#21 | |
There's an evil monkey in my truck
Just like Johnson8537 did.
__________________
#22 |
people like me on the internet
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Jefferson
ah that wire gets power ONLY when lock is hit.. got it.
#23 |
Correct... (One of these days I will get out a relay and play with it so it ungrounds the unit when keyed 12+ is turned on making this mod not beep when the key is on and you lock the door.)
__________________
![]() 2006 TRD SPORT LB v6 4x4 Auto RevTek 3" Lift w/block spacer and rear TSB-MotoMetal 955B 17x9 w/32"Tires-Billet Grill-Tinted Windows- Access Lorado Tonneau-Weston Nerf Bars-Wet Okoles-Pioneer DEH P700BT-AFE intake filter |
#24 |
Adrenaline Addict
i think i'm going to do this...
question - should i try the passenger side? that way it will only beep when i lock the doors with the remote OR from the passenger side front door, correct? or would it beep only when locking doors w/the remote then? thanks!
__________________
![]() Obsessed is a word the lazy use to describe the dedicated. Click below and fix your cracked mud flap. http://www.tacomaworld.com/forum/2nd...-flap-fix.html |
#25 |
TW Newbie
I guess anything is possible.
#26 | |
My Set up: Beeps anytime the Keyfob is locked or you use the Lock button inside the cab. (If would work the same if you tied into the lock wire in the passenger door. Unless I am not understanding what you are wanting to do?)
__________________
#27 |
Saving up for Long Travel
YEah Paul did it. Lock/Unlock Chirp
__________________
![]() My Build: http://www.tacomaworld.com/forum/builds/37540-lentsnhs-build.html (UPDATED)
#28 | ||
It would be different with the unlock signal from the fob. The fob requires two pushes to unlock the passenger doors. So the first push, it wouldn't beep (the passenger lock isn't getting any power). The second push of the fob would activate the beeper, since the passenger door lock receives power to unlock. The door panel switch would always beep, since it unlocks all the doors with one push.
__________________
#29 |
Ah, all i want is the Lock sound
#30 | |
CORRECT!! (If you added a second Beeper with a different tone for unlock you could add it to the passenger side or drivers side. Depending if you wanted a single or double beep for unlock.) If I remember right the wires are under the kick panel on the passenger side (high -next to the door.).
__________________
#31 |
My 08 Taco isn't wired the same way at the fuse block behind the coin tray, I didn't see the Blue/Pink wire on any connector. I did find it in the bundle coming out from the top of the kick panel. Same colors as in the pic. Same wire, works the same way, but isn't found in the same place. Great mod, cheap, and it works!
#32 |
can "do work son"
great write up. too bad i dont have automatic locks.
#33 |
I bought a "high Intensity Slow Pulsing" pizo buzzer.. you think that's fine? I didnt realize how many different types there are (and i have no clue what the difference is
#34 |
If it makes noise and your doors still lock I would say its OK.
#35 | |
__________________
#36 |
[]D [] []D
Any sound clips with the piezo you used?
I really wanted the camry piezo sound but I could never get it to work even after I got one from the dealer. I remember reading something like the Toyota piezo's are emitting a frequency, almost like a speaker, and the driver is not built into the piezo.
__________________
07-X-Runner |
#37 |
#38 |
don't hate me cause i'm a prerunner
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Paul
johnson, have you tried it with a relay yet. I tried today and couldn't get it to work.
__________________
My satoshi write up. LOCK/UNLOCK Chirp for DTRL and Alternating turn signal modders My build My Smurf build |
#39 |
[]D [] []D
Got the right connections on the relay?
__________________
07-X-Runner |
#40 | |
__________________
| Thread Tools | Search this Thread |
| Display Modes | |
| Group buy: Pop N Lock Tailgate Lock (Ends April 08, 2009) | DanGer | Group Buys | 1220 | 11-17-2009 07:23 AM |
| Caution: Installation of Pop n Lock Powered Tailgate Lock | 1BADTACOMA | 2nd Gen. Tacomas | 4 | 04-18-2009 10:30 AM |
| Pop & Lock tail gate lock...best price? | Motorshooter | 2nd Gen. Tacomas | 4 | 11-07-2008 06:51 PM |
| Cheap TPMS Light How-To/DIY | EquinsuOcha | Wheels & Tires | 16 | 04-03-2008 08:03 PM |
| alarm beep for lock/unlock | bra | 2nd Gen. Tacomas | 40 | 03-02-2008 03:30 PM |
