Spare Tire Removal Tools
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mizzouborn, Jan 16, 2015.
  1. Jan 16, 2015 at 9:26 AM
    Mizzouborn
    Mizzouborn [OP] Well-Known Member
    Tampa, FL
    06 Tacoma PreRunner
    Thorley Headers Dual Exhaust Flowmaster 40s Bilstein Shocks/Struts K&N Air Filter
    Originally Posted by theduckbutter [​IMG]
    I thought I won. but i didnt win. when going to the dealer to get the tool that turns and lowers the spare tire, they quoted me $130. they said its a three piece unit. my chin hit the floor and i suddenly resented owning a toyota.
    Thank you for your support.
    Rick
    OK I initially posted this in another thread (see comment above I replied to) but upon reflection I thought it may need it's own thread, not that it's a huge deal, unless you're stuck somewhere and can't get your spare tire down.
    For all of you that will have to replace your spare tire lowering tool thingy here's what I did. And BTW, all of you will replace yours eventually.
    I can't recall the socket size (deep socket not regular) cause I'm not at home but a deep socket will fit PERFECTLY (even a little tight) over the piece that actually lowers the tire (the piece with the hook shaped end & the socket doesn't go over the hook:)). Then add 32" of 3/8" extensions to a ratchet, breaker bar (I use this) or speed handle and BOOM you're there for A TON LESS (about 1/3 of the cost depending on the manufacturer) and you'll have a MUCH better tool. And all of this will fit into the vinyl case that your spare tire lowering tool thingy came in from Toyota. No more cheap extensions made out of pot metal, no more little screws that don't work or hex shaped thingys that "round" out.
  2. Jan 16, 2015 at 9:33 AM
    whiting1977
    whiting1977 Well-Known Member
    Steve
    Sacramento CA
    2014 SR5 PreRunner
    What am I missing? Why will I eventually have to replace my spare tire lowering tool?
    JimboAnz and PvilleJohn like this.
  3. Jan 16, 2015 at 9:40 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    +1
  4. Jan 16, 2015 at 9:47 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  5. Jan 16, 2015 at 9:50 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    This sounds like a good story
    Manfred likes this.
  6. Jan 16, 2015 at 10:10 AM
    Mizzouborn
    Tampa, FL
    06 Tacoma PreRunner
    Because it's beyond cheaply made. I have to take my spare down only a couple of times a year (just to add air to the spare) and the extension ends are rounded off, the little screws to hold the extensions together get stripped out and don't work very well and extensions bend easier than you think.
    If you don't think you need to replace yours, don't.
    Stryker420 likes this.
  7. Jan 16, 2015 at 10:20 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    +3 or 4 can't tell
    DGXR likes this.
  8. Jan 16, 2015 at 10:22 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    There's time I won't get back.
    bax, IronPeak and Bluegrass Taco like this.
  9. Jan 16, 2015 at 10:51 AM
    Mizzouborn
    Tampa, FL
    06 Tacoma PreRunner
    Here's some irony; it took you more "time" to post than just read.
  10. Jan 16, 2015 at 11:06 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    srsly ? my spare tire drop tool is gonna be working now and 15 years from now
    I don't get it
    my 4runner pole which is the same thing has dropped that spare 22 times, still works like day 1. I just don't get it
  11. Jan 16, 2015 at 11:08 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    can't you just flip it over so the valve is accessible. That is what I have have done on all my previous trucks. I have not yet had to air up my spare on the 2013. Also, I carry a compressor so I can just add the air I need when and if I have to use the spare.
    whatstcp, Stryker420, Tocamo and 2 others like this.
  12. Jan 16, 2015 at 11:10 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Valve is prone to damage off road.
  13. Jan 16, 2015 at 11:15 AM
    Pigpen
    Pigpen My truck is never clean
    Northwest Montana
    2012 AC Manual 4.0 4x4 Base Model
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    OP took the time to post without even having the socket size... I guess it couldn't wait. We've all been warned.
    Really though, OP, just edit in the socket size and I'm sure someone could potentially benefit from this.
    Marc70 and Stryker420 like this.
  14. Jan 16, 2015 at 11:50 AM
    prerunner 06
    prerunner 06 Well-Known Member
    David
    Springfield OH
    06 Prerunner SR5 DCSB
    Mine's been sitting under there for 9 years. Have to try it tonight when I have it up on the rack for an earl change and let ya know.
  15. Jan 16, 2015 at 12:29 PM
    vtdog
    vtdog Well-Known Member
    NH
    You should check that spare very carefully. After 9 years its 3 years past (50%) the "replace" age for tires. I know they can last longer (at least they did when they were in the trunk), but now the tire manufacturers recommend replacement after 6 years regardless of use.
    whatstcp likes this.
  16. May 15, 2018 at 8:59 AM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    Thanks for posting this. Posts like this are why I love this site. Same thing happened to me, my Taco has no spare tire tools and I aint gonna pay zee stealership.
  17. May 15, 2018 at 9:06 AM
    Clearwater Bill
    Clearwater Bill Never answer an anonymous letter
    Billy
    Largo Florida
    '13 5 lug AC w/convenience package
    A few OE parts from fancy trucks
    I agree that HF or garage sales could source the bits needed for this solution.
    And it's a good one.
    Assuming:
    1) your OE tool is MIA or
    2) your OE tool is broken and
    3) you can't find an OE tool cheap on eBay, CL or your local wrecker
    There's nothing wrong with my tool, and I doubt I'll ever break or lose my tool.
    And I do have my tire flipped for ease of keeping aired up. But I don't do off roading that puts it at risk either.
    06Tacooo and whatstcp like this.
  18. May 15, 2018 at 9:11 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Bring a 6 pack to a local fabrication shop during lunchtime and you'll have one.
  19. May 15, 2018 at 9:14 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  20. May 15, 2018 at 9:17 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    -1
    OP is spot on. After a few uses the tool sucks. I think newer ones have slightly different design without the hex thumbscrews that suck.
    Manfred likes this.
