Help: KC lites won't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZM9, Apr 23, 2014.
  1. Apr 23, 2014 at 11:10 PM
    AZM9
    AZM9 [OP] Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    I hooked up all the wires correctly and carefully. Installed a fuse tap and put it in the fog light slot in the fuse box by the battery. Then I placed a 15 amp fuse on the fuse tap. Then I put the fuses in the battery line and the supply line. The KC lites came on but the fogs would not. Then I shut it all off and checked the fuse tap again and the fuse is good but now the KC lites won't come on. If I remove the fuse tap and put the fog lp fuse in it is ok.
    Question, what is the best place to put the fuse tap in a 2009 trd sport.
  2. Apr 23, 2014 at 11:22 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    too much current being drawn from that tap. might want to add a relay or run a separate switch for the lights. this happened with my dtrl when i wired it with the arb indicators. too much draw would shut off a set of the dtrls. simple relay solves it. i run a separate fuse box so i dont mix it in with the first one.
  3. Apr 23, 2014 at 11:29 PM
    AZM9
    Jay
    Chandler, AZ
    Ok how would I connect the relay and what type of relay. Aren't the multi pronged.
  4. Apr 23, 2014 at 11:34 PM
    inesshell
    simple bosch relay
  5. Apr 23, 2014 at 11:36 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Wire it like so. If you want them to come on only when your fog lights are on, then run a wire from the fuse tap at the fog light slot to the number 86 prong on the relay.
  6. Apr 23, 2014 at 11:47 PM
    AZM9
    Jay
    Chandler, AZ
    Ok so I connect the fuse tap to 86, and I connect the supply line to 87, and I have to run a fuse line from the battery to 30. And of course a ground.
    This just seems redundant because there is already a line from the battery to the KC relay and so on.
    Just curious and confused. I don't do a lot of auto electrical.
  7. Apr 23, 2014 at 11:48 PM
    PcBuilder14
    Brent
    Southern New Mexico
    You've got it.
  8. Apr 23, 2014 at 11:50 PM
    AZM9
    Jay
    Chandler, AZ
    Is there a particular value relay to use.
  9. Apr 23, 2014 at 11:53 PM
    PcBuilder14
    Brent
    Southern New Mexico
  10. Apr 23, 2014 at 11:55 PM
    AZM9
    Jay
    Chandler, AZ
  11. Apr 24, 2014 at 11:27 PM
    AZM9
    Jay
    Chandler, AZ
    Just did the relay and besides all the parts, relay, fuse link to the battery, wire and connectors, and fuses, cost was another $37.00 and lights still won't come on. I will go through and check all the fuses tomorrow again but very frustrating.
  12. Apr 25, 2014 at 5:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    use a multimeter to try to find out where you're not getting current at.I'm not far from you, if you haven't got it figured out this weekend, let me know and maybe I can help.
  13. Apr 25, 2014 at 6:01 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Only one relay is used to power your new lights.
    Let's assume the relay you have matches the one in the picture above. Also that you are hooking them up so that they come on with your existing fog lights.
    #30 gets a fuse protected wire from the battery.
    #86 would tap into an existing powered fog light wire, also fuse protected. (Or from a powered fog light wire to another switch in the cab, then to #86. If you want to be able to just turn off the kc lights)
    #87 would go to power your new fog lights.
    #85 is ground.
    #86 is simply the signal voltage to close contacts #30 and #87 to power the light. #86 doesn't power anything but the relay.
  14. Apr 25, 2014 at 7:23 AM
    AZM9
    Jay
    Chandler, AZ
    I would love the help. Please. Pm me when and where at your convenience. Thanks.
  15. Apr 25, 2014 at 8:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  16. Apr 26, 2014 at 12:47 AM
    AZM9
    Jay
    Chandler, AZ
    Thanks again Chris. Wow it was great getting together and finally meeting you. I would love for us Az TW guys to get together. I know it already happens but I haven't had the chance.
    Can't wait to get the bracket from Bamf now to stiffen it all up and aim them right. Question, the lights are mounted upside down. Do I need to turn the lenses. Just curious as to why the lenses are marked "top"
  17. Apr 26, 2014 at 1:21 AM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    no, any direction is fine, just make sure the screws on the rings are at the bottom, like lowest point, not bottom of the light, they could make water collect if they are at the highest point and if seal is weak may leak, of course make sure the seal is good and sound around the lense. also since they are upside down, make SURE the seal where the metal sleeve goes into the light housing is also SEALED very GOOD! a single drop of water on a light that has been on for even a few minutes will kill it!
    air-flow is good to keep cool, water on the inside will make the bulb fry in a new york minute, or could short the poles on the light inside!
    you may have mentioned it and i missed it, but where did you mount them? always cool to see different setups :)
    cheers,
    disco
  18. Apr 26, 2014 at 7:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Some lenses are marked as they have holes at the bottom for draining moisture. Look for any little holes at the bottom. Otherwise, You shouldn't worry about the way its mounted.
  19. Apr 26, 2014 at 9:10 AM
    AZM9
    Jay
    Chandler, AZ
    Ok cool thanks Chris.
