PLEASE HELP With Roof Light Bar Whistle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheNatural, Dec 22, 2014.
  1. Dec 23, 2014 at 8:00 PM
    #21
    Jacob78
    Jacob78 Well-Known Member
    Jacob
    San Diego, CA
    2013 tacoma d-cab prerunner
    Too much of a gap between the windshield and bar. I have never had any whistle even in pretty strong winds in Baja. 50" radius bar and TRAC Performance bolt in brackets. 2ac7040eba64e2e5b8e8abd8db2c9357_8b7f1b9cd1001f532837c6bd37bf6b705a4f3bb2.jpg503bfa3524982a5030663da90bc83d79_abaca260837cd42bbbd0e6767f376fefd169ed40.jpg
  2. Mar 16, 2019 at 7:35 PM
    #22
    chubbyscorpion
    chubbyscorpion Member
    Charlie
    Oregon coast
    3rd Gen TRD OFF ROAD Cement
    Have the same problem with mine. Just did a test run with tape over the screws in the front and that stopped the whistle completely. Now I just need to figure out a more permanent solution other than tape.
  3. Jan 14, 2020 at 8:47 PM
    #23
    dkg
    dkg Active Member
    I have the MCM Fab mounts also and a dual row 50” curved rough country light bar. It came with 5 of those rubber spacer finger things. It was previously on my 98 Grand Cherokee and had no noise. Sold the Jeep and now on my 2012 Tacoma and I have horrible whistle starting around 5 mph and just gets louder the faster I go until I hit about 60-65 mph then it turns into wind vibration turbulence.
    I tried taping over all the fins, tried taping the holes on the mounts, tried adjusting the angle of the light. Nothing works. Gonna try taping the screw holes and the bottom slit before the cooling fins, those are the only other two solutions I’ve read about that I haven’t tried. Considering buying a wind diffuser on Amazon, see link below. Anyone tried this? If I can’t solve it I’m taking it off.
    Light Bar Noise Reducer 50" Wind Diffuser https://www.amazon.com/dp/B01AT5IMDC/ref=cm_sw_r_cp_api_i_ojPhEb789TYCG
  4. Jan 14, 2020 at 9:14 PM
    #24
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Damn $90???
  5. Jan 15, 2020 at 6:59 AM
    #25
    MenloGa
    MenloGa Member
    North Ga
    super white SR5 4x4
    3inch OME 886 coils stock UCAs.
    Buddy of mine in college just wrapped some rope around his and it stopped the whistle. Looked janky but it got the job done.
  6. Jan 15, 2020 at 2:41 PM
    #26
    dkg
    dkg Active Member
    Good news...kind of. I figured out the whistle on my light. It is coming from the screws on the face of the light bar. Covered them with some blue painters tape and the whistle went away. However, the vibration is still pretty bad starting at about 65 mph, so I still need a solution for that. I also need to figure out how to cover up the screws without having tape all over my light bar.
  7. Jan 15, 2020 at 3:32 PM
    #27
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Silicone? And if u need access to the screws the silicone should peel off pretty easily
    or black tape of some sort
  8. Jan 16, 2020 at 7:20 AM
    #28
    dkg
    dkg Active Member
    Well, I gave up! I tried mocking up a cardboard wind diffuser similar to that $90 Zroadz one that they sell, but it didn't help the vibration issue. Looked sweet with the bar on, but the turbulence/roof vibration at highway speeds was too annoying. Might do some more research to see if anyone has a combination of mounts & light bars that tend to work without creating issue. This seems to be a problem across all makes and models of light bars, surprised manufacturers haven't designed something that deals with this problem.IMG_2155.jpg
  9. Jan 16, 2020 at 7:45 AM
    #29
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I haven't read to see if you've tried this before but you might want to replace the bushings with thicker bushings if the bar is buffeting the in the wind. Something like https://www.lowes.com/search?searchTerm=rubber+bushing might work. If you can shake your bar with your hand or if it's not sitting tight in the mounts might be the cause of your roof vibration. I couldn't say for sure since I don't have a full radius bar like yours.
    -J
  10. Jan 16, 2020 at 7:58 AM
    #30
    dkg
    dkg Active Member
    Its tight. There is no give, no flex when I grab the mounts. I can shake the whole truck by grabbing the mount.
  11. Jan 16, 2020 at 8:57 AM
    #31
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I have these mounts from eBay:
    and a 42” curved light bar from Amazon. I don’t have any whistling or vibration. I do have wind noise similar to having a lumber rack.
    i put door edge trim on the bottom two heat diffusers it didn’t help with wind noise.
    #31
  12. Jan 16, 2020 at 9:02 AM
    #32
    dkg
    dkg Active Member
    Yeah, I think the wind noise issue is cause of the flat front. Not much can be done about that unless you get one of those round diffusers. Saw a review on youtube and the guys said it was as silent as before.
    https://aeroxindustries.com/collections/light-bar-cover
    #32
  13. Jan 16, 2020 at 10:15 AM
    #33
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Also I didn’t see any of those for curved bars, only straight right?
  14. Jan 16, 2020 at 10:26 AM
    #34
    dkg
    dkg Active Member
    Correct. I only see them for straight bars. There is another company I also found called Mictunning (https://mictuning.com/) that has the curved diffuser built in, but they only have straight bars. Seems like I need to start a new lighting company and make the first silent vibration and whistle free light bar.
    Alexely999[QUOTED] likes this.
  15. Jan 16, 2020 at 10:35 AM
    #35
    dkg
    dkg Active Member
    Alexely999 likes this.
  16. Jan 16, 2020 at 10:35 AM
    #36
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    So is it the actual sheet metal of the roof that is making the noise? You might be able to mask the noise with a roof rack to break up the ... laminar (?) air flow over the roof.
    -J
  17. Jan 16, 2020 at 10:40 AM
    #37
    dkg
    dkg Active Member
    Not sure what is causing it exactly, but I don't really want a roof rack nor do I have $500+ to drop on one.
  18. Jan 16, 2020 at 10:42 AM
    #38
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    my light bar is mounted to the oem rack.
    (No whistle/vibs, just wind noise)
  19. Jan 16, 2020 at 10:43 AM
    #39
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  20. Jan 16, 2020 at 10:52 AM
    #40
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    It would be interesting to see what the bar looks like on a truck in a wind tunnel with a smoke funnel. Just to see how the wind reacts across the different parts of the bar. I wonder if one of those hood mounted bug/rock deflectors would lift the wind up high enough to pass over the light bar at speed?
    -J
