TRD Exhaust Installation Instructions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by se7en, Aug 6, 2009.
  1. Aug 6, 2009 at 6:12 PM
    se7en
    se7en [OP] Go Vols!
    East TN
    21 Limited 4x4 Nightshade, Wind Chill Pearl
    I looked the site over and really didn’t see anything on how to install the TRD exhaust so I decided to make a little installation instruction. Not everyone is a gearhead like many of us so I thought it would be a good idea to give those less wrench worthy a little confidence on the installation. I did read several posts that suggested that this was “easy”, “no problem”, etc. but nothing to give those a real heads up. There are no pictures because this really is easy to do.
    Don’t get the tools yet…that’ll come in a minute, but you’ll need a 14mm socket, a ½” wrench, and an old milk crate (or something similar). No ramps or lift required if it’s a 4x4.
    1.Get some WD-40 and spray the rubber hangers where the exhaust is inserted into them. I chose to spray them where I would leave the rubber hangers attached to the truck instead of removing them with the pipe. Now, go get the tools as this will give the WD-40 time to make the rubber slippery enough to slide the pipe out. Get the 14mm socket and the ½” wrench. You’ll need a ½” wrench to get enough oomph to get the spring bolts loose.
    2.Wrap the end of the pipe behind the mudflap with a rag and use a rubber band or tape to secure it. This will keep the quarter panel from getting scratched as you twist the pipe during removal.
    3.Loosen the 14mm spring bolts located next to the Y-pipe. Mine were on there with Loctite, so I had to use a little muscle to get them loose. Remove them completely.
    4.I used an old plastic milk crate to support the end next to the Y-pipe as I started to slide the pipe out of each rubber hanger. This will take some pressure off the rearmost hanger when you get that far. Start at the front and work your way back. The milk crate (or other support you may use) will pay dividends during this and the next step.
    5.Once all have been removed, you’ll need to twist the exhaust in order to get it over the rear axel. You’ll want to take the whole thing toward the front of the truck. Once removed, lay it to the side.
    6.Now, wrap the chrome tip of the TRD exhaust to, again, prevent unwanted scratching.
    7.Reverse procedure #5 above, twisting and turning until the catback is past the rear axel. Place the front back on the milk crate for support and start placing the exhaust back in the rubber hangers. Start and the rear and work your way forward.
    8.Tighten the spring bolts. No torque wrench required…just as tight as you can as it’ll stop once the shank has been reached.
    9.Polish the tip and go for a ride.
    10.Crack open a beer and marvel at the sight. :cheers: Done!!
    This truly is an easy project and there is NO NEED for the stealership to charge you a 100 bones for this. Total time from start to finish: 30 minutes.
    Hope this helps a few of you out there.
    PatrickR likes this.
  2. Aug 6, 2009 at 6:57 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Nice. Thanks for the write up. I plan on putting on the TRD exhaust after I get my front windows tinted and get an XM receiver put in.
  3. Aug 6, 2009 at 7:16 PM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    So is there a pretty nice sound difference with the TRD exhaust? or do you have to go the Borla / Flowmaster route to find that.
  4. Aug 6, 2009 at 8:32 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    not loud as shit like flows but sounds good, of course i'm over 40 and into the loud shit on my trk, now the harley is a bit different.
  5. Aug 7, 2009 at 5:21 AM
    se7en
    se7en [OP] Go Vols!
    East TN
    That's really a subjective thing. To each their own. I love the sound and it was exactly what I was looking for. Do a search on YouTube...tons of clips. That's why I didn't post one here.
    It doesn't sound anywhere close to a Harely...or I wouldn't have it. LOL ;)
  6. Jan 23, 2010 at 4:25 PM
    tcbe6472
    tcbe6472 Well-Known Member
    Tommy
    Lake Jackson,TX
    09 TRD
    Just completed the installation and took it for a test drive and I love it, nice throaty sound @ take-off and gets quiet @ cruise. I don't know if its me or the truck but it does seem to be running better?? Time will tell..
  7. Sep 16, 2010 at 4:47 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    so you remove the old exhaust by pulling it out towards the FRONT of the truck? would it not be easier to lower the rear spare tire and go in and out that way?
  8. Sep 16, 2010 at 4:58 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
  9. Sep 16, 2010 at 5:49 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    what do you want, a pic of the two nuts you unbolt, or a pic of the three hangers you remove/install the the exhaust from?!! not much to it...
  10. Sep 16, 2010 at 5:54 PM
    DrRabbitFurHead
    Salem, VA
    Pics of the exhaust of course!!! It seems like it belongs. We have a great write up and no pics??? Oh the shame!!! :D
  11. Sep 16, 2010 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can pull it out the rear, but you would have to cut the muffler off. By pulling it out the front, all you have to clear is the rear section.
  12. Sep 16, 2010 at 7:23 PM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    If you want to get the best sound out of a TRD Cat Back get a CAI, really makes it sound allot stronger with the CAI too.
  13. Sep 16, 2010 at 7:28 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    x2.i put a jack on my receiver hitch,and raised it up a bit.loosened the bolts on the front of the pipe,pushed off all the hangers, and slide it out the front with no problems:D
  14. Sep 16, 2010 at 8:45 PM
    Simon's Mom
    Simon's Mom Wag More Bark Less
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Holy thread revival
    proof that search works! :thumbsup:
    Congrats on the new exhaust :burnrubber:
  15. Oct 6, 2011 at 9:39 AM
    Taco Tuco
    Taco Tuco Member
    gary
    Yakima, WA
    2010 Tacoma SB
    se7en, awesome instructions. I had heard about using WD 40, but really liked the milk crate idea and knowing in advance the wrench sizes. It took me about 45 minutes, that was probably due to being 65 and moving slower. I decided to admire my work with a cup of coffee and listening to the gentle rumble of the exhaust, because it is a little early here for a beer. Thanks again, take care drive safe, Tuco
  16. Oct 6, 2011 at 11:44 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Got mine and had it installed last week. Overall, it isn't nearly as loud as I thought it would be, but it does have a nice deep sound. I kinda wish it was bit louder but at least it doesn't sound ricey like how some other catbacks do.
    Pics if anyone is interested...
  17. Oct 6, 2011 at 11:57 PM
    Bens MBL TACO
    Bens MBL TACO Well-Known Member
    San Diego, CA
    07 Prerunner Rumbler
    AFE Air Intake, Billy 5100's up front set at .85 with top plate and lean spacer, Eibach coils, Bilstein 5160's rear shocks, Toytec AAL, TRD Exhaust, Flowmaster Super 44 Muffler, JBA Headers, 5k 35 Watt HID, 3K 35 Watt HID fogs, Anytime fog mod Fierce 265, 70, r17.
    Damn I forgot how nice that oval exhaust looks brand new, ahh takes me back.
    IMG_4049_26b1c330fbcaa34217064e1a3ffc42afb2f05d70.jpg[/QUOTE]
  18. Oct 7, 2011 at 8:42 AM
    Taco Tuco
    Taco Tuco Member
    gary
    Yakima, WA
    2010 Tacoma SB
    I haven't taken it out yet. Installed a CAI as well, hope to take a short trip tomorrow. Love the sound though, I am hoping for improved performance towing my Lance TT 1685. Will checking fuel consumption this weekend. I will reply back when I know more.
  19. Oct 7, 2011 at 11:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Low end is the same as stock, with gains beginning at about 2200 rpm, and gaining up to a peak of 5 hp gain near 5200 rpm.
  20. Oct 8, 2011 at 4:39 PM
    Turbokanji
    Turbokanji Well-Known Member
    Va
    05 sr5 4x4
    Looks good
