Spark Plug change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clownbear69, Apr 18, 2015.
  1. Apr 18, 2015 at 5:59 PM
    clownbear69
    clownbear69 [OP] Active Member
    Joseph
    Gallup NM
    2012 Toyota Tacoma TRD
    Do we have a sticky for spark plug change?
    Didn't find one. While I don't need to now Id like to see how its done
  2. Apr 20, 2015 at 5:15 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    not as hard as you think.
  3. Apr 20, 2015 at 6:21 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    that's not what she said :D
  4. Apr 20, 2015 at 6:32 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    piece of cake and if you use factory plugs (ngk or densos)
    some here may say use anti-seize....I recommend NOPE
    the plug manufacturers denso and NGK both say do NOT use anything on the threads
    they already are made to go into the head and not gall or wreck anything, and if you
    a) use a torque wrench to install them
    b) change them every 30,000
    they won't seize
    the possible problems with anti-seize is
    - electrical contact is via the threads, you install goop in there, you can compromise the spark or ignition system trying to overpower the resistance
    - heat issues. spark plugs and head is designed for no thread coatings whatsoever, if you add anti-seize it may insulate and hold heat where is was not designed to, compromising the plug or the threads
    I know someone is gonna chime in here and say 'well I use anti-seize and have never had an issue '
    really ? so what is the measured difference in heat propagation and electrical conductivity with and without
    anti-seize...and why is that better than what the plug manufacturers recommend (no anti-seize) ?
    it probably doesn't matter a whole lot...but why risk blowing up a coil ?
  5. Apr 20, 2015 at 7:29 PM
    clownbear69
    Joseph
    Gallup NM
    hmm interesting on the no anti seize im probably going NGK
    ETA: im at 43000 and not the first owner so... I guess ill have to change them....
  6. Apr 21, 2015 at 4:37 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    If you get oem plugs they will already have a small amount of anti seize on them. Just don't over tighten. 30 min job.
  7. Apr 21, 2015 at 5:02 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    This is on my spring cleaning list of things to do. Havent changed plugs since I bought the truck....50k miles ago.
  8. Apr 21, 2015 at 5:39 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    umm densos are what are shipped to dealers
    and...no they don't have anything on them whatsoever
    except a plastic shipping tube to protect the electrode
  9. Apr 21, 2015 at 5:59 AM
    clownbear69
    Joseph
    Gallup NM
    That's why im doing a whole bunch of stuff to my truck (while the weather is nice)
    Besides the plugs I know for sure another oil change (at the most late summer) and Im finally going to rid of the anti theft lug nuts and while I do that mind as well rotate the tires and in about a month change the pads and turn the rotors.
  10. Apr 21, 2015 at 6:07 AM
    VTaco08
    VTaco08 Well-Known Member
    Vermont
    08 Tacoma 4X4
    OME Complete lift kit, Dakar leaf pack, LR UCA's, G2 1.25 wheel spacers, Pro Comp 17/8 5001, derrped badges.
    Use an extension that pivots on the socket wrench....made my life so much easier when changing plugs!
  11. Apr 21, 2015 at 6:16 AM
    clownbear69
    Joseph
    Gallup NM
    not sure what your talking about could you show an example if you don't mind
  12. Apr 21, 2015 at 6:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's basically an extension with a u-joint in the middle. Makes is so the ratchet can be at a different angle, making it easier to remove and install the plugs.
    Also, I'd use neversieze, just a very small amount on each plug despite 127's compelling argument against it. I like the piece of mind knowing the plugs will come out next time and I'm not buying that the thin layer of graphite between the plug and the heat is going to cause a coil to fail. In a spec-built race engine, maybe but not in a daily driver engine. Just don't go nuts with it, a small dab will do ya.
  13. Apr 21, 2015 at 6:33 AM
    VTaco08
    Vermont
    08 Tacoma 4X4
    I used a short extension then attached one of these and it worked great for the drivers side gaggle F$&* you will encounter.
  14. Apr 21, 2015 at 6:38 AM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Mine did, I assure you. I'm not going to argue because I've changed out the plugs on my truck 3 times now. It's not a lot but it's there.
  15. Apr 21, 2015 at 8:01 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    ok mine did not. toyota box with denso inside. dry thread.
