Rust on 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tskeens, Feb 3, 2014.
  1. Feb 3, 2014 at 9:32 AM
    Tskeens
    Tskeens [OP] Well-Known Member
    Trevin
    Maryland
    2022 MGM TRD-Off Road
    100% stock
    How common is this for a 2 year old Tacoma with 18K miles? I just bought it "certified" last week. :confused:
  2. Feb 3, 2014 at 9:35 AM
    tacofox
    tacofox Well-Known Member
    Isaac
    MO
    11 reg cab 4x4
    my 08 had 154000 miles and its been in the northen ststes and didnt have any snow so i think thats really odd
  3. Feb 3, 2014 at 9:41 AM
    OffroadToy
    It all depends on where it's been. Get it taken care of now before it gets any worse.
  4. Feb 3, 2014 at 9:42 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Looks like the previous owner took zero care to keep it clean and rust free so it makes me wonder about the rest of the truck.
    I'm in NJ and my 08' with 94k looks MUCH better than that.
    You sure the ODO reading is correct? Its super easy to unplug them on these trucks so they register zero mileage - what I'm saying is that truck looks to have much more corrosion on it than 18k worth.
  5. Feb 3, 2014 at 9:43 AM
    LukeBo4x4
    LukeBo4x4 The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    do u what state it came from exactly?
  6. Feb 3, 2014 at 9:46 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    My 2012 in chicago winters doesn't look anything like that.
  7. Feb 3, 2014 at 9:47 AM
    Kyle Butler
    Kyle Butler Well-Known Member
    1972 LeBaron
    Green, some brown or rust coloration, a tape deck, some Creedence tapes
    Is that Torx bolt from the tailgate? I noticed mine were beginning to rust and they are less than 2 years old (got new bed and tailgate in Oct 2012). I just sprayed them with some Fluid Film.
  8. Feb 3, 2014 at 9:52 AM
    Tskeens
    Trevin
    Maryland
    100% stock
    It came from Pennsylvania originally. I first noticed the bolts in the bed after bringing the truck home, which were snow covered when I test drove the truck.Then I started looking underneath and found much more. I know it's "buyer beware but being Certified Used, I don't think this should have passed. I think the mileageis accurate, at least according to the carfax that I received with the vehicle.
  9. Feb 3, 2014 at 9:54 AM
    Tskeens
    Trevin
    Maryland
    100% stock
    Yes, the bolts in the bed.
  10. Feb 3, 2014 at 10:02 AM
    XXXX
    sKiP
    05 Prius
    Carfax is worthless for anyone who knows anything about cars and is looking to get over on people. How would it know the mileage? How would it know about unreported accidents?
    I have been in three accidents in my truck and my carfax is completely clear. I also could of had my odometer disconnected for the past three years and no one would know except me. You need to look for abnormal wear and other issues not depend on some website Fox.
    Rusty leaf springs are a joke so forget about them being replaced by Yota. The bed bolts tend to rust after being scrapped by stuff going in out of the bed and after all it's a truck so Yota won't do anything there either. The axles in the rear are rusty but has nothing to do with performance so again - nothing to be done.
    I'm not sure why it's Toyotas fault you bought a rusty truck? Did you expect them to replace the parts before they sell a 2 year old truck?
  11. Feb 3, 2014 at 10:08 AM
    Tskeens
    Trevin
    Maryland
    100% stock
    Who said that?
  12. Feb 3, 2014 at 10:26 AM
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    Don't mind XXXX. It's not the first time he's posted a snotty, pointless, presumptious, argumentative, assholeish statement.
  13. Feb 3, 2014 at 10:33 AM
    XXXX
    sKiP
    05 Prius
    Said what?
    I told you about carfax and asked you simple questions.
    No words put into anyone's mouth.
  14. Feb 3, 2014 at 10:34 AM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Take it back in, the stealership might bust off the rust and give you a free undercoating. I dunno, but it's always worth a shot - especially if you literally just bought it last week.
    Good luck.
  15. Feb 3, 2014 at 10:36 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Seems a bit aggresive for 2 years but my truck had heavy surface rust pretty much everywhere on the under carriage after the first 2 winters
  16. Feb 3, 2014 at 10:44 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Someone never washed that truck. I live in upstate NY I've had my 2009 since it was new and the surface rust isn't that bad. From your pictures it appears to be just surface rust nothing the would stop it from being sold as certified used, your truck isn't going to fall next week or anything.
  17. Feb 3, 2014 at 10:47 AM
    Tskeens
    Trevin
    Maryland
    100% stock
    “You are entitled to your opinion. But you are not entitled to your own facts.” Daniel Patrick Moynihan
    "A bad attitude is like a flat tire, you can't go anywhere until you change it." Derek Donovan
  18. Feb 3, 2014 at 12:21 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I would at least take it to a dealership to get it documented. Then scrape/paint/fluidfilm and forget about it!
  19. Feb 3, 2014 at 12:30 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    +1 here in Québec. Salty roads all winter long. I'm washing it often and have treatment against rust every year at the end of summer.
  20. Feb 3, 2014 at 2:24 PM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    Did you claim with the Insurance Companies? If not then how the heck do you expect CarFax to know?
    Have you TRIED to unplug or rollback the ODO on these new vehicles? Not a simple task though.
    OP...My '12 with 25k miles in Nebraska does NOT look that bad. Have it taken care of. Good luck.
