| Register | Search For Products | Site Information | Glossary | Calendar | Search | Today's Posts | Mark Forums Read |
#1 |
05 transmission question
Last weekend my son and I bought a 2005 Tacoma 4x4. During the test drive, I noticed, when 'punching' the gas, the transmission seemed to rev high, but we did not accelerate quickly - it was like the back wheels spun - but I do not think this happened. I'd like to know if anyone is aware of transmission problems (auto) like this. I'm not sure it's a problem at this time, as my son is off at school and has the truck. I will test this again during Christmas holidays. Just inquiring to see if anyone else has felt this type of problem.
thanks, Scott |
#2 |
The one you are not!
How fast were you going and what gear (best estimate) were you in? The 2005+ Tacoma auto transmission is designed to simulate a manual trans shift pattern.
#3 | |
Member Dismemberer
__________________
"My honour is more valuable than my commission". ![]()
#4 |
Good thought on the LSD! Perhaps. I was going very slow, less than 20, stepped on the gas, there was immediate torque which could be felt, then the higher rev's, and noticed the torque reduced.
How does the LSD work, in general... if it detects the wheels spinning, doe the transmission dis-enguage? Thanks sc |
#5 | |
Member Dismemberer
__________________
#6 |
it's all about me
i don't seem to have that issue i also have an '05
__________________
Ldytaco05
#7 |
Best way to find out is to go to a Dealler and ask to test one new . If you see the same behavior??? then you have your answer. This truck does have the first gear litlle bit shorth. But once you start to move , dont be surprise to find your self cruissing at 32-35 Mph in fifth gear. Good luck with your decission
| Display Modes | |
| Dumb question Transmission cooler / AT fluid check 08 Tacoma? – | JJK | 2nd Gen. Tacomas | 7 | 11-24-2007 07:30 AM |
| 6 speed transmission | BrianPK | 1st Gen. Tacomas | 2 | 11-21-2007 08:35 PM |
| AT Transmission Filter Kit | agapedisciple | Technical Chat | 3 | 09-18-2007 02:10 PM |
| 05 and up Transmission servicing | viprbomber | Technical Chat | 4 | 07-07-2007 07:48 PM |
| Transmission Cooler Options | missingthenw2001 | 1st Gen. Tacomas | 3 | 04-21-2007 02:08 PM |
