Bushwacker Flares For Dbl. Cab Shortbed....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trooper440, Jul 27, 2009.
  1. Jul 27, 2009 at 5:14 PM
    Trooper440
    Trooper440 [OP] Active Member
    Scotty
    Alabama
    07 TRD Sport,Dbl. Cab, Short, Speedway Blue
    Bug Shield, Vent Visors, XM Radio, Black Toolbox, TRD emblems, N-Fab step bars, KMC XD 17"x9" wheels, Weathertech floor mats, Door seal protectors, Blue booster seat, 3" Ultimate lift, MT ATZ 285-70-17 tires
    I just received an email from Bushwacker that confirmed that they have pocket flares available for the short bed dbl. cab Tacomas. Part# 31925-02
    The long bed version is Part# 31920-02. I've checked all 4by websites that I know of and they only show Part# 31920-02 for the long bed. It clearly states on Bushwackers website that Part# 31925-02 will fit the short bed version o the dbl. cab.
  2. Jul 27, 2009 at 5:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    wouldnt be bad if they made them in the cut outs or extended flares...
  3. Jul 27, 2009 at 5:38 PM
    Trooper440
    Scotty
    Alabama
    I think they're supposed to add 1.5 to 1.75 inches of extra coverage.
  4. Jul 27, 2009 at 5:39 PM
    The_Hodge
    SC
    that wouldnt be bad, but i didnt see that anywhere in the descrpition for the taco or the generic for the flare type
    EDIT: nvm...found it...1 3/4", but thats from the metal..not the width over the stock flares
  5. Jul 27, 2009 at 6:16 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Actually by my calculations they would add 1/4" additional coverage over the stock flares.
  6. Jul 27, 2009 at 10:13 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    I'm confused.... Help!
  7. Jul 28, 2009 at 12:15 AM
    toku58
    Mall Crawler!
    Well I'm not 100% sure about this?
    But BW states that it gives an additional 1 3/4" to your truck.
    It isn't clear if they mean 1 3/4" more than the stock flares or 1 3/4" from bare fender.
    The stock flares gives 1.5" more coverage than the bare fender.
    So I believe that it will only net about .25" over the factory flares.
    But again I'm not sure? I will be ordering a set and testing them out, if that part # is true.
  8. Jul 28, 2009 at 12:48 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    who cares about the fenders, its the cab mount that F's us all.
  9. Jul 28, 2009 at 12:52 AM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    i would be all over them if they added at least an inch, otherwise, i do not see the purpose...post pics if you get them install...
  10. Jul 28, 2009 at 7:51 AM
    The_Hodge
    SC
    ditto...i'd even say 1/2 to 3/4" and i'd be over it. cover up the 285's some more
    if u go to their site and look it up, it says they are 1 3/4" but click for more details. the diagram then shows they extend 1 3/4" from the metal out and thats where they get their measurements. well u give us the verdict when ya get em:D
  11. Jul 28, 2009 at 8:05 AM
    toku58
    Mall Crawler!
    yeah I know, I've seen that. That's why I think it will only give an extra 1/4". My stock flares extend 1.5" from the metal out.
    So $400+ may not be worth it?
  12. Jul 28, 2009 at 8:08 AM
    The_Hodge
    SC
    if its only 1/4" then i'd lean towards not worth it....unless the main want for them is different design than stock. i'd much rather have some that look like stock but stick out more
  13. Jul 28, 2009 at 8:17 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    oh the $400 gives you a little bit of a built in mudflap and some fake bolts too:rolleyes:
  14. Jul 28, 2009 at 8:31 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Haha, true that!!!:D
  15. Jul 28, 2009 at 8:58 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey go to Truckaddons.com and you will find them for the Double Cab short bed models for $399 shipped because they are having a sale or something. I was really pissed because it took them so long for them to come out for the short beds but I am thinking of getting a set.:rolleyes: Only problem is they don't come color matched and I don't trust anyone in the town I live in to paint them.:cool: I don't want to take a spray can to those you know?
  16. Jul 28, 2009 at 9:02 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    I bolted my OEM on for less than $80.00 with 1/4"x2" SS round hex bolts and 1/4" SS finishing washers.
  17. Jul 28, 2009 at 9:37 AM
    toku58
    Mall Crawler!
    why??????
  18. Jul 28, 2009 at 10:41 AM
    Mandy3206
    San Juan PR
    I removed my flares to test for rub on my 33x12.50 and some of the tabs inside the flares broke off, even thou I used a bondo spreader to pop them out.
    Then I found that all of the clips holding the flare were one time use only and the dealer wanted $3.00 and $2.00 for each clip so I epoxied the broken tabs on the back of the flare and drilled holes through the flare in the same location the OEM clips were so now the flares are bolted in the same location as the OEM clips thus no need to drill the fender.
    SS hardware cost me +/- the same as the OEM clips and now I can remove them whenever I want.
    I also used 1/4" clear tubing as a spacer so the bolts never touch and scratch the paint in the fender holes.
    Bonus is I got the Bolt-on look that I wanted so much :cool::cool:
  19. Jul 28, 2009 at 2:45 PM
    The_Hodge
    SC
    thats one thing i could do w/o on the BW ones is the bolt on look. stock finished and wider would be perfect
  20. Jul 28, 2009 at 4:15 PM
    rrtaco
    rrtaco Well-Known Member
    Colton
    Culpeper
    07 Tacoma Double Cab, Long Bed, Radiant Red
    Kenwood head unit, Alpine speakers with Rockford fosgate amp, kicker subs in box behind rear seat. Bhlm style headlights with ddm tuning 55w 5k headlight and fog light. Bed liner on bed and toolbox. Rear bumper fog lights. Super 44. Custom Exhaust Fox 2.5 Coilovers Total Chaos UCAs Allpro U Bolt Flip 33" Mickey Thompsons
    sweet decals:confused:
