My 12V MOD
View Poll Results: What do you think?
Looks good would do it the same way. 64 84.21%
Looks good but i would have done it different 8 10.53%
Looks bad 0 0%
I cant believe you cut a hole in your bed!!! 4 5.26%
Voters: 76. You may not vote on this poll
Old 06-20-2009, 07:18 AM   #21
mvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud ofmvega1969 has much to be proud of
mvega1969's Avatar
mvega1969's Tacoma Gallery
Send a message via MSN to mvega1969
I did install not one but three 12v, two in the bed and one under the hood, you never know where you will need it.
One side:
And under the hood: (it was not there at that time but is now below the red cable on the left)
Old 06-20-2009, 07:28 AM   #22
bass turds
Veccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shedVeccster is one of the sharper tools in the shed
Veccster's Avatar
Veccster's Tacoma Gallery
^ what kind of stuff do you run off those?
I've never been under the hood and felt the need to charge my cell phone. That is the only thing I would use those for!
Nice work too...your install is very clean looking!
Old 06-20-2009, 07:36 AM   #23
mvega1969's Avatar
Anything that has a 12v input, for me: a Fan (mosquitos away and cool breeze), air compressor (big enough) to inflate sport balls, my truck tires or even someone else tires, run/charge my laptop, charge my phone, extra needed lights at front or back, my 2,000,000 candle spotlight for wild boar hunting.... and probably a lot of more uses in the future.
Old 06-20-2009, 08:57 AM   #24
Aalders [OP] Aalders is offline
Aalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud ofAalders has much to be proud of
Aalders's Avatar
Air Force: Electronic warfare tech
Aalders's Tacoma Gallery
Looks sweet. You can never have too many power outlets, lights, and switches to control them. My next thing is to put another DC to AC inv 1000 Watt plus for the rear outlet and use the stock 400 Watt for the cab outlets ill install.
Old 07-20-2009, 03:02 PM   #26
bigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud ofbigyetti has much to be proud of
bigyetti's Tacoma Gallery
very nice mod.
Old 07-20-2009, 06:27 PM   #27
Founder Socaltacomas.com
SocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shedSocalMan22 is one of the sharper tools in the shed
SocalMan22's Avatar
SocalMan22's Tacoma Gallery
Thats a nice mod! Good job.
Old 07-20-2009, 07:44 PM   #28
coke_220 is a name known to allcoke_220 is a name known to allcoke_220 is a name known to allcoke_220 is a name known to allcoke_220 is a name known to allcoke_220 is a name known to all
coke_220's Avatar
Coast Guard: DC
coke_220's Tacoma Gallery
so i was wondering did u put an axzilery fuse block under the hood so u only have to run one 12v wier from the batery?
sorry about the spelling
Old 07-20-2009, 10:28 PM   #29
Aalders's Avatar
i ran 8 ga wire with a 80 amp fuse from the battery back to the left rear tail light. this will supply power for this mod and future ones.
Old 07-21-2009, 11:11 AM   #30
coke_220's Avatar
Coast Guard: DC
ok that is cool but y not run a sepret fuse block under the hood so u can only have to run the one wier from the bat and then u can have a block up fron in sted of the back that will be easyer to get to if u need to in the futcher
Old 07-21-2009, 02:37 PM   #31
george3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shedgeorge3 is one of the sharper tools in the shed
george3's Tacoma Gallery
I can't spell worth a damn either. Try the spell check on the computer.
Old 08-29-2009, 08:42 PM   #32
teri4lance is on a distinguished road
teri4lance's Avatar
Army: FDC , A battery 6/9FA
teri4lance's Tacoma Gallery
$16 and 10 second install........
http://www.tweetys.com/7-pin-to-12-v...our-hitch.aspx
Old 12-10-2012, 06:47 PM   #33
canucktacoma is on a distinguished road
canucktacoma's Tacoma Gallery
realize thread is not current,new to site/tacoma owner.just got my2008,base sr5/4cyl.has the garage door/vanity lite setup over mirror,was thinking of 12v outlet/usb setup so i could plug gps in /mount bup ocer mirror.reduces wires.have you thought of putting 1 there?is there wires in place already.mike
Old 12-13-2012, 06:50 PM   #34
calixto25 is on a distinguished road
calixto25's Tacoma Gallery
sub'd
Old 12-13-2012, 07:10 PM   #35
SitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to all
SitkaSpruceMica's Tacoma Gallery
Looks nice.
TC
Old 03-25-2013, 11:00 PM   #36
byrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud of
byrd's Avatar
byrd's Tacoma Gallery
I'm running one under the hood as well for my trouble light, small air compressor, etc might as well run one in the bed. Lots of stuff you can use them for and only having the 1 in cab, sometimes the cords aren't long enough to reach where you need to go. My in cab one I plug my CB into when on long trips, or plug a 110V AC Inverter in to charge my AA rechargeable batteries for my digital camera, or my camcorder.
Old 03-26-2013, 06:35 AM   #37
mvega1969's Avatar
It is worth it.
Every single change we do to make our life more convenient it is worth the time spend on it.
Lets keep things flow.
Old 03-26-2013, 05:52 PM   #38
byrd's Avatar
Agreed! Just installed rcbs204's board to light up my 4x4 selector switch, another happy camper! On to the next mod!
12v outlet not working Front sight 2nd Gen. Tacomas 14 12-09-2012 02:04 PM
Amps for the 12v? Fightnfire 2nd Gen. Tacomas 6 08-11-2011 09:47 PM
Mod suggestions for 12v rechargeable flash lights and accessories..... dessertsand05 2nd Gen. Tacomas 1 03-23-2011 11:55 AM
12v Power Snoyota 2nd Gen. Tacomas 3 01-26-2011 02:00 AM
12v constant on??? thebigk 2nd Gen. Tacomas 3 04-26-2009 04:18 PM
