4 ton or 6 ton jack stands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliforniaTaco, May 14, 2009.
  1. May 14, 2009 at 10:40 AM
    CaliforniaTaco
    CaliforniaTaco [OP] Well-Known Member
    Can I get away with using 4 ton jack stands to install a readylift or should I get 6 ton stands?
  2. May 14, 2009 at 10:46 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Considering the truck doesn't weight nearly 4 tons, you'd be fine... ....
    Plus that rating is per jack, and if you're using multiple jacks you're distributing the weight across them.
  3. May 14, 2009 at 10:51 AM
    CaliforniaTaco
    awesome thanks, knew i was over thinking it
  4. Nov 14, 2009 at 7:09 PM
    phil_c
    phil_c Member
    me
    02 tacoma dual cab 4x4 v6 auto
    Napa had a real good deal on 6 ton stands awhile back so I picked up four. This is one case where overkill can't hurt, hey it's my ass under there! Whatever don't get the units that are stamped metal with pins that go through holes to adjust for height,if they still make them.
  5. Nov 14, 2009 at 7:36 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    You can never have to much support when lifting a truck..................
  6. Nov 14, 2009 at 7:46 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    go big or go home!! usually the higher rated ones are also taller, so that helps too!
  7. Nov 15, 2009 at 5:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get the ones that lift the HIGHEST.
    If they're both the same height - can't go wrong with either.
    If it were me, and the price difference was minimal - I'd get the 6 ton.
  8. Nov 15, 2009 at 5:53 AM
    PropJet
    PropJet Well-Known Member
    KS
    '09 DC TRD Off Road
    ToyTec Ultimate Lift Kit, Moto Metal 955's, GoodYear DuraTrac 265/75/16's, N-Fab Nerf Bar
    Although the 4 ton is plenty, I'd get the 6 ton just for the peace of mind. Also, you never know what your future applications may be.
  9. Nov 15, 2009 at 9:47 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Sounds like a personal problem...couldn't resist. :p Get the one that is best fit for your truck.
  10. Nov 15, 2009 at 12:09 PM
    sonjay
    sonjay Well-Known Member
    4 ton=8000lbs. Your truck doesn't weight anymore then 4000lbs.
  11. Nov 15, 2009 at 1:01 PM
    Janster
    Jandy
    Lancaster, PA
    I'll need even more lifting / height as I get older. Gravity is evil. :D
  12. Dec 9, 2009 at 11:43 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    Is there a thread or info with pics somewhere here where i can see the best and safest place to place the jack stands under the truck ?
  13. Dec 9, 2009 at 12:03 PM
    98tacoma27
    Ben
    Not Beech Creek
  14. Dec 9, 2009 at 12:05 PM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
  15. Dec 9, 2009 at 12:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think it might show you in the manual
  16. Dec 9, 2009 at 12:06 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sorry, Tahla. That was meant as a joke for another memeber that we pick on about jackstands.
  17. Dec 9, 2009 at 12:08 PM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
    lol haha i firgured ... man you guys are funny .. anyways yeah i read through it but it wasnt clear to me i thought someone might have some clear pictures here but no worries i'll keep looking ....
  18. Dec 9, 2009 at 12:09 PM
    paulm09tacoma
    paulm09tacoma Well-Known Member
    paul
    connecticut
    09 access cab trd
    go big. safety first. money second.
  19. Dec 9, 2009 at 12:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Here is what you are looking for.
  20. Dec 9, 2009 at 12:11 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    x2
    4 ton stands are more then enough, but why not spend a little extra and get a much stronger 6 ton jack stand. For me personally, it is a no brainier. All I use, and all I'll ever use on a truck.
