09+ Electronic Traction Systems Explained
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd09, Aug 22, 2009.
  1. Aug 22, 2009 at 11:32 AM
    trd09
    trd09 [OP] Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    With all the confusion on how the many different traction systems alphabet soup work, I did some research and figured I'd throw this together.
    Trac- Cuts power and brakes spinning wheel(s). “Traction Control”
    VSC- Controls spins by braking select wheels. “Stability Control”
    AutoLSD- Brakes spinning wheels to emulate LSD- does not cut power. Avail only in 2WD mode.
    ATRAC- Avail only on OR models. Similar ALSD operation except available in 4WD mode.
    When you start an 09 Tacoma:
    Trac- On
    VSC- On
    AutoLSD- Off
    When wheels spin, cuts power and brakes spinning wheel. If slide is detected, “beep beep beep” and slide is corrected.
    Quick push of button:
    Trac- limited op (see below)
    VSC- On
    AutoLSD- On
    When wheel spins, brakes spinning wheel but does not cut power (ALSD function). If slide is detected, “beep beep beep” etc. Will only brake select wheels to control spin when spin is detected.
    Hold down button while stopped:
    Trac- Off
    VSC- Off
    AutoLSD- Off
    When wheel spins, it will keep spinning. No slide corrections under 30 mph. ie, used for donuts, etc. VSC is always enabled over 30 mph.
    ATRAC- Only on OR models. Provides “AutoLSD” in 4WD mode (braking spinning wheels but not cutting power).
    In 4WD mode (ex OR), only disable feature is VSC by holding button down (no ALSD), but again activates over 30mph.
  2. Aug 22, 2009 at 11:37 AM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
  3. Dec 4, 2009 at 11:36 AM
    ruppmeister
    ruppmeister Well-Known Member
    Colorado
    09 TRD Offroad
    Moto Metal Skull 17x9, BFG KM2's 285/70R17, Toytec ULK, LR UCA
    Thanks for putting this together TRD09. This was something that was confusing me until you made all the connections between each system.
    Great post!
  4. Dec 4, 2009 at 12:29 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    good job danielson.
  5. Dec 9, 2009 at 3:08 PM
    yahtzee
    yahtzee Member
    Tahoe
    '09 4x4 D-cab Long Bed TRD Sport
    Great info! Now I can spin donuts again.
  6. Dec 9, 2009 at 5:37 PM
    TexasTacoma37
    Thanks I have been wondering what the hell the difference between all those was.
  7. Dec 9, 2009 at 6:27 PM
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    My 2010 TRD OF have soo many buttons it got me confused. thanks for clearing up little. *** STICKY PLEASE ANYONE ***
  8. Dec 9, 2009 at 6:35 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Good post, I was trying to slide in the snow today, and the bells are ringing like crazy. All I wanted to do was slide a little!
  9. Dec 9, 2009 at 6:52 PM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    I posted the following in another thread, but I figure it'd be useful for people to know what to do when you get stuck in snow/mud as well.
  10. Dec 11, 2009 at 8:50 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Nayo2002, thanks for posting that. I especially enjoyed that VSC video. BOSCH created VSC and wow, to know that data from the National Highway Traffic Safety Administration and the Insurance Institute for highway safety show that VSC systems are second only to safety belts in reducing fatalities on our nations roads.
    That's awesome.
  11. Dec 11, 2009 at 11:09 AM
    Juicifer
    Juicifer Member
    This helps explain things. However, shouldn't I hear the Trac come on when I'm driving through a snowy neighborhood road in 2wd and apply to much gas? It seems like my truck just spins and spins. It would be nice if it would assist me at the occasional rainy or snowy stoplights and let me leave it in 2wd since the majority of the roads aren't slick.
  12. Dec 11, 2009 at 11:19 AM
    hendooman
    Jeff
    KC
    Yeah for sure you should, I cant spin the tires without the bells going off and the trac coming on, maybe you have something set wrong. I am also not sure of your model and trim packages...there is a difference.
    And welcome to TW!
  13. Dec 11, 2009 at 11:28 AM
    Juicifer
    Juicifer Member
    I hear and see beeping, but I don't feel anything except spin. I do sometimes get the VSC to kick on if I'm going around a turn, but in a straightline I get nothing. 2009 TRD Off Road, auto. Is it obvious when the Trac engages?
  14. Dec 11, 2009 at 11:33 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    Hold the VSC button(car with squiggly lines) button for 5 seconds, because just pushing the button turns the VSC off, but if you hold down it down for several seconds, it turns the LSD off too and you can fish tail all you want. in 2 hi or 4 hi. Have fun!
  15. Dec 11, 2009 at 11:33 AM
    hendooman
    Jeff
    KC
    same truck I got by the way. It is working, you can really feel it around a turn, it will almost stop you from sliding...because it will lock that spinning wheel or brake it one of the two...it is all so confusing. I am starting to figure it out though. My previous truck was a big gmc 4x4, it just slid till I steared out of it or it hit something :woot:
  16. Dec 11, 2009 at 2:39 PM
    copernicus
    copernicus Well-Known Member
    I just turned off VSC via holding the button down for 5 secs. It does not turn back on above 30 mph.
    (2010 2.7L manual 5 speed)
    TRAC/VSC only turn back on from the quick press of the button, which also activates the Auto LSD function, that combination reactivates the VSC/TRAC and disabled the Auto LSD once it reaches a certaing speed (30 mph I guess).
  17. Dec 11, 2009 at 3:54 PM
    NAYo2002
    Great Falls, MT
    This is true. Only thing that turns itself back on is TRAC (also turns off A-LSD) according to the manual. If you press and hold for 5 seconds, nothing will come back on regardless of speed.
  18. Dec 11, 2009 at 4:26 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    TRAC doesn't cut power in 4WD HIGH. Only transfers torque.
  19. Dec 11, 2009 at 7:36 PM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Commiefornia
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Great info, always appreciate having the tacomas rubiks cube cleared up
