How to adjust Fox 2.5 no resi
Old 02-14-2015, 03:38 PM   #1
SexyTaco [OP] SexyTaco is offline
SexyTaco is a splendid one to beholdSexyTaco is a splendid one to beholdSexyTaco is a splendid one to beholdSexyTaco is a splendid one to beholdSexyTaco is a splendid one to beholdSexyTaco is a splendid one to beholdSexyTaco is a splendid one to behold
SexyTaco's Avatar
SexyTaco's Tacoma Gallery
Maybe I got bad coilovers or something, but mine only have one adjustment collar for the coil and all the others I've been seeing have the one on top too. Anyway, this collar has little holes and I can't use a spanner wrench on them. They have an Allen screw in the side I'm assuming you use to loosen the collar to move it. After squirting a little WD-40on it I tried loosening it a little and sticking an Allen wrench in the hole to turn it but it started to crush the sides of the holes a little so I stopped. I don't want to loosen it any more because I don't want to die. Do I need a special wrench or just need to be more intelligent about my rigging?
Old 02-14-2015, 03:53 PM   #2
deeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the sheddeeez is one of the sharper tools in the shed
deeez's Avatar
Army:
deeez's Tacoma Gallery
You should post some pictures of what your collar looks like.
Old 02-14-2015, 04:14 PM   #3
SexyTaco's Avatar
I'm not really sure how to post pictures to the post but maybe this worked
Old 02-14-2015, 04:19 PM   #4
All I Do Is Nguyen
gym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shedgym_jamz is one of the sharper tools in the shed
gym_jamz's Avatar
gym_jamz's Tacoma Gallery
Yeap, you're missing your locknut. Anyways, did you jack up the truck before adjusting it?
Old 02-14-2015, 04:22 PM   #5
trexTRD is on a distinguished road
trexTRD's Avatar
trexTRD's Tacoma Gallery
Thats how its suppose to look, you need a spanner wrench to adjust it
Old 02-14-2015, 04:24 PM   #6
trexTRD's Avatar
you loosen up the allen wrench screw, that what "locks" the collar from it moving anywhere after your done adjusting, loosing up this screw wont do anything but allow you to turn the collar with the spanner wrench(hard to do) but you will get it done.
Old 02-14-2015, 04:25 PM   #7
4runner Troll
SCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shedSCRunner12 is one of the sharper tools in the shed
SCRunner12's Avatar
SCRunner12's Tacoma Gallery
That is how they are now. The old versions had the dual rings, but now there is only one. Did you loosen the allen nut on the left side of the picture first? That needs to be loose then use either an spanner wrench or some people have used screw drivers or punches to adjust. Once done, retighten that nut and you're good to go.
Old 02-14-2015, 04:26 PM   #8
SexyTaco's Avatar
Well I haven't even got them on yet. I was going to try even give the drivers side just a little more preload to compensate for the weight and try and swing the allen bolt around so in a few weeks when they are broken in I can adjust them without completely taking them out. I stuck the bottom part in a vice with a t shirt wrapped around it so I could actually work with it so it's completely extended.
Old 02-14-2015, 04:28 PM   #9
SexyTaco's Avatar
So how far can I run out the allen screw? and will just a regular spanner wrench work with the holes?
Old 02-14-2015, 04:28 PM   #10
SexyTaco's Avatar
i ordered then from down south motosports and when i called they said i didn't need a spanner wrench
Old 02-14-2015, 04:30 PM   #11
Thegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shedThegenerik1 is one of the sharper tools in the shed
Thegenerik1's Tacoma Gallery
Locknut?
Old 02-14-2015, 04:36 PM   #12
4runner Troll
SCRunner12's Avatar
You need a Fox spanner wrench as they are all different, but I'd get a screwdriver or something similar and try it.
In regards to the nut, just back it out enough that it feels a bit loose. Don't take it all the way out.
Old 02-14-2015, 04:40 PM   #13
trexTRD's Avatar
you can take the allen screw out and it wont do anything, its just a screw that basically locks it in place when your done doing the adjustment.
Old 02-14-2015, 05:15 PM   #14
deeez's Avatar
Army:
Bullaculla uses a drill bit that is the exact size fit for those spanner wrench holes and turns the collar with that. It'll be hard to spin it if it's not installed on your truck.
Old 02-14-2015, 05:34 PM   #15
bluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shedbluewaters182 is one of the sharper tools in the shed
bluewaters182's Avatar
Firefighter: Firefighter/Paramedic
bluewaters182's Tacoma Gallery
Take a look at the picture, it is not a set screw. The allen screw on his might not be a good idea to take all the way out. Those threads are pretty shallow and if that collar expands too much, wouldn't the pressure from the spring blow that thing apart. Maybe I'm wrong, but my Icons have a set screw but it does not hold the ring collar together.
OP, make sure someone who truly knows about this helps you first. That spring is under a lot of pressure. Make sure you know for sure before you back that screw out. Good luck.
Old 02-14-2015, 05:38 PM   #16
txmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shedtxmxer is one of the sharper tools in the shed
txmxer's Tacoma Gallery
You can go to a hardware store and get a weird looking tool almost like a t handle or a long screwdriver but with a hex head on it, thats what I use
Old 02-14-2015, 06:17 PM   #17
SexyTaco's Avatar
I did use drill bits to try at first but i was afraid I'd break them but ill try again. so what i need to do is just slightly loosen the allen bolt and while the shock is on my truck,( with it decompressed)turn the collar to fit? Or can i just completely take it out? It looked to me like it could explode. TrexTRd, do you know for sure i can back it all the way out?
Old 02-14-2015, 06:22 PM   #18
SexyTaco's Avatar
Also, sorry it took so long to get back. I cooked steaks for my girlfriend. Dropped one walking inside from the grill and then spilled have a thing of salad dressing in the floor. been a good valentines.
Old 02-14-2015, 06:26 PM   #19
Señor Member
PSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shedPSU Taco85 is one of the sharper tools in the shed
PSU Taco85's Avatar
PSU Taco85's Tacoma Gallery
DON"T take the screw all the way out, loosen it just a few turns so the collar is free to turn. If you loosen it all the way you risk the collar jumping threads and getting cross threaded let alone what would happen if the collar let go completly. As far as adjusting, I used a metal punch with a 3' piece of cheater pipe, makes turning it easy as pie.
Old 02-14-2015, 07:04 PM   #20
SexyTaco's Avatar
Alright! Thanks guys. so put it on my truck and loosen the screw a few turns and then set it right? i really don't like the collar design. the other is a lot safer.
2.5 Fox Coilovers with remote resi Rappy60guy 2nd Gen Tacoma Marketplace 8 01-21-2015 08:49 PM
Fox 2.0 Coilover adjust Greenneck77 Suspension 1 05-31-2014 09:57 AM
Fox 2.5 coilover Resi adjust to 3in lift FBGW01 1st Gen. Tacomas 12 06-07-2012 12:47 AM
Feeler: Fox 2.0 w/ Resi hudhawk 2nd Gen Tacoma Marketplace 15 03-31-2012 11:09 AM
fox 2.0 remote resi bulhas Suspension 0 03-02-2012 08:05 PM
