06 Tacoma fuel filter
Old 06-12-2009, 05:17 PM   #1
peleus21 [OP] peleus21 is offline
peleus21 is on a distinguished road
peleus21's Tacoma Gallery
Angry 06 Tacoma fuel filter
i off road quite a bit and have had my fuel cap and spout get wrecked. the cap will no longer stay tight and now i got enough dust in the tank that the screen on the pump is plugged.(it is the only fuel filter on the whole damn truck)
toyota says that you have to buy a whole new fuel pump to get the screen and that it is not an individual part. can anyone help? is there an aftermarket deal a guy can find?
the pump is 800 dollars!!!
Old 06-12-2009, 05:23 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
The filter IS part of the pump....You should be able to find the pump cheaper than $800.00 though.
Old 06-12-2009, 05:32 PM   #3
the filter is removable, held on by a bolt i believe was able to take it off and clean it even
and so far noone even has a part number for a pump
Old 06-12-2009, 05:36 PM   #4
chris4x4's Avatar
Maybe you can find some similar material and make one?
Old 06-12-2009, 05:39 PM   #5
maybe but it is not a sock like some of the other screens i have seen. it looks more like a power saw air filter. a screen glued to a housing. i would have to add a fuel filter in line if i make it from anything else just to be safe. this thing should have one anyways.
Old 06-12-2009, 05:57 PM   #6
chris4x4's Avatar
I agree.
Old 06-12-2009, 08:11 PM   #8
that is exactly what i need
now if urd had a check out system that actually worked i could buy it
Old 06-12-2009, 08:52 PM   #9
Dirty White Boy
Marc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shedMarc M is one of the sharper tools in the shed
Marc M's Avatar
Marc M's Tacoma Gallery
Send a message via AIM to Marc M
How are you not getting a CEL with a loose gas cap??
Marc M
Old 06-12-2009, 09:39 PM   #10
i was i replaced the cap with a locking cap and replaced the filler tube and the new tube is just as bad. i know this must be a problem but toyota is not releasing a tsb on it but the new trucks come with proper screw type gas caps. my locking one can be taken off without unlocking it or even wiggling it.
don;t get me wrong i love my truck but toyota is no better then ford for making stuff to break down and cost a fortune to fix. my next truck i am building from scratch and i bet it beats the pants off anything on the market for reliability, performance, and price
Old 06-12-2009, 09:52 PM   #11
DDD DDD is offline
Shine bright like a hymen
DDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shed
DDD's Avatar
DDD's Tacoma Gallery
Keep us up to date on how well that works out for you...
Old 06-13-2009, 04:31 PM   #12
judd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant futurejudd94 has a brilliant future
EMS:
judd94's Tacoma Gallery
ok so i did a little research to prove the stealership wrong.
all of this is direct from shoptrd.com
i would paste a picture of all the system components which you can order separate but i'm having trouble with that.
there are 2 pieces to the filler hose
- "filler hose" the half that goes to the tank
- "filler pipe" the half that goes to the fuel opening
There is a fuel filter which is shaped like a canister, then there is a separate "filter" that looks like a cap thingy with a small tube coming down but you can't just order that piece.
Filler Hose MSRP 37.44 Cost 27.46
Filler Pipe MSRP 133.04 Cost 97.58
Fuel Filter MSRP 53.02 Cost 38.88
Fuel Cap MSRP 19.44 Cost 14.25
Fuel Pump Assy MSRP 638.44 Cost 468.27
Old 06-13-2009, 09:34 PM   #13
that is correct can't order the filter by itself real stupid.
i completed my order with URD and am real excited to put it in and be back to full status
Old 06-13-2009, 11:50 PM   #14
Banned
johnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shedjohnecon2001 is one of the sharper tools in the shed
johnecon2001's Tacoma Gallery
Send a message via AIM to johnecon2001
Can you do a write up if you do the work yourself? I will probably end up doing one of these eventually as well.
Old 06-14-2009, 03:24 PM   #15
i sure can hope to have it up by next week. the downfall of the whole thing is that it is easier to do it by pulling the box of the truck off then dropping the tank. i will post both
FUEL TANK 06 Tacoma jazzman1 2nd Gen. Tacomas 12 01-13-2015 09:38 PM
Fuel Filter location '99 Tacoma??? SIK99Tacoma 1st Gen. Tacomas 21 02-04-2013 08:15 AM
Help, tacoma stumbles and dies after fuel filter change. Beluga 1st Gen. Tacomas 10 03-24-2012 07:29 PM
01 Tacoma 4x4 fuel filter help ZanderD 1st Gen. Tacomas 10 07-26-2010 05:39 PM
'98 Tacoma - Timing Belt & Fuel Filter Maint? OysterCracker 1st Gen. Tacomas 10 09-29-2008 06:30 PM
