Brake Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hartford, Jul 27, 2014.
  1. Jul 27, 2014 at 9:38 AM
    Hartford
    Hartford [OP] Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I have one damaged front rotor on the truck, my fault. I need to replace it today. Can I get away with doing just the one side or should both be changed? Ill add a pic of the rotor later
  2. Jul 27, 2014 at 9:42 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    You CAN replace one-have the other turned if needed. Otherwise your braking might be offset. Just a recommendation.
  3. Jul 27, 2014 at 9:43 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    That should be alright, but you should also change your pads on the new rotor.
  4. Jul 27, 2014 at 9:44 AM
    Hartford
    Maine
    2011 Acc Cab 5spd
    OK, Since one is newer and thicker it may grab more than the rotor on the other side?. If it does that will cause pull under braking.
    New pads. This job went from simple to more involved and way longer.
  5. Jul 27, 2014 at 9:47 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    thickness should not be the problem-it is the WEAR on the rotor and pads.
    Thickness is compensated in the hydraulics.
  6. Jul 27, 2014 at 9:48 AM
    Hartford
    Maine
    2011 Acc Cab 5spd
    Alright, makes sense. Guess I'll see how this goes.
  7. Jul 27, 2014 at 10:05 AM
    Evenflow
    Evenflow Well-Known Member
    Jason
    San Diego, CA
    06' DCSB 4x4
    Yes
    Nah, new pads literally take 5 minutes to install and you have to remove the caliper anyway to replace your rotor.
  8. Jul 27, 2014 at 11:31 AM
    Hartford
    Maine
    2011 Acc Cab 5spd
    It's not so much the pads. It that it started out as pooping off the passenger side wheel so I could access the block drain for the coolant. I guess a couple lug nuts were over tight because some the studs got fucked taking the nuts off. Then work calls and says I need to fly to oklahoma tomorrow. Not that bad, but I have to swing by the office and pick up a few things. Office is 4.5 to 5 hour drive. Now I just want to get this shit done. Inexperience and hurrying caused me to screw up the rotor. So now I have to do the 45 minute trip to the auto store again.
    Crap day all around Pouring rain right now just got back with the rotor. eat some lunch and maybe the rain will let up.
  9. Jul 27, 2014 at 5:41 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I'm a bit confused. Is it the studs that are damaged? Not the rotor? How is the rotor damaged? The damaged studs are going to have to be pressed out of the wheel hub. Or, did you damage the rotor removing the studs?
    Anyhow, to answer your original question. You can replace only one rotor if you have to. And if the wear on the pads is minimal and you need to get going, I would use the same ones. Braking may feel spongy while the pads adjust the new rotors, but there is no danger in re-using them. The proper thing to do is eventually replace all new brake pads.
  10. Jul 28, 2014 at 2:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you are replacing the rotor due to the Lug Nut Studs, then you are doing it wrong. The Lug Nut Studs are pressed into the hub behind the rotor. They are not part of the rotor at all.
