Replaced power steering pump, Still no power steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjhitchen, Feb 9, 2014.
  1. Feb 9, 2014 at 3:56 PM
    jjhitchen
    jjhitchen [OP] Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    The pump on my truck was whining for some time like all power steering does when its going bad. One day off road the power steering went out and the pump stopped whining. When I went to replace the pump today we flushed the reservoir because it was full of metal shavings from the old pump. Could the old pump going out destroy the power steering rack too? The new pump has been flushed and bled twice and still no power steering assist. The truck drives fine just no assisted steering.
    Alexely999 likes this.
  2. Feb 9, 2014 at 9:41 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    bump somebody helllp!
  3. Feb 9, 2014 at 9:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I really do not know, but it stands to reason that if you had metal shavings in the reservoir there are also shavings inside of the rack itself. I would say the possibility of the blown pump taking out the rack are very good.
    JDawg562 likes this.
  4. Feb 9, 2014 at 10:01 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    No personal experience to draw from, but a friend lost the power steering on his F350. He went out one morning and it was gone, no warning at all. Changed the pump with no improvement. Changed the steering box and that fixed it.
  5. Feb 9, 2014 at 10:04 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    well, if you changed the pump, what else is left? lines. and a rack.
    what was your bleed procedure?
    what brand pump?
  6. Feb 9, 2014 at 10:15 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Metal shavings blocking the HP lines to the rack?
  7. Feb 9, 2014 at 10:19 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    collapsed line?
  8. Feb 9, 2014 at 10:30 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    New rack
  9. Feb 9, 2014 at 11:41 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    The pump was roaring off road about a week ago like I said, and then I lost power steering at about 35mph and noticed right away so I slowed.. We kept it running and hopped out, popped the hood and saw the line going from the reservoir to the pump was sucked shut on its self and pinched like the reservoir filter was clogged. The pump must have dried out, burnt up and shot metal into the rack, going through the rack and up the return line to the reservoir. I cant imagine running metal shavings in oil through a mechanical device with seals would be a good thing. The rack is shot. I think we have a verdict. Thanks guys :thumbsup:
  10. Feb 18, 2014 at 8:48 AM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Buuuummppp
    :annoyed:
    I have now replaced the pump AND rack and STILL no power steering!!!!!!!
    We think the shitty replacement pump i got from autozone was broken or went bad right away. What kind of pressure should be coming out of the "high pressure" line from the pump to the rack??
    This has been such a riduclous learning experiance.
    We removed and completely flushed every power steering line and no clogs, flushed the reservoir and now im waiting on another Power steering pump to give that a shot. If this doesnt work im giving up and taking it to a local shop where some buddies work.
    upongame619 likes this.
  11. Feb 18, 2014 at 8:52 AM
    BamaToy1997
    Bill
    Navarre, FL
    the pressure of most pumps is quite high. Some as high as 200psi.
  12. Feb 18, 2014 at 8:59 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I think you meant 2000 psi. 200 psi is nothing. Although stock pumps don't usually put out 2000 psi, but many aftermarket pumps do.
  13. Feb 18, 2014 at 12:22 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I can't confirm on our 2nd gens but more than likely if it has a screen (like most late model vehicles) in the reservoir, it's clogged especially if you have shavings and gunk that would prohibit flow in the PS system. Have you taken the reservoir out and cleaned the screen or replaced the reservoir ? My guess is a clogged screen in the reservoir causing no flow in the system.
  14. Feb 18, 2014 at 12:54 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Thats what im thinking, there was nothing close to 200 or even 1200 psi coming out of the high pressure line. I read a few places is should be 1200-1800 psi on tacos
    We also thought the same thing, I know a clogged screen blew up the first pump because it caused the reservoir to over flow and choked the pump. This time we took the reservoir out and flushed it completely, blew it out with 200psi compressed air and clean out everything we could, I almost just want to replace the reservoir for complete peace of mind.
    Going to swap a new pump into the truck in about an hour and put it all back together and hope for the best.. 2 pumps and 2 racks later lets see if I can get this figured out :confused:
  15. Feb 18, 2014 at 5:10 PM
    BamaToy1997
    Bill
    Navarre, FL
    Derp! I meant to type 2000. Not enough zeros. lol.
  16. Feb 18, 2014 at 9:27 PM
    Spoonman
    Jamie
    Alberta
    Wonder if the stock rack can handle that extra psi. I'd like to bump the psi from stock, I can't steer when aired down
  17. Feb 18, 2014 at 10:25 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    holy shit!!!!!!
    suuper super :annoyed:
    replaced the pump and it worked for about 5 minutes on my trip around the block then power steering pump started getting loud again and smelling hot then went silent and I lost steering assist again and the reservoir overflowed and splattered fluid out the top like the first time...........:mad:
    a) the new pump blew up again! (heard horror stories of people going through 4-5 parts from autozone before they got a good one)
    b) the reservoir is actually clogged somehow and caused the pump to blow up
    c) I have no idea what the fack is going on
  18. Feb 18, 2014 at 11:06 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Are these New Pumps or Remanufactured Pumps? I'm thinking Remans. You may want to just buy a New Pump and save yourself some aggravation.
    This is how they describe the remanufactured pump:
    Bushings and bearings are inspected and replaced if necessary
    Shafts are precisely measured, center less ground and replaced if not to specification
    Cam pack rings are resurfaced or replaced if necessary
    Painted
    to help protect unit in harsh road conditions
    I would just buy a new one.
    MTopp likes this.
  19. Feb 19, 2014 at 5:36 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    I believe there is a filter screen in the supply tube to the pump, might wanna check that if you haven't.
    Also...I am removing a stock pump in perfect working condition this weekend and installing a Trail-gear full hydro pump. PM me if you're interested, I will sell it to you on the cheap.
  20. Feb 19, 2014 at 8:12 AM
    BnbBlitz
    BnbBlitz Well-Known Member
    over the rainbow
    13 DCLB 4WD
    Get a toyota pump.
    Check the power steering switch just for fun
