Quick question about the carrier bearing on a 2014
Old 06-28-2014, 09:05 PM   #1
RAHTacoma [OP] RAHTacoma is offline
RAHTacoma is on a distinguished road
RAHTacoma's Avatar
Army: C co 3/10 Mountain DUSTOFF(ETS)
RAHTacoma's Tacoma Gallery
Why are the two mount holes elongated on the carrier bearing?
Ok, so after trial and 1/4 tank of gas I seemed to have solved the low speed vibration from a stop to 15 mph. With the elongated holes I started moving the bearing a tenth of a mm from full forward. At 1.9mm aft from full forward the vibration is gone at all speeds.
This is on a 1 1/2 block with a 3 degree shim in the rear and OME carrier drop. I am in the blind here cause I can't find any posts about the carrier except lowering it and replacing it.
Quick Help: Carrier Bearing Bracket on a 4WD? jaymac10 2nd Gen. Tacomas 2 04-15-2014 11:53 AM
Center (Carrier) Bearing Assembly Question wrat 1st Gen. Tacomas 0 02-21-2014 04:15 PM
Carrier bearing R+R question Jetman1979 2nd Gen. Tacomas 2 04-19-2013 04:16 PM
Carrier Bearing 180 Degree Flip Question IB Slingin 2nd Gen. Tacomas 0 11-02-2012 02:44 PM
Carrier bearing alignment question Beast Mode Suspension 3 10-15-2012 10:51 PM
