Buzzing Noise from behind dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, May 27, 2009.
  1. May 27, 2009 at 6:28 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    Hey all, I have tried to wrap this bundle of wires and have zip tied and I am still getting that stinkin "buzzing noise" at low rpms.... IT IS DRIVING ME CRAZY!!! Has anyone zip tied theres and still got the buzzing noise? I am wandering if there is really anyway to stop it.
  2. May 28, 2009 at 6:10 PM
    danmckennat
    danmckennat Well-Known Member
    chardon, ohio
    2009 tacoma access cab offroad package
    i did same as you and still noticed it, after playing and playing with it the thing i did was you know the big wire harness behind the glove box, it should be wrapped in a black plastic or whatever that material is, cut all the black plastic off the wire harness then zip tie it, i did that and the noise went away, for some reason i think the plastic wrapping was causing the wires to rub making a buzzing sound.
  3. May 28, 2009 at 6:14 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I have a slight buzz coming from the passenger side of the dash. Unless I'm drunk, I am the only one driving and never have a chance to listen for the source.
    Anyway, it sounds like its coming from the glove box area.
  4. May 29, 2009 at 9:49 AM
    Planner
    Planner New Member
    Iowa
    09 V-6 4x4 Dbl cab short bed
    I have an '09' that had a buzzing sound on the passenger side of the dash. The right side of the glove box has a plastic round tube devise that has a spring mounted in it to allow the glove box to drop slowly. I took it off and messed around with it, pulling on the stem that pulls and stretches the spring. Hooked it back up and no more noise. It did make a buzzing noise when i first messed with it. Haven't heard it since.:)
  5. May 29, 2009 at 10:05 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Same here. The sound has been gone for a while but I remember hitting the glove box and things in that area to get the damn buzzing to stop when I was at a stop sign or red light. I think I forgot it for a while since my radio is up about halfway when I am driving.
  6. May 29, 2009 at 12:40 PM
    danmckennat
    chardon, ohio
    [​IMG][​IMG]
    ok here is what i did i took all that black wrapping off the big wire harness, then i unplugged ever single harness and wrapped them with electric tape then put on a few zip ties. those are the best photos i could get to try and help.
  7. Nov 10, 2009 at 5:07 PM
    Cwhitt09taco
    Cwhitt09taco Well-Known Member
    Cody
    Mississippi
    09 Double Cab Tacoma TRD Offroad 4wd
    Stock for now. Bfg at's, aries bull bar, aries nerf bars, uws tool box.
    My 09 is doing the same thing. Should i take it back for warranty work, or do it my self and re-wrap the wiring harness?
  8. Nov 10, 2009 at 5:37 PM
    JONNY TACO
    JONNY TACO Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    I took it in under warrenty and they fixed it.
  9. Nov 10, 2009 at 5:42 PM
    Cwhitt09taco
    Cody
    Mississippi
    alright thanks i plan on taking it back during thanksgiving break for warrenty work. i have the buzzing sound, engine is ticking, transmission slip under 10 mph it doesnt wanna shift and my fenderwell is loose it rattles a lot
