Please help with clutch reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charlie213, Apr 12, 2014.
  1. Apr 12, 2014 at 12:16 PM
    Charlie213
    Charlie213 [OP] Well-Known Member
    San Gabriel Valley, CA
    06 OR TRD 6speed DCSB 4X4
    I thought the clutch reservoir was supposed to be next to brake reservoir? Can someone please tell me where should it be or where the heck is it? Just want to make sure, in the picture on the right, that reservoir is for the brakes, correct?
  2. Apr 12, 2014 at 12:35 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Can't tell you on an 06 but on my 13 the clutch uses the master cylinder reservoir as a shared system. From the pict, I'd guess the 06 is the same.
  3. Apr 12, 2014 at 12:41 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    That black hose from the lower front corner of the brake reservoir feeds the clutch master cylinder. There is a baffle in the reservior to protect the braking system from fluid loss from a leak in the clutch system.
