Locking Gas Door install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eAreEyeSee, Jan 19, 2014.
  1. Mar 10, 2014 at 8:19 AM
    #21
    dionysis
    dionysis G.A.S. (Gear Acquisition Syndrome) sufferer
    Jim
    Northern Colorado
    08 DCSB SWB Auto V6 Stock, for now
    You should plastidip the end of the spring. It will keep you from having to use electrical tape. Or I do believe they make coated springs.
  2. Mar 10, 2014 at 10:29 AM
    #22
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    can the lite gas push button with the gas tank icon be supplied with kit?
  3. Mar 11, 2014 at 6:20 AM
    #23
    eAreEyeSee
    eAreEyeSee [OP] Well-Known Member
    Eric
    Aurora CO
    2010 DCSB TRD Off-Road
    Blah Blah Blah. Like your FF team, nobody cares!
    That's a great ideas. I hadn't thought of that. Thanks.
    The switch is not provided but you should be able to find it on eBay for around $12-18ish. It's from older 2k VW's.
    #23
  4. Mar 12, 2014 at 3:28 AM
    #24
    iJDub
    iJDub Well-Known Member
    If that fuse powers the 12V cig outlets - and the 12V cig outlets are only on when IGN is on, how come its a constant 12V (I went out and tested with my meter and sure enough it is constant 12V)...
  5. Mar 12, 2014 at 5:10 AM
    #25
    MrShoehorn
    MrShoehorn Well-Known Member
    Justin
    North Augusta, SC
    12 DCSB TRD Sport Blue Ribbon
    I could be wrong but if it's tied to the ignition then I believe the ignition switch would control the power. Much like a light switch it always has power but prevents power from reaching the light unless it's on.
  6. Mar 12, 2014 at 2:12 PM
    #26
    iJDub
    So the fuse is before the relay?
  7. Mar 13, 2014 at 11:21 PM
    #27
    eAreEyeSee
    Eric
    Aurora CO
    I'm not sure if that's a question or not. It sounds like you figured it out. I don't even know what that fuse is for. I just probed until I found a hot fuse without the key and stuck the fuse tap in it. I wanted constant so if I got out to fill up and forgot to pop the door i could just reach in and do it without putting the key back in the ignition.
    Yes. Fuse tap to your button. Then button to the relay/actuator.
  8. Apr 12, 2014 at 3:28 PM
    #28
    eyesurf2611
    eyesurf2611 Well-Known Member
    714 & 808
    09 Tacoma 4X4 DCLB & 4th Gen T4R
    *Icon Extended Travel Coilovers w/ 700lb. Coil *TC UCA *Rear Icon 2.0 w/ Resi *Rear All Pro Standards *ArmorTech Shackle Flip *All Pro Flip Kit *F&R Wheelers Bumps *All Pro Front Bumper w/ 10,500 Winch *All Pro Front Skid Plate *All Pro Trans Skid Plate *All Pro Mid Exhaust Skid *All Pro Rear Bumper w/Hitch *Rocky Road Outfitters Rock Sliders *Method Rims *Custom Bead Locks *305-70-17 Nitto Terra Grapplers *Hanneman Fiberglass Front Fenders *EBC Stage 5 Brake Kit *Bed Mounted HiLift *FrontRunner Roof Rack *50" Dual Amber/White LED Light Bar w/ Roof Rail Brackets *Custom One Off Removable Bed Rack *Satoshi Grill w/ BAMF Bar and (2) 20" LED Light Bars *Leather and Heated Seats *Full Audio/Video System
  9. Apr 14, 2014 at 7:21 AM
    #29
    SolarDude
    SolarDude Member
    Dude
    Dallas
    2014 4X4 Off-road AC
    None...yet.
  10. Apr 14, 2014 at 9:23 AM
    #30
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Put some heat shrink tubing on the last coil of that spring. Paint would wear off.
  11. Apr 24, 2014 at 5:09 PM
    #31
    kc123
    kc123 Member
    Where did you find the fuel button ? I've looked for one of those. Can't seem to find one like that.
  12. Apr 24, 2014 at 7:32 PM
    #32
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Have you checked eBay? If nothing there, you can always check out a auto junkyard, and there's also different Toyota parts websites .
    #32
  13. Apr 25, 2014 at 4:36 PM
    #33
    kc123
    kc123 Member
    Oh yes..checked ebay.....looked and looked until I'm crossed-eyed...I'll look around more...maybe go to a junkyard...I can find buttons like that just not with the the fuel emblem on them.
    #33
  14. Apr 25, 2014 at 4:59 PM
    #34
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    Isn't it from a toyota highlander?
  15. Apr 25, 2014 at 5:11 PM
    #35
    adio
    HI
    yes.
  16. Nov 24, 2014 at 4:00 PM
    #36
    wheelman
    wheelman Member
    Jim
    Toronto Ontario
    Tacoma TFD Sport
    Bed LEDs, TRD 17" rims, running boards, Tailgate power lock, Skid plate.
    This is what it looks like when you remove the finger pull! Color is right on unlike how it looks on camera.
    Jim
    markelhof and BudMan like this.
  17. Nov 25, 2014 at 10:55 AM
    #37
    eAreEyeSee
    Eric
    Aurora CO
    Very nice work sir! I wanted to do this too but don't really have bodywork skills. I need to find a spare door to work on.
  18. Jan 9, 2015 at 11:50 AM
    #38
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Did you do body work or find a replacement door?
    Y'all realize that the tacoma have an anti siphon screen in the filler necks
  19. Mar 8, 2015 at 6:00 PM
    #39
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    Installed mine today, I used the same VW button. I ended up using a piece of weather stripping from my Tonneau cover and put it on the inside lip of the door instead of trying to add the spring to the outside lip, the door springs all the way open vs just popping slightly, I love it! Thanks
  20. Mar 8, 2015 at 9:09 PM
    #40
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Fyi...to the guys with the newer 2nd gens doing this. If for some reason and I have seen it the actuator either fails or breaks while your out and about you'll have to remove the actuator from under the fender well to get gas in your tank. As a failsafe method I used the original gas door pinch clip as it will grab on to the actuator pin and still function as normal. It just won't be as secure, but I'm not worried about gas theft.
