No-cut ABS kill switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAUL747, Mar 22, 2015.
  1. Mar 22, 2015 at 3:43 PM
    MAUL747
    MAUL747 [OP] Well-Known Member
    Michael
    Hartsville, SC
    14 DCSB SR5 4x4 6SPEED
    Husky liner floor mats, Scanguage II with blendmount, Panavise-ram mount for Garmin, 27% on fronts, Crystalline70 on windshield
    I wanted to do the abs kill switch mod to my truck for on the fly control of the traction babysitters, which this truck is loaded with, but like many others I didn't want to cut the factory harness. I plan on trading my tacoma in for a new gen in a few years so I wanted to avoid cutting the harness and the fear of messin up a brand new $30k truck so I came up with this idea.
    I pretty much just put a switch between the fuse socket and fuse for the abs. I used a short piece of wire with a female connector on one end and a male in the other to connect into the fuse socket on one side and to one terminal on the fuse. Then I ran another longer wire from the second post in the fuse socket thru the fire wall and to a switch then back out to the second post in the fuse which completed the circuit. When the switch is turned on anyways.
    The only down fall of this way is that you have to cycle the key for the dash lights to go off after you turn the abs off and back on. I haven't tested if the abs is functional after turning it off and back on without cycling the key In theory it should work. the lights stay on because the ECU hasnt ran a check to see that the abs is back on(or at least I think that's why they stay on). If I'm right or not I haven't had a chance to try it yet and I have been wrong a time or two, according to my wife anyways.
    Now I know I'm horrible at explaining the process of how I did something so if my directions take you in circles let me know and I'll try to explain better.
    EDIT: your abs will not reset and become active again until you cycle the key
  2. Mar 22, 2015 at 8:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  3. Mar 23, 2015 at 4:07 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    This is exactly how mine is on my current truck and on my last one. Except I used a Toyota rocker/fog light switch. I've put about 70k miles on this setup with zero issues.
  4. Mar 23, 2015 at 4:28 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Sizing wire for a 12 volt direct current system is different than alternating current. Wire size for 50 amps in an AC system would be a #8 (depending on insulation).
    50 amp DC is 16 gauge at 3'.
  5. Mar 23, 2015 at 4:35 AM
    Large
    Large Red
    Do you have a chart? I've been looking for a wire rating chart for DC.
  6. Mar 23, 2015 at 4:44 AM
    MAUL747
    Michael
    Hartsville, SC
    we all have opinions on what is the "proper" way and like i said this is a option for people that dont want to cut into their factory harness. and its a 30amp fuse and 14ga wire so im sure itll be fine. if not then you can say i told you so while im standing next my to burnt up truck.
  7. Mar 23, 2015 at 4:46 AM
    MAUL747
    Michael
    Hartsville, SC
    If thats right them im in the clear, its 30 amps and 14ga wire. thanks
  8. Mar 23, 2015 at 4:49 AM
    moondeath
    Pa, Gardners
    Here's the best I could get with my phone. It's a screen shot.
  9. Mar 23, 2015 at 5:03 AM
    Large
    Large Red
    I would say this is a good guide but this might not work with your state's code nor automotive DC circuitry.
  10. Mar 23, 2015 at 5:18 AM
    moondeath
    Pa, Gardners
    This graph is not for 120/240 residential or commercial industrial 277/480 electrical. As I stated, it's for 12 volt dc.
  11. Mar 23, 2015 at 8:14 AM
    nd4spdbh
    SoCal
    thats right on the cusp with 30 amps at 14awg for ~10 ft.
    Either way that switch is a radio shack switch, probably cant handle more than an 5 amps.
  12. Mar 23, 2015 at 10:08 AM
    MAUL747
    Michael
    Hartsville, SC
    Your disapproval has been dually noted. I feel safe doing it the way i did it.
  13. Sep 15, 2018 at 6:12 PM
    Tacomoto23
    Tacomoto23 IG: Tacoma_Carey23
    Carey
    Torrance,CA
    11’ TRD Prerunner / 21’ TRD 4x4
    Bump, anyone try this method with success since this thread was made?
