Truxedo low pro tonneau cover issue
Discussion in 'Tonneau Covers, Caps and Shells' started by ToyFXR88, Feb 20, 2015.
  1. Feb 20, 2015 at 11:18 AM
    ToyFXR88
    ToyFXR88 [OP] Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    Anyone have one of these? I just installed one yesterday and there's a gap above the top of the tailgate between it and the cover. Upon further inspection, my bed rail caps sit higher than my tailgate cap. This is how I bought the truck. Are other tailgate caps available? Am I stuck with this gap? I can't adjust the tonneau cover any further to close the gap.
    Truck is a 2014 double cab long box.
    I attached a pic. There's a rubber flap on the underside on the cover where the tailgate is supposed to make contact with it
  2. Feb 20, 2015 at 12:20 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Can the rails be adjusted, can you lower both sides?
  3. Feb 20, 2015 at 3:23 PM
    ToyFXR88
    WI
    Nope. The tonneau is as low as it will go. My bed rail caps are taller than the tailgate so I'm not sure if there's a different tailgate cap available from Toyota or if anyone else has encountered this and had a solution
  4. Feb 20, 2015 at 3:25 PM
    mikevee
    mikevee Well-Known Member
    Socal
    14 prerunner trd offroad
    I think you need a car wash :eek:
  5. Feb 20, 2015 at 6:25 PM
    ToyFXR88
    WI
    I don't think that will help solve my problem.
    Also, given the sub zero ambient air temperatures we've been having for most of the week plus the snow we got today and the snow we will get tomorrow, no point in washing it right now. Besides, maybe the frame will rust prematurely and then I'll get a new one.
  6. Feb 20, 2015 at 6:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    The "low-profile" tonneau cover designs typically don't seal as well in this area. A "conventional" tonneau that sits completely on the rail caps typically would have a beefier weatherstrip over the tailgate as well.
    You can buy beefier weatherstripping and stick them either on top of the tailgate or under the tonneau, effectively backing up the rubber flap. You will need to add weatherstripping around the sides and bottom of the tailgate anyway if you want to keep water out completely.
    Google "tailgate seal" and you'll come up with all kinds of designs and vendors. For example: http://www.pickupspecialties.com/trailseal.htm
  7. Feb 20, 2015 at 6:58 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I have one of these covers and mine sits futher back that flap goes over the back of the tailgate...You said its been cold maybe the cover is not stretched out due to the cold... There is a tension adjuster on the cover..
  8. Feb 20, 2015 at 7:17 PM
    ToyFXR88
    WI
    I installed the cover at work which was a comfortable 65-70 degrees. The instructions said to install the center hole of the rearward brackets (3 per bed rail) 11.25" from the tailgate, which I did.
    I just thought it was interesting to discover the tailgate cap sat below the bed rails, so I didn't know if there were different options for tailgate caps to make it level with the bed rails. I'll check out the weather stripping. I don't want it completely water tight, I just didn't like the gap between the cover and tailgate.
  9. Feb 20, 2015 at 7:17 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Did you close the cover then the tailgate?
  10. Feb 20, 2015 at 7:26 PM
    ToyFXR88
    WI
    Yes. Either way there is a gap
  11. Feb 20, 2015 at 7:38 PM
    303tacoma
    Rebecca
    I just looked at mine it sits closer to the tailgate than the pics you have.. The flap goes almost to the outside edge of the tailgate...and there is a height difference between my side rail and tailgate.....Ill try and snap a pic in the morning if u would like so you can see the difference
  12. Feb 20, 2015 at 7:48 PM
    ToyFXR88
    WI
    I can snap a pic in the morning. If the height difference is normal than im not too worried. I don't expect it to be 100% water tight, I was just puzzled by the height difference. My past truck, a silverado, wasn't like this.
    That would be great.
  13. Feb 20, 2015 at 8:28 PM
    KenLyns
    Belly of the Beast
  14. Feb 21, 2015 at 6:45 AM
    ToyFXR88
    WI
    Here is the front edge of the cover, by the cab.
  15. Feb 21, 2015 at 8:15 AM
    303tacoma
    Rebecca
    Pics from last night
  16. Feb 21, 2015 at 8:17 AM
    303tacoma
    Rebecca
    I cant figure out how to post more than 1 pic at a time I have a couple daylight I just took if you want to see those.. Look in my gallery.. At least you can get an idea where the cover is setting on the backside
  17. Feb 22, 2015 at 3:10 PM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    Still look like you're closing it wrong. You lock the cover in place. Then close the tailgate.
    Take a picture of the rail butt up to the tailgate when closed. It's suppose to touch and that's part of the seal. From the last pic you posted, I can kind of see the seal is not push back against the tailgate at all.
  18. Feb 22, 2015 at 3:31 PM
    303tacoma
    Rebecca
    I like the seal outside the bed of the truck that way when there is rain or snow it doesnt drain into my bed...My brother inlaw said the same thing you did.... My pics were to show OP how my flap is closer to the backend than his pi:)
  19. Feb 22, 2015 at 3:33 PM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I have that cover as well. My flap actually goes inside the tailgate. Water will occasionally dribble in at the corners, during really heavy rains, but that's it. I'll grab a picture in a bit.
  20. Feb 22, 2015 at 4:15 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    It looks like you can slide it back slightly. I have one on my Tundra and it stays pretty dry. I also keep the rubber flap inside of the tailgate. You can also contact TruXedo. They have good customer service.
