load capacity on these tie-down points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JC0352, Apr 8, 2014.
  1. Apr 8, 2014 at 1:29 PM
    JC0352
    JC0352 [OP] Well-Known Member
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Anyone have any info on these? Is this hardware called a "footman loop"? Did Toyota just start putting these on the Tacoma?
    In reading through various threads in here about tie-down points/mods, I've never seen these mentioned. My truck has them, and I'll use them to haul my dirt bike, if they're made for something like that.
  2. Apr 8, 2014 at 1:32 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  3. Apr 8, 2014 at 1:34 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Did you buy your truck used? From what I know (and I could be wrong), those are not OEM and looks like someone added them. What's holding them in place... backplate or just a nut? Either way, I doubt anyone here will know what the load capacity is. Since you have a shortbed, you're better off using the link above.
  4. Apr 8, 2014 at 1:36 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2021 Honda Ridgeline Sport AWD
    They will work just fine for your dirt bike.
    They are factory equipment on the 2014 Tacoma.(and maybe the 2013 )
  5. Apr 8, 2014 at 1:38 PM
    SpruceTacoChris
    SpruceTacoChris Well-Known Member
    Las Vegas!
    13 DCSB TRD Offroad
    BAMF Sliders
    My 2013 came with those from the factory, dont know weight rating but I've used them quite a few times.
  6. Apr 8, 2014 at 1:40 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    They're factory. Started 2012+
    No idea on the load capacity though. OP, have you checked your manual?
  7. Apr 8, 2014 at 1:41 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Thank you! That's what I had figured. I actually come across that thread awhile ago.
    What do you think of the JP Metal Fab "Hook-Ups"? http://www.jpmetalfab.com/products.html
    If I was hauling two bikes, the angle of my tie-downs would seem to be better placed, with those. The rings on my Sierra were really low, so with two bikes you'd have to cinch them really tight to prevent any side-to-side rocking, since the straps were nearly vertical.
    This is a brand new truck I picked up from the dealership on Saturday. All of their Tacoma pictures have those in the bed.
  8. Apr 8, 2014 at 1:42 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Hahah, I should be asking myself the same question!:D
    I will look it over tonight.
  9. Apr 8, 2014 at 1:45 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    And I also have a least 2 D-rings from factory in my 2014, don't know if that was the case before
  10. Apr 8, 2014 at 1:48 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    I've cinched tie downs on 'em before with no problems. Definitely add some d-rings though.
  11. Apr 8, 2014 at 1:49 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Yeah, up though 2011 they just had the D rings. In 2012 they got rid of a cubby that was near the cab of the bed and installed those newer tie downs instead.
    Pre 2012 bed with cubby:
    http://www.dgmphotography.net/forumpost/April2011/DRingBed2.JPG
  12. Apr 8, 2014 at 1:51 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    Thanks for the reply. Do you have these, and did you use them for that purpose?
    To haul a dirt bike?
  13. Apr 8, 2014 at 1:58 PM
    XXXX
    sKiP
    05 Prius
    I like the idea, but nothing will beat a sturdy d-ring in the bed bolt. Those bolts literally hold the bed to the frame and are the best form of structural tie down you can get with these composite beds.
    All these guys telling you that those little U clamps in the bed are fine to put a bike in without knowing the rating of it or the weight of your bike should be ashamed of themselves.
    If your doing 80mph and rear end someone it's your wife and kids that will be eating the bike so what do they care? Seems everyone always thinks of best case and never worst case.
  14. Apr 8, 2014 at 2:02 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    X2.
    The cost to install a couple of D-rings in the bed is nothing compared to the cost to fight a lawsuit for gross negligence because you strapped your dirtbike to a dinky little tiedown that popped loose and let your dirtbike go through somebody's windshield on the highway.
  15. Apr 8, 2014 at 2:17 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    I can totally understand that. Thanks again.
    It no big deal. I had no plans to hit the road like that without doing my due diligence. Basically just wanted to hear about other peoples' experience since I'd never seen those loops in previous threads.
  16. Apr 8, 2014 at 6:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you will have no problems with those loops in the front... i trust them way more than the D ring tie downs in the back... both are just held to the bed through the fiberglass. nothing more.
    like stated those came on 2012+ trucks after they got rid of the cubby holes.
  17. Apr 8, 2014 at 11:25 PM
    JC0352
    Beau
    NW Louisiana
    '14 DC Off Road 4x4
    So you're saying these are bolted onto more than just the polymer bed?
  18. Apr 9, 2014 at 1:15 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I've easily put two bikes in the bed on these front mount points and haven't had any issues in a 1600 mile round trip.
  19. Apr 9, 2014 at 4:14 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x3..Not sure about the front footman loop specs but from what I recall, the bed D-rings are rated at about 440lbs each and the cleats 220lbs each...Go with the D-rings.
  20. Apr 9, 2014 at 5:37 AM
    XXXX
    sKiP
    05 Prius
    are you an engineer? or just some guy on the web guessing with other people's safety?
    So the loops in the composite bed are stronger than the bolts holding the bed to the frame? Please explain...............
    I think he is saying....
    This is very important... one of mine is seized and Ive tried breaker bars, every penitrant possible, heat, 6 different impact guns, and NADA. I have to cut and drill it out which is going to really suck.
