Alignment? Can't adjust caster/camber?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beginah, Aug 17, 2009.
  1. Aug 17, 2009 at 3:39 PM
    beginah
    beginah [OP] Well-Known Member
    I just installed my 5100s and a AAL this weekend and took my truck to Firestone for alignment. The manager and the tech both tell me that on Toyotas the camber/caster cannot be adjusted and only toe. I've read many threads, especially by Toku which says both can be adjusted. Does this make sense to anyone?
    Here are the specs:
    L R
    Camber 1.2 0.8
    Caster -0.2 -.02
    Toe .006 .005
    If I leave it as is, is this okay? Thanks for your help in advance!
  2. Aug 17, 2009 at 3:42 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    thats bs, i just had mine done a few weeks ago
  3. Aug 17, 2009 at 3:48 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    They are full of it.
    Thuguon2.7 likes this.
  4. Aug 17, 2009 at 3:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2! Bunch-O-Shit! Get your money back, and go someplace else.
  5. Aug 17, 2009 at 4:44 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    literally just had mine done 30 minutes ago.... all of it is adjustable.... so they are full of it
  6. Aug 17, 2009 at 5:34 PM
    Tacoluver
    Tacoluver Well-Known Member
    Norcal
    TRD Off Road shortbed
    Volant cold air intake, RevTek 3" Lift, Snug Top Toneau cover, Kenwood Navi, Jamoshi grill
    Had my alignment done at Goodyear last Friday. According to them Camber and toe are adjustable. With a 3" lift I was able to get them both in spec but Caster was a bit off.
  7. Aug 17, 2009 at 7:07 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Run like HELL! Doesn't sound like they have any clue as to what an alignment is?
  8. Aug 17, 2009 at 7:13 PM
    beginah
    Thanks for the replies! Damn, I already paid Firestone for the lifetime alignment. Oh, they also mentioned that the only way to fix the caster was with shims.
    Can anyone recommend a better place in Honolulu? Thanks!
  9. Aug 17, 2009 at 8:03 PM
    toku58
    Mall Crawler!
    Take it to Sears. That's where I had mine done when it had the 3" lift.
    Which Friestone is that? Shims??:confused: Somebody should go in there and slap some sense into them. Get your money back!!!:mad:
    Can you post a picture of your 5100's? By the numbers that you gave, I want to see the the 5100's Take a picture of your struts.
  10. Aug 17, 2009 at 10:19 PM
    JKD
    JKD Well-Known Member
    It would be helpful to take a printout of, for example, the factory service manual, showing the procedure for adjusting caster and camber.
    It is kind of hard for them to continue to claim that it isn't adjustable when you have the procedure in front of you.
  11. Aug 18, 2009 at 1:32 AM
    beginah
    Thanks for the help Toku! I hope these photos help. Please let me know if I should take it at a different angle. I could only get the driver side right now. I'll post the other side tmw. Thanks again!
  12. Aug 18, 2009 at 2:47 AM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I had similar experience with Firestone. Since I have Firestone lifetime alignment, I went to another Firestone shop. The technician of the other shop was able to adjust them to within specs (though my Billy is at 1.75).
    You may do the same to save money, making use of your lifetime alignment.
  13. Aug 18, 2009 at 10:52 AM
    beginah
    JKD, that's a good idea. I tried to google it, but couldnt find anything. Does anyone know have a link to a factory service manual online? Thanks!
  14. Aug 19, 2009 at 1:02 PM
    beginah
    So I took it to another Firestone this morning and the specs are below. They said caster was maxed out and this was the best they could do. I know the are off from optimum, but are these specs really bad?
    Maybe is there something wrong with the lift?
    Also, I'm experiencing a very slight shudder between 5-7 mph. Shoud I be concerned with this and what should I do?
  15. Aug 19, 2009 at 1:14 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    i got my alignment done also
  16. Aug 19, 2009 at 9:24 PM
    toku58
    Mall Crawler!
    Hey, Sorry for the late reply.
    I see your problem!
    You installed the spring mount upside down. That is why your numbers are so off!
    I had a feeling you did that that's why I asked for the picture.
    You need to flip them over.
    Good Luck!
  17. Aug 19, 2009 at 9:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im pretty sure they are correct. These are upside down:
  18. Aug 19, 2009 at 9:28 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    DOH!
    Hopefully those puppies stay togeather from now to when he reads this thread again.
  19. Aug 19, 2009 at 9:32 PM
    SC4333
    Grant
    FL
    The strut pictured is actually correct.
    The picture that the OP posted is most definitely upside down. I'm not sure of how safe that could be either.
  20. Aug 19, 2009 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....The mounting is the same whatever direction, so I cant imagine any safety issue arising. Good to know which is which though. :)
