The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Mar 1, 2014 at 1:18 AM
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I put together a collection of some of the most-common Torque Specs and Diagrams. These are all from the 2006 FSM.
    __________________________
    FRONT SUSPENSION COMPONENTS
    2WD
    4WD & Pre-Runner
    REAR SUSPENSION COMPONENTS
    2WD
    4WD & Pre-Runner
    Rear Shocks (2WD/4WD/PRE-RUNNER)
    Suspension MASTER LIST
    FRONT AXLE COMPONENTS
    2wd
    4wd & Pre-Runner
    4wd ONLY
    REAR AXLE COMPONENTS
    Front & Rear Axle MASTER LIST
    4wd Only
    POWER STEERING
    2WD
    4wd & Pre-Runner
    DIFFERENTIAL
    Front Differential
    Rear Differential (non E-Locker)
    Rear Differential (E-Locker)
    Differential MASTER LIST
    DRIVELINE (Prop-Shaft)
    2wd Reg. Cab
    2wd Access Cab
    4wd Reg. Cab
    4wd Access Cab & Double Cab
    Front Driveline (4wd Only)
    Driveline MASTER LIST
    EXHAUST
    2TR-FE
    2wd & Pre-Runner
    4wd
    Exhaust MASTER LIST
    4cyl
    V6
    BRAKES
    Front Brakes (2wd)
    Front Brakes (4wd & Pre-Runner)
    Rear Brakes
    Brakes MASTER LIST
    EXTERIOR MISC.
    Exterior Misc. MASTER LIST
    TRANSFER CASE (4wd)
    Transmission (some Diagrams listed in the Engine section below)
    A340E
    A750E
    A750F
    R155
    R155F
    RA60
    RA60F
    2TR-FE Engine
    Main Assembly & Accys.
    Internal Assembly & Components
    2TR-FE MASTER LIST
    1GR-FE Engine
    1GR-FE MASTER LIST
    ENGINE MISC.
    A/C System
    Charging System
    Cooling System
    Engine Control System
    Ignition System
    Lubrication System
    Starting System
    MISC.
    Clutch
    2TR-FE Fuel
    1GR-FE Fuel
    Parking Brake
    Power Streering
    Steering Column
    Tire & Wheel
    (Please let me know if you spot any errors/misprints)
    As always, feel free to leave constructive feedback or PM me with any questions :cheers:
  2. Mar 1, 2014 at 1:29 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Great Job
    BandanaBerg likes this.
  3. Mar 1, 2014 at 1:32 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Chris...though I am already regretting linking the pics from PB. Takes FOREVER to load.
    Might transfer them somewhere else or scale them down.
  4. Mar 1, 2014 at 1:35 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Wow, lots of big pictures.
    Good job, tons of good info here.
    TacomaCZman likes this.
  5. Mar 1, 2014 at 1:45 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thank you Jake. I only have the '06 FSM, but maybe I can get a 1st Gen FSM at some point.
    I forget to uncheck the "Save Original Resolution" when I uploaded to PB....smh.
  6. Mar 1, 2014 at 1:48 AM
    95 taco
    95 taco Battle Born
    I have the 1st gen FSM, if i get a chance i'll make a thread, or i can PM you the link for it (if i can find it).
  7. Mar 1, 2014 at 1:55 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Yeah, for sure man. This took me about 3 hours to put together, working off & on throughout the day...but I don't mind doing shit like this :typing:
    I started going through the FSM and saving PDFs. I used GIMP to open, then export the PDFs into an image format (I used PNG, but jpg would work too). Then it was just a matter of sorting them into folders/categories and the most tedious part of all....posting with all the IMG links.
    RedDemolisher and MSN88longbed like this.
  8. Mar 1, 2014 at 1:56 AM
    95 taco
    95 taco Battle Born
    Sweet, thanks for the info, i'll start working on that and see how far i get. :thumbsup:
  9. Mar 1, 2014 at 2:25 AM
    95 taco
    95 taco Battle Born
    Ben, i don't know if you want this here but IMO it's good info to have. (i didn't see it up there, but if it's up there i'll pull it)
    [​IMG][/IMG]
    [​IMG][/IMG]
  10. Mar 1, 2014 at 8:21 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks Jake and Charlie! Great info. right there. I wanted this thread to be a one-stop-shop for anything related to torqueing parts correctly.
  11. Mar 1, 2014 at 10:41 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I need to redo the images and scale them down. The page load time is ridiculous, and I don't want PB to limit the bandwidth usage
    I will do some more work on it this weekend.
  12. Mar 1, 2014 at 10:45 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Good stuff! Thanks for all the hard work :)
  13. Mar 1, 2014 at 10:51 AM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Sub'd.
    good stuff Ben!
  14. Mar 1, 2014 at 11:11 AM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    Cool stuff. A single PDF version would be great also!
  15. Mar 1, 2014 at 11:22 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    :eek: damn man you got it all...:thumbsup: definitely saving this
  16. Mar 1, 2014 at 3:12 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Ya I agree. Pictures aren't loading for me.
    Here is a link to the 2nd gen manual.
    All of the torque specs. are listed in the "Service Specifications" section.
    HillJackJDS and stephenw13 like this.
  17. Mar 1, 2014 at 5:14 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    So handy having this now, I'll be tackling alot of front suspension work this upcoming week. Printed what I needed. Thank you very much Ben, +rep for you for your hard work!
  18. Mar 1, 2014 at 9:10 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks guys, need to fine tune it a little more.
    Word...I have the whole FSM in a PDF, but Toyota was cracking down and making sites pull them off. I just grabbed the most common specs/diagrams and organized them.
    Thanks for the feedback. I will be redoing the images, scaled down and stored on a better server. Hope it makes the page load faster. It will be nice to have all the specs in one place without sorting through the whole FSM.
  19. Mar 2, 2014 at 4:57 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    One of the best Post on TW. A mountain of info right there :thumbsup:
  20. Mar 2, 2014 at 8:38 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Alright, I scaled down the pics and added them to my TW album to help improve load times.
    I also added a downloadable .PDF (with linked Table of Contents) at the top of the OP.
    Please let me know if this improves the page loading, or if you spot any errors or misprints.
    :thumbsup::cheers:
    Salmonloaf and GT2000 like this.
