How much psi should I run
Old 01-23-2015, 01:39 AM   #1
Arkansas30 [OP] Arkansas30 is offline
Arkansas30 will become famous soon enough
Arkansas30's Avatar
Arkansas30's Tacoma Gallery
How much psi is everyone running in there 285s.
Old 01-23-2015, 03:47 AM   #3
DSMJRV is on a distinguished road
DSMJRV's Avatar
DSMJRV's Tacoma Gallery
is this a real question? look at your tires and they will tell you..
too low will eat mpg's and too high will do the same but give you a rough ride...
Old 01-23-2015, 04:26 AM   #4
Gearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shed
Gearheadesw's Avatar
Gearheadesw's Tacoma Gallery
All your going to find there is max inflation and load carrying capability. Chaulk method will get you a nice street pressure.
Old 01-23-2015, 07:32 AM   #5
catattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud ofcatattacksdog has much to be proud of
catattacksdog's Avatar
catattacksdog's Tacoma Gallery
Google.
Old 01-23-2015, 07:45 AM   #6
JAGER91374 is just really niceJAGER91374 is just really niceJAGER91374 is just really niceJAGER91374 is just really nice
JAGER91374's Tacoma Gallery
It really depends on the type of tire. Is it P rated or an LT tire. IF it'san LT tire which load rating.
My tires for instance. When I ran the P rate P265/70/16's I ran 35psi frontand 32psi rear. Gave me a rice ride, as decent of handling as I could expectfrom an AT tire and over 60K miles before they needed to be replaced.
My current setup is LT265/75/16 C load Duratrax's and I'm running 30psifront and 26psi rear. I've done the chalk test and I contact patch across thetire. If I run more than 26 in the rear I have substantially less traction inthe rear as my contact patch is only about 2 inches wide and I'm riding on thecenter of the tire.
I don't recognize those tires so I can't tell what you have by the picture.
Old 01-23-2015, 08:27 AM   #7
MPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant futureMPLS TACO has a brilliant future
MPLS TACO's Tacoma Gallery
35 PSI and rotate every 5,000
Old 01-23-2015, 09:32 AM   #8
Arkansas30's Avatar
They are mt tire.
Old 01-23-2015, 09:43 AM   #9
pudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shedpudge151 is one of the sharper tools in the shed
pudge151's Avatar
pudge151's Tacoma Gallery
number on tires is just a max pressure. best to start at car manufacturer recommend and then do the chaulk test from there
Old 01-23-2015, 09:47 AM   #10
Clearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shedClearwater Bill is one of the sharper tools in the shed
Clearwater Bill's Tacoma Gallery
is this a real question? look at your tires and they will tell you.....
Is this a real answer?
Old 01-23-2015, 09:50 AM   #11
chris4x4's Avatar
chris4x4's Tacoma Gallery
Bingo!
Old 01-23-2015, 10:06 AM   #12
1stTruck is on a distinguished road
1stTruck's Avatar
1stTruck's Tacoma Gallery
Great reply, I have the same tire/size as ur running and I was inflated to 35 all round. I'm going to deflat to 30 / 26... Thanks
Old 01-23-2015, 05:21 PM   #13
Thank you. Keep in mind that my truck has a shell on it full time but the bed is mostly empty. I f you carry stuff then 26 might not be enough.
Old 01-23-2015, 05:26 PM   #14
Vaginas are rad.
Boone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shedBoone is one of the sharper tools in the shed
Boone's Avatar
Boone's Tacoma Gallery
Ermagherd.
Chalk test and be done if you aren't sure. Every tire will vary slightly per vehicle. I find 32 psi works well with my KM2's for what I do with my truck.
What psi should i run? TacoTRD420 Wheels & Tires 130 01-11-2015 02:26 PM
What PSI should i run my new tires at? Toy Yoda Wheels & Tires 4 07-18-2013 09:41 PM
what psi do you run. JONNY TACO 2nd Gen. Tacomas 4 02-27-2012 06:18 PM
What psi should i run Madams Wheels & Tires 27 08-25-2011 06:15 PM
What PSI do you run? Mudbug Wheels & Tires 5 07-26-2007 07:25 PM
