How-to: Build your own roll-up bed cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClayCrusher, Jul 10, 2014.
  1. Jul 10, 2014 at 8:57 AM
    ClayCrusher
    ClayCrusher [OP] Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
    I wanted to go ahead and get this thread started..
    The Problem: I have a headache rack and Toyota toolbox in the bed of my DCLB. I have a long trip coming up and I didn't want my gear to get wet as we drive up the East Coast.
    Other Problem: I haven't found a company who makes a bed cover that is the dimension I need (to incorporate the gap from the headache rack, AND the toolbox.
    Solution: Use marine grade canvas and snaps to cover the bed. I have ordered the canvas and will receive it today. I plan to stitch a 2" seam around the perimeter, then press in canvas snaps (screw in the mate to the bed rail).
    I plan to fully document this process--if it goes as smoothly as I expect, the total cost should be less than $50.
    Check back and see, I hope to have it finished by the weekend!:)
  2. Jul 10, 2014 at 9:00 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I will be looking for it, good luck.;)
  3. Jul 10, 2014 at 6:07 PM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Picked up the cover. I got 5'x8' of heavy duty marine canvas for $20.
    I measured my bed at 46"x57" of open space from toolbox to tailgate. I made a line at that dimension, then made another line 2" out for the fold.
    Next, I used my shears to cut the pattern.
    Then it was sewing time!
    Then after stiching the lines, it's ready for the buttons. Stay tuned tomorrow for the installation of rivets.
  4. Jul 10, 2014 at 9:15 PM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Sub'd
  5. Jul 11, 2014 at 5:55 AM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Got the snaps pressed in this morning. Hope to get the male attachments intot he bed caps this afternoon.
  6. Jul 11, 2014 at 6:53 AM
    owen06
    owen06 Well-Known Member
    Hinesville, GA
    16 DCSB 4x4 Red
    Sub'd as well...
  7. Jul 11, 2014 at 7:26 AM
    drewp
    drewp Well-Known Member
    south Jersey
    '14 Sport/DCLB
    I'm interested to see how this works too. I've had to "customize" an Extang roll up cover w/ snaps/rails to fit my long bed due to a custom rack set-up I've made getting in the way. Are you planning to try to add any bows to the system.....so water, etc. will run off the sides and not puddle?
  8. Jul 11, 2014 at 7:26 AM
    pikehk01
    pikehk01 Well-Known Member
    Stewart
    Mobile, AL
    '11 SR5 4x4
    sub'd, looks good so far
  9. Jul 11, 2014 at 7:41 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2
  10. Jul 11, 2014 at 8:51 AM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    So far, I haven't planned for any of that. The original idea was to have something that could easily snap on to protect against rain while in transit...I don't plan to keep this on full time.
    However, I may stick in fiberglass batons for some shape after I get it mounted up. Let me get the male snaps mounted to the bed rail; this evening, and we can go from there.
    I may even be interested in selling these if it sparks enough interest.
  11. Jul 11, 2014 at 10:42 AM
    Iggy
    Iggy Vagabond Outdoors
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
  12. Jul 11, 2014 at 12:17 PM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
  13. Jul 11, 2014 at 5:10 PM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    And the snaps are in! 3CDD3DAC-41D2-49A1-A17E-36975BA7BA06_a836306ab1c508630884f02f67ff95c066454518.jpg
  14. Jul 11, 2014 at 5:11 PM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    The corner snaps have not been attached yet because I ran out of snaps...it'll get pulled tight and I'll add some batons for shape.
  15. Jul 11, 2014 at 9:48 PM
    Kfletch
    Kfletch Well-Known Member
    Kyle
    Rockwall, TX
    2016 Tundra Crewmax TSS Off-road
    Looks good so far!!
  16. Jul 11, 2014 at 9:55 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  17. Jul 11, 2014 at 10:11 PM
    Ian.S
    Ian.S Well-Known Member
    Ian
    Harlingen, TX
    2016 TRD OR DC Infernooooo
    It's the little things.
    Sub'd!!
  18. Jul 13, 2014 at 11:14 AM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Ordered a baton stock to put in for some shape. Should have it tomorrow! It looks great, works well, and keeps the sun off the stuff in the back too!
  19. Jul 13, 2014 at 1:06 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Looks great so far, specialy for the price.
    Wear did you learn how to sew? I can sew by hand, but haven't mastered the sewing machine. I always break the needle. :eek:
  20. Jul 13, 2014 at 1:35 PM
    ClayCrusher
    Corpus Christi, TX
    13 DCLB MGM
    Thanks! Sewing machines are pretty easy to use...especially when they're industrial. I work in a sailing shop, so one of our riggers showed me how to use it, then I just taught myself.
