Lift Rec for 05 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by groads82, Sep 18, 2014.
  1. Sep 18, 2014 at 3:16 PM
    groads82
    groads82 [OP] New Member
    Greg
    Cincinnati Ohio
    SR5 V6
    I need a recommendation for size and manufacturer of lift for my 05 Taco. I have 265/70R16 Michelins. I was told the largest lift I can put on without having to change the tires or modify the rear diff lock is 2.25 front and 1 inch rear. I'm just looking for something simple that makes the truck look a little more aggressive. Would like to keep price below $500.
  2. Sep 18, 2014 at 3:28 PM
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    For your budget I would probably say 5100 Billies all round, stock coils, add-a-leaf in the rear or get the TSB leaf done. Do some research on here, then some more, and then a little bit more until you're nearly fed up with the idea. Once you've got it all plotted out then you can probably run it by the knowledgeable folks on here and they'll give you the green light or tell you what you'd be better off with.
    Threads like these are pretty common, so most people people don't bother looking at them or just tell you to do your homework. Good luck!
  3. Sep 18, 2014 at 4:32 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  4. Sep 18, 2014 at 4:44 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
  5. Sep 18, 2014 at 4:45 PM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    ImageUploadedByTapatalk1411083841.144506.jpg 3 inch spacer in the front, 1.5 in the back. All from Toyteclifts.com sitting on 265/70r16 Goodyear Wrangler Armortracs (they suck soooo bad)
  6. Sep 18, 2014 at 4:45 PM
    yota243
    E.J.
    north Alabama
    That kit is just over $500 but it comes with eibach coils i think,
