Tonneau Cover Question
Discussion in 'Tonneau Covers, Caps and Shells' started by msu12181, May 27, 2009.
  1. May 27, 2009 at 11:39 AM
    msu12181
    msu12181 [OP] Member
    07 PreRunner TRD Off Road - Desert Sand Mica
    I have a 2007 Tacoma TRD Double Cab and am looking install a tonneau cover. Is there any tonneau covers out there that allow you to still utilize the rail system after install? I am specifically looking for a roll up kind since I haul everything from a lawnmower to golf clubs in the truck bed. I would still like to be able to use the rail ties to help secure things from sliding around in the back. I would appreciate any advice in this matter...
  2. May 27, 2009 at 11:55 AM
    monte1985
    monte1985 Well-Known Member
    Stan
    Lancaster NY
    09 Tacoma Dbl Cab 4.0 S/C
    Supercharger, Magnaflow Exhaust. Audio System . Gauges TRD CAI
  3. May 27, 2009 at 12:02 PM
    msu12181
    Thanks I appreciate the suggestion. I noticed on one website that they come in different colors. Would you go with black cover for Desert Sand Mica color Taco?
  4. May 27, 2009 at 12:18 PM
    msu12181
    Any other brands out there for suggestion? Or should I say is there any brand I should stay away from? Main goal is soft roll up cover but still want to utilize rail system.
  5. May 27, 2009 at 12:23 PM
    SHunter080703
    SHunter080703 Well-Known Member
    I have an Access Roll-up Tonneau cover.
  6. May 27, 2009 at 12:46 PM
    heintjie
    heintjie Member
    Southern California
    2006 Toyota Tacoma 4X4 Double Cab (long bed)
    I have a white ARE Tonneau cover that matches my Super White Long Bed Double Cab 06 Tacoma. I like the aerodynamic design that the cover has and it doesn't hinder the use of the rails. http://www.4are.com/product/lsii/
  7. May 27, 2009 at 12:50 PM
    msu12181
    I am planning on installing this myself. What would be one that is simple and easy? I have read somewhere that you have to take the bed rails off to install certain brands. Any thoughts?
  8. May 27, 2009 at 12:57 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    most of the trifolds will be the easiest to put on, 4 clamps and your done. Even the ones where you pull the bed rails, like the access tonneau above are not hard to install, just a little more time consuming. All that said, Access is one of the nicest tonneaus on the market. I also really like Extang
  9. May 27, 2009 at 12:58 PM
    heintjie
    heintjie Member
    Southern California
    You could install it by yourself but I would suggest having a friend help you install a tonneau cover. I get to keep the rails on my truck intact with the ARE tonneau cover that I got. Installation should be around 30 mins to an hour depending if you've got some help and if you're already familiar with the installation steps.
  10. May 27, 2009 at 1:04 PM
    SHunter080703
    A friend and I installed mine in 30 minutes or so.
  11. May 27, 2009 at 1:12 PM
    msu12181
    Thanks again for all the suggestions...
  12. May 27, 2009 at 1:13 PM
    SHunter080703
    Good luck and let us know what you pick up.
  13. May 27, 2009 at 1:21 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I also have the Access Roll-Up and am very happy with it. It installed in about 30 minutes and I did it by myself using basic tools. It is nearly watertight and very easy to roll out or roll up.
  14. May 27, 2009 at 1:28 PM
    heintjie
    heintjie Member
    Southern California
    Btw, the ARE tonneau cover also addresses the security issue with the Tacoma tail gate (for some weird reason toyota did not put any lock on it if you haven't noticed) by having the lock built-in. Because of this, the ARE cover is not only very strong/surdy, water tight, but will definitely secure your bed. Just wanted to add that thing up there.
    See my Tacoma with ARE Cover below:
    http://www.4are.com/cgi-bin/_b/gallery.cgi?pictureid=4065&max=4083&truckmake=
  15. May 27, 2009 at 4:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The Access covers are great and most allow use of the bed rail system. I have the Literider so I know for sure that does.
    It took me about 2 hours to install the Literider but that's because I did it myself and it's a little tricky putting the bed rails back on with the spacers and tonneau rails at the same time.
  16. May 27, 2009 at 4:42 PM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    For soft Rollup I would suggest any of the Access line...
    We also offer a pretty sweet deal on Access to TW members...:D
    See pricing page below...
  17. May 27, 2009 at 4:56 PM
    SHunter080703
    I wish I had known this when I got mine.:(
  18. May 27, 2009 at 5:43 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Access roll up all the way... Yes, you do have to take the rails off, but with a second pair of hands a piece of cake. I did mine by myself in about an hour. Plus you get to use your rails and cleats when done :D
  19. May 27, 2009 at 5:46 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    My Advance Accessories Hardshell tonneau locks into the factory bedrails, however you can still use them! No reason why not. The cleats are still there and can be moved.
    Don't have a better picture than this, sorry.
  20. May 27, 2009 at 6:02 PM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    What about the Loredo? I to am looking for a high quality/fitment roll up cover that allows the use of the rails. Prefer not to remove and shime the rail out....
