LSC15's 95 Tacoma 4x4
HID fog light help!!
Old 01-21-2014, 12:17 PM   #1
Trev407 [OP] Trev407 is offline
Trev
Trev407 is on a distinguished road
Trev407's Tacoma Gallery
Exclamation HID fog light help!!
Hey everyone. I purchased an HID kit from SDX. First off, the instructions seem to be written by someone with no literary or electrical sense. But, through what little info I could decipher from the generic instructions, I thought it seemed like a simple install. One side of the ballast is input and one is output. Most of the connectors are made so that you cannot screw things up (so I thought). So I plugged everything in to see if they would turn on and nothing happens. So I check the fuse. It's a 15 amp and it's blown. The instructions do say you need a 20 amp fuse. So, I replace the fuse. I check my connections. Once again I turn them on and nothing happens. So I check voltage at my fuse and I have battery voltage of roughly 14v. Pull out the fuse. It's good. I pick up the drivers side ballast and it's warm... Check the other one, it's room temperature. Does this sound like a ballast failure? Even if one had failed the other should work since the fog lights are wired in parallel...Is it likely that both ballasts would fail? Or could I just have them wired incorrectly all together? Need some help! Thanks
Display Modes
HID Fog light HELP! rmahoney2013 Audio & Video 13 12-28-2011 06:58 PM
Fog light HID thewhiteknight Lighting 8 12-22-2011 07:59 PM
HID FOG LIGHT ufrusty Lighting 1 06-24-2011 10:36 AM
fog light hid danstacoma Lighting 10 01-07-2011 11:21 AM
fog light hid's???? brutalguyracing Lighting 29 03-23-2010 11:56 AM
