leaf spring pack 3"lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darektylka, Mar 5, 2014.
  1. Mar 5, 2014 at 6:40 PM
    darektylka
    darektylka [OP] Well-Known Member
    Darek
    Chicago
    Taco TRD Sport DCLB 4x4
    Which leaf spring packs are available that will give me 3-4" of lift?
  2. Mar 5, 2014 at 6:45 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Dakars , Expos
  3. Mar 8, 2014 at 12:22 PM
    darektylka
    Darek
    Chicago
    Here is my current setup on 2006 taco, 3" lift which is the way I bought the truck. My question is if I get the Dakars leaf packs will my rear sit higher then it currently does?
  4. Mar 8, 2014 at 2:20 PM
    darektylka
    Darek
    Chicago
    Bump anyone. ?
  5. Mar 8, 2014 at 2:23 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    Looks like u just have an add a leaf in your pack now. Just go with the allpro stds and you will get 3" of lift. If you want more than that you can go with the expos for 4" of lift.
  6. Mar 8, 2014 at 2:23 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    that's nowhere near a 3" lift, if anything it looks like an AAL
    you're only getting 1.5" or so
  7. Mar 8, 2014 at 5:02 PM
    darektylka
    Darek
    Chicago
    where is a good place to order the allpro stds leaf packs and also what else will i need for the install. Longer ubolts? Anything else?
    Thanks in advance
  8. Mar 9, 2014 at 6:24 AM
    BORNWILDGUY
    Rich
    Florida
  9. Mar 9, 2014 at 6:35 AM
    darektylka
    Darek
    Chicago
    as far as install all I would be needing are the leafs and the ubolt flip kit?
    Thanks again, just trying to make sure to get everything I need.
  10. Mar 9, 2014 at 6:38 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    All you really need are the leafs, new bushings and longer u-bolts to install new leafs. What rear shocks do you have? If you still have the stock ones, you may want to replace them as they probably aren't long enough and they will act as limit straps if you flex the suspension too far and you'll eventually destroy them.
  11. Mar 9, 2014 at 6:47 AM
    BORNWILDGUY
    Rich
    Florida
    The leafs come with the bushings in them so just the ubolts he needs.
  12. Mar 9, 2014 at 7:34 AM
    bjboucher
    Brad
    San Antonio, Texas
    Ahh, Dakars only come with one set and you need to make sure whoever you buy them from gets you the 2nd set.
  13. Mar 9, 2014 at 8:57 AM
    darektylka
    Darek
    Chicago
    I bought the truck the way it sits so not sure if rear shocks are stockers. There the yellow Bilsteins. Also just by looking at my truck, what size lift you guys think is currently on it?
  14. Mar 10, 2014 at 1:15 PM
    darektylka
    Darek
    Chicago
  15. Mar 10, 2014 at 1:33 PM
    darektylka
    Darek
    Chicago
    Ok.
    Also, is there any advantage doing the flip ubolts?
  16. Mar 10, 2014 at 1:42 PM
    darektylka
    Darek
    Chicago
    ok. Thanks for the help
  17. Mar 11, 2014 at 11:59 AM
    darektylka
    Darek
    Chicago
    For rear shocks, will the bilstein 5100s (0-2.5" lift) work with this leaf pack?
  18. Mar 11, 2014 at 12:22 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    No only the front 5100s are adjustable. Try some fox shocks with 9.5" of travel or you can get a set of 5100's made to your specification. Look at the Bilstein 5160's as well
  19. Mar 11, 2014 at 4:16 PM
    BORNWILDGUY
    Rich
    Florida
    If you want to use 5100's for the rear you need this p/n BE5-B110-T5 . These are the extended rear shocks.
  20. Mar 11, 2014 at 4:21 PM
    bjboucher
    Brad
    San Antonio, Texas
    If you get longer shocks you'll probably want bigger bump stops too to make sure you don't top out the shocks.
