Multiple attachments to battery terminals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Sep 23, 2014.
  1. Sep 23, 2014 at 12:02 PM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    How do you run extra lines for accessories to the stock battery? Are there special adapters to the terminals that I can use instead of getting a new battery with marine terminals or hacking the OEM connectors?
  2. Sep 23, 2014 at 12:07 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
  3. Sep 23, 2014 at 4:11 PM
    kai38`
    kai38` Well-Known Member
  4. Sep 23, 2014 at 4:16 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
  5. Sep 23, 2014 at 4:22 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
  6. Sep 23, 2014 at 4:23 PM
    kai38`
    Yes, sorry always put a in line fuse to any hot wire you install
    "This requires a breaker in front of it. Don't just run it straight to the battery"
  7. Sep 23, 2014 at 4:53 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
  8. Sep 23, 2014 at 4:57 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    Make you some cables
  9. Sep 23, 2014 at 4:58 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    And the before pic.
  10. Sep 23, 2014 at 5:24 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Got it. Thanks. I just went to look at the OEM positive connector again, and it does have a 12mm or so stud that I can tap into just like your setup. Does the ground from your fuse box go back to the battery negative or to the frame? Or it doesn't matter?
  11. Sep 23, 2014 at 5:52 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    Yup, to the battery negative from the fuse block.
  12. Sep 24, 2014 at 5:44 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You can also use a plain distribution block, depending on what your acessories/needs are. Just keep in mind the warnings on fuse locations for the block and for the accessories
  13. Oct 31, 2014 at 9:16 PM
    LIKURMoMsTaco2
    LIKURMoMsTaco2 Ebola Free 53 years
    The Player
    Not your mom's taco
    Who is the resident ELECTrical genius on the thread?
    I have many questions...
