Motherf*&#@! Can it be fixed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notty, Jul 9, 2009.
  1. Jul 9, 2009 at 9:20 PM
    #21
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Bummer you're not in the valley, or I'd do it for you, too.
  2. Jul 9, 2009 at 9:34 PM
    #22
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    I thought you had to rethread the hole (oversize) to insert a heli-coil. At least the ones I have seen.
    The knuckle would have to come apart to fit a tap handle. At least the ones I have seen.
    I need to get out more... :eek:
  3. Jul 9, 2009 at 9:37 PM
    #23
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    next time just undo the upper control arm castle nut and zip tie the spindle to keep it in place. no need to undo all that extra stuff on the bottom
  4. Jul 9, 2009 at 9:39 PM
    #24
    kevhogaz
    SR5 PreRunner
    You could just move the ball-joint out of the way. The other bolts not stripped out, so just take it out, and spin the ball-joint around to where you could work on it.
  5. Jul 12, 2009 at 10:18 AM
    #25
    Notty
    Notty [OP] Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
    After going to six different shops that refused to touch it due to it being too much of a "liability", I found a place that was able to help me out. At first the owner said he didn't have a tap big enough to help me, but when I happened to mention I had bought two replacement bolts just in case I needed them he got very happy. He asked if he could destroy one of the new bolts and use the other one to fix it. I told him as long as it is done right and I don't have to worry about it breaking.
    So, he took out the bolt I jacked up:
    Then made a tap out of one of the new bolts:
    And now it is good as new. I did not know you could make a tap out of a bolt, but it worked like a charm. He was done in about 30 minutes and charged me $19!!!!!!!! In my 11 years of driving/working on my vehicles, this was the first time I had stripped or crossthreaded a bolt and I thought I was in for a big repair bill, so I am happier than a pig in sh*t that it was so easy/cheap to fix once I found someone to do it!!
  6. Jul 12, 2009 at 10:22 AM
    #26
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I mean your gonna have too...fuck it lol
  7. Jul 12, 2009 at 2:51 PM
    #27
    XC4ME
    XC4ME Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    That's cool how he made the tap. Glad it worked out for ya.
