Best front spring/shock set-up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12tinker, Apr 9, 2015.
  1. Apr 9, 2015 at 7:46 AM
    12tinker
    12tinker [OP] Well-Known Member
    dan
    MA
    08 Off Road
    engine swap (stuck valve @260K)
    Hey all,
    Finally looking to replace my road weary '08 TRD 4WD front yellow Bilstiens.
    Looking for just a normal, not too stiff ride without any height mod
    Would like to buy an assembled strut and wondering if I would loose anything on the TRD thing giving up my OEM springs
    Do I need gas bilstiens? I did the rear OEM....
    Wondering how other Taco owners did...
    Thanks!
  2. Apr 9, 2015 at 8:52 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
  3. Apr 9, 2015 at 8:56 AM
    12tinker
    dan
    MA
    08 Off Road
    Gregnan,
    5100?
    Why would I need to adjust ride height?
    Looking for an assembled gas strut with the proper spring
    Advantages of OEM TRD spring?
  4. Apr 9, 2015 at 9:00 AM
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    The 5100 has a setting for stock height.
    Depending on how many miles you have, you don't need to change your springs.
  5. Apr 9, 2015 at 10:40 AM
    12tinker
    dan
    MA
    08 Off Road
    same thought, but was looking for an decent assembled unit as not to mess with a spring compressor or unbolting the LCA.
    Wondered what the TRD bilie was giving me? Always had a somewhat harsh ride, street potholes or off road.
  6. Apr 9, 2015 at 11:23 AM
    12tinker
    dan
    MA
    08 Off Road
    discovered searching this forum that the OEM TRD progressive/Billie set-up is a harsh ride vs the non TRD 4WD and lots are being sold or given away in favor of 5100 and linear springs set at stock height.
    May just go with pre-assembled Monroe standard, since I'm just into a daily rider/ boat puller/ firewood hauler :)
    2008 is my 3rd Taco @ 140K.
    250K on my last two, Lovin it!
    just wheel bearing and idler so far at 130K
    plugs, filters, brakes, rotors, tires and oil of course....
    re-soldered that compass/temp resistor 3 times now, ha!
    never had any other mechanic touch it, which, helps!
    some good ones out there, but not the one at the dealer that left the oil 2 qts. low!
  7. Apr 10, 2015 at 11:27 AM
    Gregman
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    You don't need a spring compressor or unbolting the LCA (just loosen them) to install 5100's at stock height, with the stock springs. Have a look:
    https://www.youtube.com/watch?v=vkVLBOnAifc
    https://www.youtube.com/watch?v=5E6u7dC7EHg
  8. Apr 10, 2015 at 1:07 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    stock OR springs will be fine set at 0 or .85. i have mine set to 1.75 and is still an improvement over worn out stock for sure. the progressive coils get harsh when they are over compressed. most abandoned the OR coils so they can get 2.5" with the linear coils. if u were gonna lift any i would recomend the eibach, my buddy put those on his 4th gen 4runner and set them to .85 and he wound up with a really smooth riding ~2.5" lift
