Lift With Stock Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pmcewen, Aug 14, 2014.
  1. Aug 14, 2014 at 7:17 AM
    pmcewen
    pmcewen [OP] Member
    Patrick
    Chicago
    I am going to install a 2.5 inch lift on my truck this weekend. The question is can I use the stock wheels and tires after the lift? They are TRD Sport Wheels. I will be getting new wheels and tires in a few weeks. I would like to be able to run the stock wheels and tires in the winter as well.
  2. Aug 14, 2014 at 7:22 AM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Should be fine. I went with a little bigger tire. 265/75/R16.
  3. Aug 14, 2014 at 7:23 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    I installed my OME kit last weekend and I'm getting my tires installed this coming weekend. As long as you go get it aligned after the lift is installed... stock rims and tires should do you fine until you get your bigger ones installed.
    I cannot speak to the Winter portion of the question, as I live in FL and we do not get actual cold weather.
  4. Aug 14, 2014 at 7:48 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I run 275/70/17's on my stock Sport alloys , you'll be fine running the stockers but if they are the Dunlops they suck in snow
  5. Aug 14, 2014 at 8:40 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    dunlops suck everywhere except dry pavement
  6. Aug 14, 2014 at 6:46 PM
    pmcewen
    pmcewen [OP] Member
    Patrick
    Chicago
    I agree that the stock tire suck! I am getting Toyo Open country MT 275/65/18. Might upgrade to better winter tires using the stock wheels. With the new rims they are 18X9, should they be -12 offset or 0 offset?. Keep in mind the lift is going to be 5100's in the front using stock coils.
  7. Aug 14, 2014 at 11:35 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    i did "3in" actually more like 2.75in said and done coils and AAL, i am now 100% back to oem wheels and tires, bought some off of a spoiled kid who had his daddy buy a new tacoma and he lifted it like the next day and could give a flip about the oem's.
    as it is, mine rides better on the road, bumps are smooth, off-road up and down travel is nice on drops and the bounce back minimal and smooth and i think looks better, no complaints!
    just do not use spacers in the front, use good quality coils, HIGHLY suggest weight over-rated coils, and use quality AAL and NO BLOCKS in the back!
    you be a happy taco-camper with that height and oem size tires :)
  8. Aug 15, 2014 at 4:48 AM
    The Field Archer
    The Field Archer Well-Known Member
    North New Jersey
    15 Tacoma Double Cab 4x4 TRD Sport
    Mine sits 2.75" over stock, stock wheels and 285/70R16 and no rubbing at all!
  9. Aug 15, 2014 at 5:59 AM
    Eduskator
    Eduskator Well-Known Member
    La Belle Province
    '14 Tacoma
    Wow nice looking Tacoma!!
    I was planning on plastidip my OEM wheels as well but didn't want them to look ''cheap'', it looks great!
    The painted grill is clean also (compared to the chrome one...)
  10. Aug 15, 2014 at 6:09 AM
    NosiBaLasi
    NosiBaLasi RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    What brand are those tire? Are they loud on freeway driving?
  11. Aug 15, 2014 at 6:37 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Lifting your truck will only allow you to put some 32'' or 33'' with minor trimming :) (Your lift kit should mention what's the maximum tire size), but there's no minimum tire size.
    Make sure to buy hub-centric aftermarket wheels if you have a recent model...
  12. Aug 15, 2014 at 11:12 AM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    I can read "NITTO" on the side of the tire... :confused:
  13. Aug 21, 2014 at 6:55 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica
    Icon, AllPro, Total Chaos, ARB, BAMF, Relentless, SCS, Cooper, Leer,
    Nitto Trail Grapplers
  14. Oct 28, 2014 at 6:50 PM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    did you use wheel spacers or just straight bolt up cause i found a good price on some toyo open country mt 285 70 17
