2010 4.0 power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtragweed, Aug 15, 2009.
  1. Aug 15, 2009 at 2:19 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    does anyone know if theyre increasing the power of the 4.0 for 2010? i remember a thread a few months ago saying they were going to increase it for the FJ and 4runner i think, just wanted to know if they were going to do it for the tacoma as well
  2. Aug 15, 2009 at 2:27 PM
    Tino4980
    Tino4980 Well-Known Member
    Bermuda Dunes, California
    09 TRD Off Road 4x4, 6 Speed , Magnetic Gray
    They are on the FJ but not on the tacoma there only going to enlarge the cupholders on the taco what an upgrade haha
  3. Aug 15, 2009 at 2:29 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I haven't heard much about the motor power increases in the Tacoma, but I have heard of them in the FJ's and 4runners.
    EDIT: Disregard this post.
  4. Aug 15, 2009 at 2:49 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would think since it is the same engines that they it would be the same. I can't see them making 2 different engines. Keep in mind that as of now they rate the FJ and Tacoma engines with different power ratings. One with premium fuel (the FJ) and one on regular(Tacoma). Maybe the same thing for 2010
  5. Aug 15, 2009 at 2:51 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    One of the threads on here has a pic of the new cup holders. They are not larger. There is an insert that goes where the adjustable thing is now... it just holds two cups.
  6. Aug 15, 2009 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The FJ gets the same engine, computer, etc., as the Tacoma, so I would guess the Tacoma would have the higher output as well.....I guess we'll all find out soon enough. :)
  7. Aug 15, 2009 at 5:09 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    While we are on the subject of engines, the salesperson who sold me my truck said that my engine was made by Yamaha corp. in Japan. Do any of you guys know if this is true?
  8. Aug 15, 2009 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Its a Toyota engine. Yamaha may have helped enginer the throttle by wire, but thats all.
  9. Aug 15, 2009 at 5:25 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Oh ok, thanks.
  10. Aug 15, 2009 at 6:36 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    The engines are not the same... well, basically they are but they already have different outputs, so they are different. I'm not sure exactly what the differences are, but I would say we'll soon (couple years) see a boost to the Tacoma's output to keep up with other midsize trucks.
  11. Aug 15, 2009 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The difference is that the FJ is rated useing 91 octain fuel, and the Tacoma is rated useing 87 octain fuel. No difference in the engines. Which is why they are both a "1GR-FE"
  12. Aug 15, 2009 at 6:49 PM
    JKD
    JKD Well-Known Member
    I read somewhere that the 2005 4.0 engine was rated at 245 hp and 282 lb-ft torque. Since the 87/91 octane discrepancy only accounts for three horsepower (236 to 239), I am curious what made the 2005 engine different.
  13. Aug 15, 2009 at 6:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Different testing method. First, even though there is only a 3 hp gain with the 91, there is a 12 lbs -ft. diff in torque. Very noticable.
    The new method of testing an engines output requires the manufacture to use all the components as they will be in the engine bay. Full exhaust, intake, all accesorise, etc. The old method required them to have all the accesorise, but (for example) have the A/C off, and use a Lab exhaust and intake.
  14. Aug 15, 2009 at 7:00 PM
    phand00
    phand00 Well-Known Member
    Danny
    Canada
    11 DCLB 4WD TRD
    2.5 ICONS Extended Resi ICON 3 Add-a-leaf packs LR UCA 305/70R16 on IS TRD 16x8 CBI Front bumper Custom sliders Toyota slim toolbox
    I think maybe it's something related to double VVT-I that make the difference. Check the tundra. They now have a 4.6L V8 with that in place of the old 4.7L!
  15. Aug 15, 2009 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. The new engine will have variable valve timing on both exhaust AND intake valves, as opposed to only the intake on the 1GR engine.
  16. Aug 15, 2009 at 7:10 PM
    UpstateTacoma
    UpstateTacoma I'd rather be diving than working..
    Greenville SC
    2010 PreRunner!!!
    All Stock, future mods will be audio only!!
    I work for a nissan dealership, and we stole a parts man from toyota. He stated the reason why the fj and the 4 runner are getting an increase in the motor size is bec the 4 runner and the fj are made in japan while the tacoma is made in the usa. For some reason the Japaneses gets better technology before us.. For those who have a fj, look at the first letter or number of the vin. If it says 1 means made in usa, if it says j means made in japan. same for the 4 runner
  17. Aug 15, 2009 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The FJ engine is still 4.0. And the new 4.6 is a little smaller than the 4.7 ;)
  18. Aug 15, 2009 at 7:19 PM
    UpstateTacoma
    Greenville SC
    2010 PreRunner!!!
    Right the reason for the increase of hp has to do with the vvti or something like that.l a new rocker arm and vvti or something new is supposed to increase the hp while the tacoma will not be getting the same upgrade that the fj and 4 runner gets.
  19. Aug 15, 2009 at 7:40 PM
    JKD
    Hey, maybe by the time Tacoma gets the upgraded engine, plus a couple of years, I will be wanting to buy a V6 4x4 quad cab. Say, about eight years from now. If they revamp the Tacoma in 2012-2014, and I decide to buy a new one when my current one is nine years old...yeah, that would work. :D
  20. Aug 15, 2009 at 7:44 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Same with me. This will be the first new vehicle out of the last 3 that I'll be keeping for the long haul. The last two made it no more than 3 years.
