015 at 6:39 PM
    #155
    lucky
    NB, TX
    07 PreRunnerX4
    Successfully stabbed and bolted up. Still have to torque the flywheel/tc bolts, put starter back on and weld up my crossmember.
    Although I did some test fitting for the cable mechanism for the x-fer case, once I was completely bolted up, I didnt have the clearance I thought I was going to have. Ended up doing some trimming and had to make a hole in the tunnel. Would have been better off with traditional twin-sticks bent and re-routed like everyone else has done, but my cables are still going to work.
  16. Jan 26, 2015 at 7:32 PM
    #156
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Very awesome job so far. I have one question for you. Does the electronics all work still like say if you shift into 4L or 2L does the transmission go into limp mode since the computer is for a 2wd or does all that get changed or re flashed. I've been trying to convince the wife to let me solid axle my prerunner and run the inchworm adapter and just use a fj case with d44 from a jeep wagoner so i can keep my rear. The main thing im worried about is the computer deal and things going wrong that way.
  17. Jan 26, 2015 at 8:24 PM
    #157
    lucky
    NB, TX
    07 PreRunnerX4
    My ECU does not know there is a transfer case behind the tranny. I kept the shift indicators on the transfer case, but they are not plugged in to anything. I intend to splice in eventually so I get the appropriate dash indicators for 4-lo and 4-hi, and I will be doing a custom indicator for 2-lo, but there will be no ECU control of any of the 4x4 components.
  18. Jan 26, 2015 at 8:30 PM
    #158
    Timbo's Customs
    Timothy
    Lakeland FL
    So i take it that there is no need to do anything with the computer everything will work correctly even if 4lo getting on it the trans wont want to shift or shift to soon? would think it would go into limp mode. I just wanna make sure this is a pretty much a easy transfer case install.
  19. Jan 27, 2015 at 5:45 AM
    #159
    lucky
    NB, TX
    07 PreRunnerX4
    I dont know about others, but when I am in a 4Lo situation, I manually select the gear I want to be in. Note: Its been 15 years since I've owned a 4x4 with an Auto trans... I seem to recall that when in 4-Lo, if you let the ECU do all the shifting - i.e., putting it in D, the shifts are a little harsh and unpredictable.
  20. Jan 27, 2015 at 5:48 AM
    #160
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Before I continue reading the entire thread (looks to be a good one), what I need to know is where is 'NB, TX' that you're catching rainbows? :D
