When to install a supercharger.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QueTaco, Mar 16, 2015.
  1. Mar 16, 2015 at 7:14 PM
    #21
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    *sigh*
    No. I don't. Please re-read the thread and try to follow along.
  2. Mar 16, 2015 at 7:19 PM
    #22
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    This is what I was saying. Aside from testing it to make sure it works like it is supposed to, there is no break in.
    Maybe I am looking into my oil sample a bit. My point is, if it were MY truck I would wait until the first oil change before putting a SC on it... but I'd be too tempted to "break in" the SC :D. 5000 miles seem like it's enough of a "break in". My truck, as noted, was still just shy of a perfect oil sample at 9625 miles, with only one oil change. I used Mobil 1 0W30 for my change.
  3. Mar 16, 2015 at 7:21 PM
    #23
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    You may find this informative. I live in SoCal where it almost never falls below freezing (where I live, anyway) so I use 0W30.
    http://www.bobistheoilguy.com/motor-oil-101/
  4. Mar 16, 2015 at 7:29 PM
    #24
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  5. Mar 16, 2015 at 7:59 PM
    #25
    ThomasMore66
    ThomasMore66 We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    Supercharged 2013 TRD Offroad 4wd
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    This topic brings out the hostility.
  6. Mar 16, 2015 at 8:35 PM
    #26
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    There seems to be a "break in" built into the SC ECU flash. The so called "learning" period. I can only assume this is done for times when a SC is installed on a new or near new engine.
    And I also believe the rings are set during a dyno run by the factory either before the engine is installed or more than likely when it rolls off the final assembly and onto a dyno where they can 1. seat the rings and 2. look at the dyno and ECU readings to determine if the engine meets SAE certification and if there's any codes thrown.
  7. Mar 16, 2015 at 8:38 PM
    #27
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Hopefully nobody thought I was being hostile. A little sarcastic, sure... not hostile.
    Trying to give the OP good, useful info.
  8. Mar 16, 2015 at 9:06 PM
    #28
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    interesting read. I might just start using 0-30syn as well currently running the standard 10w-30 syn... but this makes alotta sense!
  9. Mar 16, 2015 at 9:15 PM
    #29
    SYTFUxMBRProjects
    SYTFUxMBRProjects Instagram: b00sted_b18c5
    Mark
    San Leandro
    2006 Super White Tacoma TRD-Sport Supercharged
    Had mine installed @ 150k miles a little less than a year ago. The truck has over 168k miles on it now, and still runs strong.
  10. Mar 16, 2015 at 9:18 PM
    #30
    double dee
    double dee Well-Known Member
    Arizona
    Best time to do it would have been when negotiation the price of vehicle to include the supercharger cost into the negotiation as well
  11. Mar 17, 2015 at 5:54 AM
    #31
    QueTaco
    QueTaco [OP] Member
    John
    Canada
    2015 DCSB Trail Teams, SC, 6 speed
    Supercharger
    K guys.
    Booked my install this morning.
    All of you leaned on my side of the argument so making up my mind was easy.
    So I now know that ASAP is NOW.....
    Thanks all......
  12. Mar 17, 2015 at 6:10 AM
    #32
    QueTaco
    QueTaco [OP] Member
    John
    Canada
    Supercharger
    Mine was quoted at $5.9K all incl.
  13. Mar 17, 2015 at 6:46 AM
    #33
    Surfer88
    Surfer88 I love my Tacoma!
    Michael
    Southern California
    '15 Dbl Cab TRD sport
    Pioneer head unit, front and rear speakers, sub box with two ten inch subs behind the rear seat, amplifier under driver seat, remote subwoofer gain control placed inside dashboard storage area, parking brake bypass switch for watching movies in the road placed behind the dashboard at the bottom near the steering column, window tinting throughout.
    @ QueTaco - Please post some pictures after the work is all done!
    I've toyed with the idea of an SC mod since I bought my first Tacoma back in June of 2000, but I'm admittedly ignorant to most of the benefits of having one, plus I was in college and broke. :)
    If someone would enlighten me as to the benefits of adding an SC to my current Tacoma I would be grateful!
  14. Mar 17, 2015 at 7:25 AM
    #34
    Surfer88
    Michael
    Southern California
    Okay - I wasn't that ignorant. I suppose I was looking for more specific benefits in regards to, yes, performance, but also regarding longevity of the engine itself, wear and tear over time, etc. Would a super charger benefit those who do more off road driving and towing, or would it be good for everyday commuters, such as myself, who may take camping and beach trips a couple times a year? Also - are there drawbacks to having this mod done? Gas mileage decreasing? Wear and tear over time? Etc.
    Thanks!!
  15. Mar 17, 2015 at 8:42 AM
    #35
    Surfer88
    Michael
    Southern California
    Good things to know. Thanks!
