09 Seat Belt Chime and Light and ...
Old 06-02-2009, 12:33 PM   #1
Massy [OP] Massy is offline
Massy is on a distinguished road
Massy's Avatar
Massy's Tacoma Gallery
I've read the how to for turning off the seat belt chime and light however I still can't seem to make it work.
1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
2) Make sure seat belt is not fastened
3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
If I wait until "everything light up" and hold for 12 seconds nothing happens. When I release after 12 seconds or more the display cycles to Trip A.
However, if I press and hold the trip at the same time as I turn the ignition to "ON" there are five "-----" which count down until there are none then it displays "000000".
4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
I can't get the display to show XXXXXX.
Hopefully I'm just missing something minor, cause I hate that chime. Can anyone with a 2009 clarify the procedure for me?
And while I have some attention, can anyone briefly explain to me why turning the LSD off is a good idea? I don't know much about the limited slip differential except that it gives more power to the back wheel that has traction, and less to the wheel that is spinning free. So turning the LSD off will give 50-50? Does turning the LSD off have any impact when my back wheels are stuck in the mud/sand? Does turning off the LSD allow me to burn out and drift like a pro?
It's probably pretty obvious I don't know what I'm talking about, so anyone want to enlighten me?
Old 06-02-2009, 01:56 PM   #2
Massy's Avatar
bump
Old 06-02-2009, 01:59 PM   #3
itzdaREV is on a distinguished road
itzdaREV's Avatar
itzdaREV's Tacoma Gallery
Send a message via AIM to itzdaREV
dont let go of the trip knob. fasten your seat belt while still holding it. i couldn't get it to work either, then i realized i was supposed to let it go after i fasten the seat belt
2012 seat belt chime disable jesse.jamz 2nd Gen. Tacomas 87 12-14-2014 11:41 AM
2011 seat belt chime mod nick 2nd Gen. Tacomas 233 11-23-2014 06:06 AM
Seat Belt Chime jhu616 Technical Chat 1 12-16-2011 03:38 PM
Forkin' Seat Belt Chime!?! Bosmob 2nd Gen. Tacomas 63 10-12-2011 08:08 PM
seat belt chime help Bellis General Automotive 1 03-07-2010 08:18 AM
