Slight clunk when starting and stopping
Old 08-06-2014, 03:38 PM   #1
Joe in Louisville
joe54tacoma is on a distinguished road
joe54tacoma's Avatar
joe54tacoma's Tacoma Gallery
As the tile stated I'm getting a Slight clunk when starting and stopping.
The carrier bearing seems like it has a lot of movement in it. Just using my hands I can move it back and forth 1/8" min.
How much slop should this thing have?
Seems way to much.
Only 38,000 miles
Old 08-06-2014, 03:48 PM   #3
toyu4ea is on a distinguished road
toyu4ea's Avatar
toyu4ea's Tacoma Gallery
I have a 2012 DCSB Baja. I used to get a small clunk when coming close to a dead stop. Took it to the dealer. They ended up replacing my drive/propeller shaft under a TSB. It eliminated the clunking. Unfortunately, I don't have the TSB info, nor did they give me the documentation on the service applied. Check with your dealer on a TSB for the driveshaft.
Old 08-06-2014, 03:52 PM   #4
Joe in Louisville
Originally Posted by kyleTRDtaco12 View Post
the weak Toyota leaf springs are the culprit!! had the same thing happening on my 2012, look into 4x innovations traction bar, it stopped my clunk.
I have the towing package so it has the heaver leafs
Old 08-06-2014, 03:53 PM   #5
resident Apple Pie Monster
Justus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shed
Justus's Avatar
Justus's Tacoma Gallery
tow package does nothing to the leafpack.
U either have the same weak 3 leaf pack or 4 leaf TSB/newer sport pack as everyone without a tow package.
an AAL will help with the axle wrap
Old 08-06-2014, 03:53 PM   #6
Sold it, dont miss it yet.
lj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shedlj973gm is one of the sharper tools in the shed
lj973gm's Avatar
lj973gm's Tacoma Gallery
Was this the sale guy who told you this???
Old 08-06-2014, 04:02 PM   #8
Joe in Louisville
Im heading out to first check the ubolt torque
Old 08-06-2014, 04:18 PM   #10
Joe in Louisville
Well the u-bolts were not even close to 73 lbs of torque.
Had to tightened each one at least 1 1/2 turns.
We'll see what difference it made with a test drive.
Old 08-06-2014, 04:24 PM   #11
Joe in Louisville
I also tow a 4,000 lb camper.
Would there be something better than the traction bar that's better for towing?
Old 08-06-2014, 04:25 PM   #12
Red
Large's Tacoma Gallery
Coming from the front or back?
Old 08-06-2014, 04:26 PM   #13
Joe in Louisville
From what I saw the TSB was for two wheel drive models.
Old 08-06-2014, 04:28 PM   #14
Joe in Louisville
Back - It almost feels as though the brakes are grabbing and releasing
Old 08-06-2014, 04:29 PM   #15
Justus's Avatar
add a leaf
or a full heavy duty leaf pack from OME dakar, or all pro
Old 08-06-2014, 08:18 PM   #16
NM Lance is on a distinguished road
NM Lance's Tacoma Gallery
I had a similar problem... The splines that mate the front portion to the rear portion of the drive shaft were getting sloppy. I had let a friend use my truck for the weekend, come to find out he is rough with a standard transmission! It produced a distinctive *ping* sound when starting and stopping. I packed some grease on the splines and put it back together just to see if I had pin-pointed the problem. The sound went away! I ended up replacing the front portion of the driveshaft (it came with the carrier bearing). Problem solved... I must warn you, if you buy this from the Toyota dealership, you are going to get soaked (~$400+).
Old 09-06-2014, 05:00 AM   #17
nujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud ofnujerzidevil has much to be proud of
nujerzidevil's Tacoma Gallery
I would assume your noise is the slip joint as NM LANCE said. I have been greasing the splines with motorcraft Teflon grease. The grease seems to wear out just before every oil change. Since I'm out of warranty, I think Im going to install a jerk fitting to make servicing much easier.
Bump/Jerk Feeling When Starting, Stopping El Guapo 2nd Gen. Tacomas 16 09-05-2014 10:34 AM
Driveline Clunk When Stopping/Starting gergg 2nd Gen. Tacomas 11 07-29-2013 07:20 PM
Pop when stopping or starting... Jaren1512 1st Gen. Tacomas 9 11-04-2012 11:25 AM
clunk when stopping... tammikm 2nd Gen. Tacomas 18 09-06-2011 10:41 AM
starting/stopping usb ports HerNameIsLucy Technical Chat 8 01-22-2009 03:02 PM
