Lift configuration help?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Supashawn, Apr 8, 2014.
Which lift
Poll closed May 8, 2014.
  1. 3" p 285 70 17
    3 vote(s)
    60.0%
  2. 2.5" LT 275 70 17
    2 vote(s)
    40.0%
  1. Apr 8, 2014 at 3:33 AM
    Supashawn
    Supashawn [OP] Well-Known Member
    Canada
    09 tacoma trd
    Here is what I have: 3" ome lift 885 coils, icon 1.5" 3 leaf progressive, LR uca's, 17x8 rims with 4.5" bs 0 offset. my tacoma will be 95% on road. Should I use the 1/2" spacers and get the full 3" and go with p 285 70 17 open country or terra grapplers? Or not use the 1/2 spacer and go with 2.5" and run maybe bfg At lt 275 70 17 or lt Goodyear wranglers mtr 275 70 17? Please help me decide
  2. Apr 8, 2014 at 12:10 PM
    Supashawn
    Canada
    09 tacoma trd
    Any opinions?
  3. Apr 9, 2014 at 1:44 PM
    Supashawn
    Canada
    09 tacoma trd
    help me out here guys
  4. Apr 9, 2014 at 1:52 PM
    DeSean Thick
    DeSean Thick TuRD TACO
    Sean
    Snowmass, CO
    05 TRD Sport Speedway Blue
    i say don't do the spacer lift, it will only degrade your ride quality and larger tires will degrade your mpg. the smaller tires won't look much different on the road, and since they would be light truck tires, they will be more durable and should last longer. I don't think the full 3" lift look would be noticeable enough to warrant worse handling and mpgs
  5. Apr 9, 2014 at 6:24 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Go 255s same diameter, no rub, better MPG, better on rock. Only downside is they are not floatation tires meaning if all you do is mud then ya get 285s
  6. Apr 16, 2014 at 10:15 AM
    Supashawn
    Canada
    09 tacoma trd
  7. Apr 30, 2014 at 8:04 PM
    xx-griz-xx
    xx-griz-xx Member
    Montana
    06 tacoma 4x4 DC LB
    3" lift
    My Tacoma initially had a 2.5" lift with 265-70-17 Mickey Thompson tires. There was some rubbing when backing. I then went with a 3.5" Walker Evans suspension system and went with 275-70-17 Hankook tires. The new suspension system and tires work great!
